I have problem with startup kodi, but i don't know how this problem solve. I am a newbie and I have no experience with the raspbian system. When I try to run the kodi I will flash icons on the desktop. And a crash file is created in the / home folder.
I tried to run the kodi as an root in terminal. I managed to get into the black screen, without the chance to get back to the desktop. I had to pull the adapter out of the socket.
Thank you in advance for any advice.
This is crashlog:
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Ne lis 5 15:59:59 CET 2017
Kodi Options:
Arch: armv7l
Kernel: Linux 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017
Release: Raspbian GNU/Linux 9 (stretch)
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/Trian/core (2017-11-05 15:59:58.391352642 +0100)
[New LWP 873]
[New LWP 868]
[New LWP 869]
[New LWP 871]
[New LWP 870]
[New LWP 872]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Core was generated by `/usr/lib/arm-linux-gnueabihf/kodi/kodi_v7.bin --lircdev /var/run/lirc/lircd'.
Program terminated with signal SIGABRT, Aborted.
#0 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:51
[Current thread is 1 (Thread 0x6f7ff300 (LWP 873))]
Thread 6 (Thread 0x701ff300 (LWP 872)):
#0 0x76ed2ce8 in __pthread_cond_timedwait (cond=0x6f800648, mutex=0x6f800680, abstime=0x701fda10) at pthread_cond_timedwait.c:198
#1 0x00463ca4 in XbmcThreads::ConditionVariable::wait(CCriticalSection&, unsigned long) ()
#2 0x00464108 in CEvent::WaitMSec(unsigned int) ()
#3 0x00641048 in Actor::Protocol::SendOutMessageSync(int, Actor::Message**, int, void*, int) ()
#4 0x00a83e48 in ActiveAE::CActiveAE::InitSink() ()
#5 0x00a86eb0 in ActiveAE::CActiveAE::Configure(AEAudioFormat*) ()
#6 0x00a89018 in ActiveAE::CActiveAE::StateMachine(int, Actor::Protocol*, Actor::Message*) ()
#7 0x00a89c5c in ActiveAE::CActiveAE::Process() ()
#8 0x0069f6b4 in CThread::Action() ()
#9 0x0069fef0 in CThread::staticThread(void*) ()
#10 0x76ecbfc4 in start_thread (arg=0x701ff300) at pthread_create.c:335
#11 0x7537bc68 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 5 (Thread 0x714ff300 (LWP 870)):
#0 0x75372d50 in poll () at ../sysdeps/unix/syscall-template.S:84
#1 0x0050efe8 in CFDEventMonitor::Process() ()
#2 0x0069f6b4 in CThread::Action() ()
#3 0x0069fef0 in CThread::staticThread(void*) ()
#4 0x76ecbfc4 in start_thread (arg=0x714ff300) at pthread_create.c:335
#5 0x7537bc68 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 4 (Thread 0x70aff300 (LWP 871)):
#0 0x76ed2ce8 in __pthread_cond_timedwait (cond=0x1602308, mutex=0x1602340, abstime=0x70afec58) at pthread_cond_timedwait.c:198
#1 0x00659e4c in CJobManager::GetNextJob(CJobWorker const*) ()
#2 0x0065a820 in CJobWorker::Process() ()
#3 0x0069f6b4 in CThread::Action() ()
#4 0x0069fef0 in CThread::staticThread(void*) ()
#5 0x76ecbfc4 in start_thread (arg=0x70aff300) at pthread_create.c:335
#6 0x7537bc68 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 3 (Thread 0x71e6f300 (LWP 869)):
#0 0x76ed294c in __pthread_cond_wait (cond=0x337fea8, mutex=0x337fee0) at pthread_cond_wait.c:186
#1 0x009f12a0 in ANNOUNCEMENT::CAnnouncementManager::Process() ()
#4 0x76ecbfc4 in start_thread (arg=0x71e6f300) at pthread_create.c:335
Thread 2 (Thread 0x71e70000 (LWP 868)):
#0 0x76ed2ce8 in __pthread_cond_timedwait (cond=0x33ea920, mutex=0x33ea958, abstime=0x7ec69d60) at pthread_cond_timedwait.c:198
#4 0x00a852a8 in ActiveAE::CActiveAE::Initialize() ()
#5 0x00a700e4 in CAEFactory::StartEngine() ()
#6 0x007ed84c in CApplication::Create() ()
#7 0x006b79c8 in XBMC_Run ()
#8 0x003d37ec in main ()
Thread 1 (Thread 0x6f7ff300 (LWP 873)):
#1 0x752d7824 in __GI_abort () at abort.c:89
#2 0x75310f78 in __libc_message (do_abort=do_abort@entry=2, fmt=<optimized out>) at ../sysdeps/posix/libc_fatal.c:175
#3 0x75317ad4 in malloc_printerr (action=<optimized out>, str=0x753ca0f0 "free(): invalid pointer", ptr=<optimized out>, ar_ptr=<optimized out>) at malloc.c:5049
#4 0x75318514 in _int_free (av=0x753e6794 <main_arena>, p=0x3431648, have_lock=<optimized out>) at malloc.c:3905
#5 0x00460660 in void std::_Destroy_aux<false>::__destroy<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*>(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*) ()
#6 0x00675e88 in RssSet::~RssSet() ()
#7 0x00675ed4 in std::_Rb_tree<int, std::pair<int const, RssSet>, std::_Select1st<std::pair<int const, RssSet> >, std::less<int>, std::allocator<std::pair<int const, RssSet> > >::_M_erase(std::_Rb_tree_node<std::pair<int const, RssSet> >*) ()
#8 0x006757a8 in CRssManager::Clear() ()
#9 0x008627a0 in CSettingsManager::OnSettingsUnloaded() ()
#10 0x00863104 in CSettingsManager::Unload() ()
#11 0x008648cc in CSettingsManager::Clear() ()
#12 0x0088c10c in CSettings::Uninitialize() ()
#13 0x0088c44c in CSettings::~CSettings() ()
#14 0x752d8dd4 in __run_exit_handlers (status=-1, listp=0x753e64ac <__exit_funcs>, run_list_atexit=run_list_atexit@entry=true, run_dtors=run_dtors@entry=true) at exit.c:83
#15 0x752d8e34 in __GI_exit (status=<optimized out>) at exit.c:105
#16 0x75813b8c in bcm_host_init () from /opt/vc/lib/libbcm_host.so
############# END STACK TRACE ###############
################# LOG FILE ##################
15:59:56.324 T:1910964224 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:59:56.324 T:1910964224 NOTICE: -----------------------------------------------------------------------
15:59:56.324 T:1910964224 NOTICE: Starting Kodi (17.5 Git:20171024-42caaae). Platform: Linux ARM 32-bit
15:59:56.324 T:1910964224 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
15:59:56.324 T:1910964224 NOTICE: Kodi compiled Oct 24 2017 by GCC 6.3.0 for Linux ARM 32-bit version 3.18.11 (201227)
15:59:56.325 T:1910964224 NOTICE: Running on Raspbian GNU/Linux 9 (stretch), kernel: Linux ARM 32-bit version 4.9.59-v7+
15:59:56.331 T:1910964224 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
15:59:56.331 T:1910964224 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
15:59:56.331 T:1910964224 NOTICE: ARM Features: Neon enabled
15:59:56.331 T:1910964224 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
15:59:56.331 T:1910964224 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
15:59:56.332 T:1910964224 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
15:59:56.332 T:1910964224 NOTICE: special://masterprofile/ is mapped to: /home/Trian/.kodi/userdata
15:59:56.332 T:1910964224 NOTICE: special://envhome/ is mapped to: /home/Trian
15:59:56.332 T:1910964224 NOTICE: special://home/ is mapped to: /home/Trian/.kodi
15:59:56.332 T:1910964224 NOTICE: special://temp/ is mapped to: /home/Trian/.kodi/temp
15:59:56.332 T:1910964224 NOTICE: special://logpath/ is mapped to: /home/Trian/.kodi/temp
15:59:56.332 T:1910964224 NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi_v7.bin
15:59:56.332 T:1910964224 NOTICE: Local hostname: RaspberryPI
15:59:56.332 T:1910964224 NOTICE: Log File is located: /home/Trian/.kodi/temp//kodi.log
15:59:56.332 T:1910964224 NOTICE: -----------------------------------------------------------------------
15:59:56.411 T:1910964224 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
15:59:56.466 T:1910964224 NOTICE: load settings...
15:59:56.634 T:1910964224 NOTICE: Found 2 Lists of Devices
15:59:56.634 T:1910964224 NOTICE: Enumerated PI devices:
15:59:56.634 T:1910964224 NOTICE: Device 1
15:59:56.634 T:1910964224 NOTICE: m_deviceName : HDMI
15:59:56.634 T:1910964224 NOTICE: m_displayName : HDMI
15:59:56.634 T:1910964224 NOTICE: m_displayNameExtra:
15:59:56.634 T:1910964224 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
15:59:56.634 T:1910964224 NOTICE: m_channels : FL,FR
15:59:56.634 T:1910964224 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
15:59:56.634 T:1910964224 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
15:59:56.635 T:1910964224 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
15:59:56.635 T:1910964224 NOTICE: Device 2
15:59:56.635 T:1910964224 NOTICE: m_deviceName : Analogue
15:59:56.635 T:1910964224 NOTICE: m_displayName : Analogue
15:59:56.635 T:1910964224 NOTICE: m_displayNameExtra:
15:59:56.635 T:1910964224 NOTICE: m_deviceType : AE_DEVTYPE_PCM
15:59:56.635 T:1910964224 NOTICE: m_channels : FL,FR
15:59:56.635 T:1910964224 NOTICE: m_sampleRates : 48000
15:59:56.635 T:1910964224 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
15:59:56.635 T:1910964224 NOTICE: m_streamTypes : No passthrough capabilities
15:59:56.635 T:1910964224 NOTICE: Device 3
15:59:56.635 T:1910964224 NOTICE: m_deviceName : Both
15:59:56.635 T:1910964224 NOTICE: m_displayName : HDMI and Analogue
15:59:56.635 T:1910964224 NOTICE: Enumerated ALSA devices:
15:59:56.635 T:1910964224 NOTICE: Device 1
15:59:56.635 T:1910964224 NOTICE: m_deviceName : @
15:59:56.635 T:1910964224 NOTICE: m_displayName : Default (bcm2835 ALSA bcm2835 ALSA)
15:59:56.635 T:1910964224 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000
15:59:56.635 T:1910964224 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
15:59:56.635 T:1910964224 NOTICE: m_deviceName : @:CARD=vc4hdmi,DEV=0
15:59:56.635 T:1910964224 NOTICE: m_displayName : vc4-hdmi
15:59:56.635 T:1910964224 NOTICE: m_displayNameExtra: Analog
15:59:56.636 T:1910964224 NOTICE: m_channels : FL,FR
15:59:56.636 T:1910964224 NOTICE: m_sampleRates : 32000,44100,48000
15:59:56.636 T:1910964224 NOTICE: m_dataFormats :
15:59:56.636 T:1910964224 NOTICE: m_streamTypes : No passthrough capabilities
15:59:56.636 T:1910964224 NOTICE: Device 3
15:59:56.636 T:1910964224 NOTICE: m_deviceName : iec958:CARD=vc4hdmi,DEV=0
15:59:56.636 T:1910964224 NOTICE: m_displayName : vc4-hdmi
15:59:56.636 T:1910964224 NOTICE: m_displayNameExtra: S/PDIF
15:59:56.636 T:1910964224 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
15:59:56.636 T:1910964224 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
15:59:56.636 T:1910964224 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512
15:59:56.652 T:1910964224 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
15:59:56.652 T:1910964224 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<fanartres>720</fanartres>
<imageres>540</imageres>
<video>
<busydialogdelayms>750</busydialogdelayms>
</video>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<cache>
<memorysize>31457280</memorysize>
</cache>
</advancedsettings>
15:59:56.654 T:1910964224 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:59:56.654 T:1910964224 NOTICE: Default Video Player: VideoPlayer
15:59:56.654 T:1910964224 NOTICE: Default Audio Player: paplayer
15:59:56.654 T:1910964224 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:59:56.654 T:1910964224 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
15:59:56.654 T:1910964224 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:59:56.655 T:1910964224 NOTICE: Loaded playercorefactory configuration
15:59:56.655 T:1910964224 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:59:56.656 T:1910964224 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:59:56.741 T:1910964224 NOTICE: Running database version Addons27
15:59:58.295 T:1910964224 NOTICE: ADDONS: Using repository repository.xbmc.org
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
