Addicted
Use Wifi in latest raspbian lite stretch in headless mode
Sun Nov 05, 2017 11:50 am
Hi, after stretch update i downloaded lite image for my headless setup.
I created ssh file in boot partition & wpa_supplicant.conf file with necessary content.
However it didn't connected to Wifi.
Then i connected it through ethernet & added following to /etc/network/interfaces.
auto lo
iface lo inet loopback
iface eth0 inet manual
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
        wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
after that i did
sudo systemctl enable wpa_supplicant.service
sudo reboot
After that wifi worked normally.
Is there anyway to do this without ethernet or display?
SurferTim
Re: Use Wifi in latest raspbian lite stretch in headless mode
Sun Nov 05, 2017 11:58 am
Normally this is caused by an error in the wpa_supplicant.conf file. You should have posted the contents of that file.
Addicted
Sun Nov 05, 2017 12:03 pm
This is the content of wpa_supplicant.conf file.
country=US
update_config=1
network={
    ssid="My_ssid"
    scan_ssid=1
    psk="My_pass"
    key_mgmt=WPA-PSK
But there were nothing in interfaces file when i opened it.
only following were in interfaces file.
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
mikerr
Sun Nov 05, 2017 12:12 pm
In Wheezy/Jessie you could get away with a short wpa_supplicant.conf file:
network={
   ssid="MYSSID"
   psk="my  wifi password"
Since Stretch you do now need the ctrl_interface line for it to work.
update_config=1
network={
   ssid="MYSSID"
SurferTim
Sun Nov 05, 2017 12:37 pm
Is this a typo? No closing brace on the network section. Any error will cause a fail.
country=US
update_config=1
network={
    ssid="My_ssid"
    scan_ssid=1
    psk="My_pass"
    key_mgmt=WPA-PSK
@mikerr: Are you on the Tinker Board forum also?
Addicted
Sun Nov 05, 2017 2:20 pm
country=US
update_config=1
network={
    ssid="My_ssid"
    scan_ssid=1
    psk="My_pass"
    key_mgmt=WPA-PSK
Ya thats a typo. Corrected in my post
@mikerr: Ya but wpa_supplicant.conf file is ok & as i posted in 1st post i created wpa_supplicant.conf file in boot partition & it contains ctrl_interface line.
So is that /etc/network/interfaces file supposed to be empty?
SurferTim
Sun Nov 05, 2017 2:24 pm
The source-directory line should be the only uncommented line in /etc/network/interfaces.
Insure the editor you use to create that file is a true text editor. There have been a few problems caused by using a word processor or copy-and-paste from examples where the double quotes were not correct.
Also insure your passphrase is at least 8 characters long.
Addicted
Sun Nov 05, 2017 2:28 pm
But i was only able to connect to wifi after coping following from my 2nd pi running jessie to new stretch headless 1.
auto lo
auto wlan0
allow-hotplug wlan0
btw i'm using rpi2 & using a wifi dongle.
HawaiianPi
Mon Nov 06, 2017 2:02 am
Editing the /etc/network/interfaces file is not needed, and in fact, it shouldn't be modified. If you need a static IP that's done in /etc/dhcpcd.conf now. If you are using DHCP you should not need to edit anything but /etc/wpa_supplicant/wpa_supplicant.conf in Jessie or Stretch. You can actually place that file in the small FAT32 boot partition to connect to your wireless network automatically.
This is the procedure I use for setting up headless boot with SSH and wireless network. It works with Raspbian Jessie or Stretch, Desktop or Lite, and with the built-in WiFi on the Pi3, or a Raspbian compatible USB WiFi dongle on other models (tested on an old model B, Pi2 and Pi Zero). Everything is done before you boot the SD card, and can be done on a Windows or Mac computer which only has access to the small FAT32 boot partition of a Raspbian SD card.
  1. Grab the latest Raspbian image from https://www.raspberrypi.org/downloads/raspbian/
  2. Grab the Etcher software from https://etcher.io/
  3. Install Etcher and use it to write the Raspbian image to your SD card. You don't need to extract the image or format the card prior to writing. Just choose the Raspbian .zip, pick your SD card and write (if you have trouble, verify the SHA256 checksum of the download).
  4. Remove and reinsert the SD card so that your Windows or Mac PC can see the small FAT32 partition on the SD card.
  5. On that small partition, create a file with the name ssh (or ssh.txt).
  6. To connect to a wireless network, create another file on the FAT32 partition called wpa_supplicant.conf which has the following inside:
    update_config=1
    country=US
    network={
    	ssid="Your network SSID"
    	psk="Your WPA/WPA2 security key"
    	key_mgmt=WPA-PSK
  7. Edit country=, ssid= and psk= with your information and save the file.
  8. Safely eject the card from your PC and use it to boot the Pi.
If Raspbian finds an ssh file it will enable SSH and delete the file. If it finds a wpa_supplicant.conf file, it will move it to its correct location and connect to your wireless network. You can try to connect to the Pi with ssh [email protected] (or raspberrypi.local), and if that doesn't work, login to your router to find the Pi's IP address. If you have an ASUS router they have a nice phone app to access and control the router.
If this doesn't work, then check your router for security settings like MAC address filtering or wireless client/AP isolation. Also, make sure you are editing wpa_supplicant.conf with a pure text editor (anything that adds hidden formatting codes will mess it up).
Another nice tool to have is a serial console cable which will let you monitor output and login to the Pi without a network connection. I use a CP2102 USB TTL serial adapter, which is compatible with the Pi's 3V3 GPIO and can be found on ebay for less than $2 (or $5-$10 on Amazon).
Here is my Pi Zero connected to an old Netbook with the CP2102 adapter (with a pcDuino WiFi dongle for wireless).
For the Pi3 or Zero-W you'll have to disable Bluetooth to restore GPIO serial console output, but it's plug-n-play with other models. To disable Bluetooth add dtoverlay=pi3-disable-bt to config.txt, and for the Desktop version of Raspbian, add enable_uart=1 to enable the serial console.
Search ebay for CP2102. There are zillions of them and prices are all over the place. As long as it's a CP2102 chip based model it should work the same as any other. Typically they run in the $2-$5 range, but there are a few for under $2, and even some under $1.50.
There are 5 and 6 pin models. The 5 pin models are mostly missing the DTR line, which is important for Arduino but not needed for the Pi serial console (Pi only needs RXD, TXD and GND, which they all have). So if you don't care about Arduino compatibility, get either type. The ones I have are all 6 pin, but even some of those don't have DTR, so it's a little whacky because they all aren't wired the same.
As long as you follow the labels on the output pins you'll be okay. The connections from the USB TTL adapter to the Pi are:
GND (ground) > GPIO pin 06 (GND)
RXD > GPIO pin 08 (TXD)
TXD > GPIO pin 10 (RXD)
Note that in my picture the Pi Zero has four connections, and no micro-USB power cord. The CP2102 also has 3V3 and 5V outputs, so for the Zero I connected the 5V to GPIO pin 02 (5V) to provide power. It would probably be okay for a model A or B as well (although it would bypass the power protection), but a Pi2 or Pi3 should have its own power supply and only the 3 connections listed above.
For a serial terminal under Linux I install screen and open the serial terminal with sudo screen /dev/ttyUSB0 115200. Under Windows you can use PuTTY with Serial as the connection type, the COM port number under Serial line, and 115200 as the speed (check the port number in Device Manager). With Windows 10 you can also use the Windows Subsystem for Linux (WSL), but you'll need the Fall Creators Update to use serial ports. The procedure is similar to Linux, but the COM port will be ttyS# (note the capital S), with # being the port number Windows 10 assigned to your adapter (if Device Manager shows COM4, you'll use sudo screen /dev/ttyS4 115200 to open the serial terminal). WSL is still beta, so PuTTY might be a little more reliable, but I have found that hitting enter a few times will often connect when the terminal window isn't showing any output.
Linux supports the CP2102 directly. Windows will need a driver: CP210x_Windows_Drivers.zip (not sure about Mac).
Addicted
Mon Nov 06, 2017 7:28 am
ok. But without doing that i can't connect to wifi.
& your tutorial & those steps, i already followed that & unable to connect to wifi. Thats why i created this thread in the 1st place.
I appreciate that you were trying to help. But You didn't read what i tried & what i want to do.
You were giving me a solution through using a USB to ttl serial connection when i was asking to access pi ssh through wifi.
Mon Nov 06, 2017 7:55 am
Ignore the USB serial connection thing. 99.9% of Pi users won't need or want such a device. I don't know why HawaiianPi is spamming the forum with this at the moment.
The rest of the information about using wpa_supplicant.conf is valid though.
ShiftPlusOne
Mon Nov 06, 2017 7:58 am
If you can get your pi in the state where your wpa_supplicant.conf is valid but you can't connect with an empty interfaces file, please post the output of 'sudo journalctl'. It should tell you exactly why.
HawaiianPi
Mon Nov 06, 2017 7:09 pm
Because it's an inexpensive tool that helps to troubleshoot problems like this (and others). Seriously, it's 2 bucks, and it can be very helpful, so why not recommend it?
mikew
Wed Nov 29, 2017 10:01 am
FIXED IP ADDRESS FOR ETHERNET AND WIFI DONGLE ON RASPBERRY PI 2
I followed very many false leads trying to get wifi with fixed ip address to work
on a nov 2017 install of NOOBS_v2_4_4 on a pi-2 with Raspi wifi dongle.
On a clean new install, ONLY modify these 2 files:
to look like:
update_config=1
country=YR #your 2 letter code
network={
ssid="your wifi SSID"
psk="your wifi pass"
key_mgmt=WPA-PSK
/etc/dhcpcd.conf
uncomment the lines as shown below and put in the required ip address settings:
save the file and reboot.
(I used 192.168.1.40 for eth0 and 192.168.1.20 for wlan0)
# Example static IP configuration:
interface eth0
static ip_address=192.168.1.40/24
static ip6_address=fd51:42f8:yyyy:xxxx::ff/64
static routers=192.168.1.1
static domain_name_servers=192.168.1.1 8.8.8.8 fd51:42f8:caae:d92e::1
interface wlan0
static ip_address=192.168.1.20/24
#static ip6_address=fd51:42f8:xxxx:yyyy::ff/64
# It is possible to fall back to a static IP if DHCP fails:
# define static profile
#profile static_eth0
#static ip_address=192.168.1.20/24
#static routers=192.168.1.1
#static domain_name_servers=192.168.1.1
# fallback to static profile on eth0
#interface eth0
#fallback static_eth0
timdonovan
Fri Dec 22, 2017 11:12 am
Sigh. After 2 hours of messing around, I find that wpa_supplicant.conf headlessly is totally broken in Stretch (or at least, the previous wpa_supplicant is completely incompatible with previous ones). Why?!!?
What fixed it for me was one of the following (taken from various threads and google searches):
Including this at the top:
country=GB
update_config=1
Using wpa_passphrase on another pi to generate a network {} config, with a hashed password (I think you can no longer just do psk="yourpassword" in wpa_supplicant ).
Including a second dummy network such as:
network={
ssid="any_old_fake_ssid"
scan_ssid=1
psk="fakefake"
key_mgmt=WPA-PSK
Not sure why something that's been working fine for years had to then be broken and messed around with in Stretch.
SurferTim
Fri Dec 22, 2017 12:34 pm
Headless wifi start is not broken in Stretch 2017-09-07. I haven't tested 2017-11-29 yet. I'll get to that soon. I've had a lot of other network checking with the new version. Are you using the full version or lite?
You must have this in your wpa_supplicant.conf file. Change the two letter country code to yours.
country=GB
update_config=1
network={
psk="fakefake"
Edit: Just tested 2017-11-29 Lite headless boot using a RPi Zero W. Worked fine as I described. I just SSH connected to it.
CraigT
Sat Jan 13, 2018 11:09 pm
Kind of re-iterating SurferTim.
I just had a similar problem getting my Wi-Fi to work on a completely fresh new Raspbian Stretch Lite install on a Pi Zero W.
Cutting a long story short, I believe the problem was with the way I had modified the wpa_supplicant.conf file.
I replaced my modified file with the original file (always good to backup a file before modifying it) and then started again, this time making less modifications (and no tabs), rebooted and it worked! Yay!
Note. In the working file, I only added the ssid and psk lines under my network entry.
I believe the problem could have been because I had used tabs when modifying the file in nano (I tried to remove them all but that didn't seem to fix things) OR because I tried to add network entries for 3 wireless networks (I am not sure whether multiple networks with no preference was an issue or maybe there was a typo in my config - made more likely by having three entries).
If I have a bit more time I may investigate more with the retained incorrect file.
Hope this helps someone else.
Craig
mikerr
Sun Jan 14, 2018 10:34 am
Stretch now requires the ctrl_interface line, whereas Jessie allowed you to omit it - see my post above.
HawaiianPi
Sun Jan 14, 2018 12:29 pm
Networking works as advertised if you set up your SD card correctly. See my previous post in this thread.
viewtopic.php?p=1231189#p1231189
I have used that procedure many times on different Pi models and it works with the last version of Raspbian Jessie (early versions had some bugs), and all versions of Stretch.
psyke83
Sun Feb 04, 2018 11:09 am
Hi folks,
I would suggest that all prior advice in this thread is disregarded, and the following is noted:
* When booting with an unconfigured wpa_supplicant.conf, if you add your network configuration and attempt to bring up the interface, the dhcpcd hooks for wlan0 will not trigger correctly. I'm not certain why this happens, but the following output can be seen directly after booting without wpa_supplicant.conf properly configured:
$ systemctl status dhcpcd | grep Warn
Warning: dhcpcd.service changed on disk. Run 'systemctl daemon-reload' to reload units.
To fix, you can either do the following before attempting to bring up wlan0:
sudo systemctl daemon-reload # not strictly necessary
sudo systemctl restart dhcpcd
Or simply reboot, because...
* When booting with a configured wpa_supplicant.conf, dhcpcd will trigger correctly on wlan0 up/down events, even though systemctl still warns about the service being changed on disk.
This also explains why a poster insisted that the method of installing a preconfigured /boot/wpa_supplicant.conf worked. In reality, all that matters is that a configured wpa_supplicant.conf in /etc/wpa_supplicant is present during boot.
liamkennedy
Contact: Website Facebook Twitter
Tue Mar 20, 2018 11:59 pm
UPDATE: SOLVED. on the 3+ only YOU MUST configure the country= setting
As per the release notes for the 2018-03-13 image states:
2018-03-13:
* Raspberry Pi 3 B+ support
* WiFi is disabled until wireless regulatory domain is set (Pi 3 B+ only)
- The domain can be done through 'Raspberry Pi Configuration' (rc_gui),
'raspi-config' or by setting 'country=' to an appropriate ISO 3166
alpha2 country code in /etc/wpa_supplicant/wpa_supplicant.conf.
* Default wireless regulatory domain is now unset
Raspberry Pi 3B+ (YAY!) with the LATEST stretch-lite image (2018-03-13 - 4.9) and having a similar issue regarding the WiFi interface is initially unavailable. NOTE: the issue below is ONLY happening on the 3+ - if I test this on a Model 2 B+ or 3 the wifi works just fine on boot with the slightly modified wpa_supplicant.conf file
Here is my step-by-step to reproduce the issue
With fresh - unmodified version of Stretch Lite. Only thing added is ssh file to the /boot partition to allow access via ssh
After first boot
ifconfig doesn't display the wlan0 interface
sudo journalctl has this message
dhcpcd[355]: wlan0: if_up: Operation not possible due to RF-kill
/etc/wpa_supplicant/wpa_supplicant.conf is configured with just TWO lines (no country identifier)
update_config=1
I edit /etc/wpa_supplicant/wpa_supplicant.conf to have some bogus wifi network={...} block in there
update_config=1
network={
    ssid="nothing"
    psk="notreally"
As per psyke83 I issued these commands
I want to see if the wpa commandline interface works to show 5Ghz as well as 2/4Ghz networks so I issue
sudo wpa_cli scan
sudo wpa_cli scan_results
But that has ZERO results - sort of expected because ifconfig is still showing NO wlan0 interface
So I issue this command
sudo rfkill unblock 0
ifconfig command now shows wlan0 - so I then repeat the wpa_cli commands above
And it all works!
BUT.. when I reboot the interface is STILL disabled (that message from journalctl is still there).
I have to issue the sudo rfkill unblock 0 command to get the wifi working.
EDIT: I am now getting inconsistent results with the reboot process. I now find that I SOMETIMES have to ALSO issue the sudo systemctl restart dhcpcd command after the rfkill unblock after reboot.
So.. anyone know what is happening - and especially how we can have the wlan0 interface WORKING without having to issue the rfkill unblock command?
Thanks!
p.s. I've checked out several threads about the rfkill issue here.. but this thread seems to be the MOST recent about the general issue with wifi on stretch-lite.
UPDATE: This appears to be an issue ONLY with the new Raspberry Pi3+ - if I put the SAME card in to any older Pi - everything works without messing with the rfkill unblock command referenced above
ShiftPlusOne
Wed Mar 21, 2018 6:14 am
No need to overcomplicate it.
Just insert country=GB (or your appropriate country code) into your wpa_supplicant.conf.
If you place it on the boot partition before booting, you won't have to run rfkill unblock.
If you've already booted and then manually edited wpa_supplicant.conf, you'll need to run rfkill unblock.
Reason: spelling
liamkennedy
Wed Mar 21, 2018 3:14 pm
No need to overomplicate it.
Yup. I updated my COMPLICATED post BEFORE your reply. SEE the first line of my reply says exactly what is needed.
Maybe I should delete my extensive post to help save others being sidetracked by the record of my journey to enlightenment.
HawaiianPi
Wed Mar 21, 2018 7:25 pm
I would suggest this post be disregarded...
Which is what I said to do back in November of last year when I first replied to this thread.
  • To connect to a wireless network, create another file on the FAT32 partition called wpa_supplicant.conf which has the following inside:
    update_config=1
    country=US
    network={
    	key_mgmt=WPA-PSK
I don't know why people are always trying to cut corners with the wpa_supplicant.conf file. If you use a properly configured wpa_supplicant.conf, it just works. The procedure I outlined in my reply back in November works on the new 3B+, it works on the Pi Zero W and 3B, and it works on all other models with a Raspbian compatible USB WiFi dongle.
