tony1812
basic python question
Tue Nov 07, 2017 2:03 pm
Hello, I have a python array
array={1,2,3,4]
Now I like to retrieve the values in the array using for xxx in range (y)
for index in range(4):
print(array[index])
result: I get all 4 array values-1,2,3,4
but if I use
for index in range(3):
print(array[index])
result: I only get 3 array values-1,2,3
Does in range not start on index 0? Thanks.
bensimmo
Re: basic python question
Tue Nov 07, 2017 2:13 pm
It ends at but does not include the last number, as such
So 4 = 0,1,2,3 (four in total)
It's a bugger and an English Vs Computer thinking.
Python didn't move the Computer part into the background ;-)
pcmanbob
Tue Nov 07, 2017 3:56 pm
Tony.
I thing your confusion is with what's being returned and how the count is done.
run this simple program
items = [1,2,3,4]
for index in range(len(items)):
    print(index, items[index])
and you get this as the result
(1, 2)
(2, 3)
(3, 4)
So the number on the left is the actual counting loop which starts at zero but it returns the first number in your array which is of course one and so on
till we get to the last number which is 3 in the loop but it returns 4 as it's the last number in the array.
So if we change the array to this
items = [11,23,63,84]
We get this as the result which might make things a bit clearer.
(1, 23)
(2, 63)
(3, 84)
jahboater
Tue Nov 07, 2017 4:03 pm
The language B (precursor to C) did that (arrays started at one instead of zero) by adding an extra item at the start that was never used.
The other possibility is continually subtracting one on every single array reference.
Both are horrible!
robbes
Thu Nov 09, 2017 7:55 pm
Only slightly off-topic:
The enumerate method provides an option for you to specify the starting value of the index in an enumerated list.
For example, to have the first value of the index as 1 rather than the default 0:
mylist = [2, 4, 6, 8]
for index, item in enumerate(mylist, 1):
    print(index, item)
bb677a
Tue Nov 21, 2017 7:01 pm
Your main issue is not using the range function correctly. You are only asking for 3 numbers, see below results. Replace that '3'in your code with a '4' and you should get what you want.
	print index
0
1
2
Return to “Python”
