nesswaw
[SOLEVED] Create a system iso?
Fri Nov 03, 2017 9:37 am
I have a raspberry with Raspbian.
I added/configured it, with scripts and packages installed and various configurations
I need to deploy this Bone with the config on several other Raspberry, how do I do it?
I was thinking about making an ISO of the current SD card and burning it to other SD cards?
How to do this?
Thank you in advance
B.Goode
Re: Create a system iso?
Fri Nov 03, 2017 9:55 am
Since you are using Raspbian, investigate the PiClone ( SD Card Copier) utility that is installed by default with recent versions of Raspbian.
(Some might want to insist that an 'iso' is an image of a CD and thus not appropriate for your purposes. I won't insist on such pedantry.)
dd and Win32DiskImager are alternatives.
nesswaw
Fri Nov 03, 2017 2:18 pm
yeah, it's works with Win32DiskImager :)
Problem solved! :)
Return to “Advanced users”
