component
Ws2812 LED pixels at 12v
Tue Nov 07, 2017 9:28 pm
I’ve done a load of projects using led strips with ws 2812 5V pixels and the raspberry pi neopixrl library as detailed in the fine tutorial by Adafruit
https://learn.adafruit.com/neopixels-on ... i?view=all
This used a level shifter to shift the pi 3.3v pwm signal up to 5V that the led strip is happy with. It also used a suitably high current 5V power supply for the leds
I’d like to use a 12v strip for another project for a variety of reasons and have found a suitable candidate on eBay
https://m.ebay.com/itm/WS2812B-WS2812-I ... 2871062060
I’ve got a suitable 12v power supply but am a bit lost on the signal line. Do I use the same as the 5V strip or should I shift up to 12v using another level shifter??
Also, is there an advantage if using a higher voltage signal line esp chalky as the strip I went to use is about 8m long?
Re: Ws2812 LED pixels at 12v
Tue Nov 07, 2017 9:45 pm
I've used 12v and 5v WS2813 LED strips with the data line driven directly from the 3.3V GPIO. The data input is not directly related to the supply voltage.
AJB2K3
Sat Dec 23, 2017 6:41 pm
I have the WS2811 set of lights @12v.
I see the arduino uno can operate them by connecting the the neg and sig to the strip (seperate +12 and minus power supply connected to strip with all grounds linked. but can't get a clear understanding of connecting the pi to the strip!
Back in the old days, we were smarter then the technology.
Nowadays technology makes us look like villages fools in front of the children!
