I have an RPi3 with Raspbian Stretch that I have worked on via the command line (SSH using PuTTY).
Now I want to use PiClone to make a backup of the system before I leave it in place, but I have no HDMI enabled monitor and PiClone is a GUI utility as far as I understand it...
So I thought of using VNC instead, but I don't know if one can enable it using the command line only?
Since it is Linux my guess is that it is possible, but how?
I believe that in Raspbian Pixel VNC was enabled by default but I don't know on this Stretch version. In any case my VNC viewer cannot connect to it so I guess it is non-active.
If it is not possible to enable using PuTTY there is a hen-and-egg problem here,,,
