CapnWinky07
aplay
Thu Oct 26, 2017 5:42 pm
Simple question that I hope has a simple answer. I have a Raspberry Pi 3. Fresh install of N00bs/Raspbian as of 1 hour ago. When I go to run 'aplay -i' it doesn't report anything back. It's like it's thinking but essentially I just have to x out of it to return back to anything. Why would it do that? Thanks in advance
Douglas6
Re: aplay
Thu Oct 26, 2017 6:59 pm
That's normal. You haven't told it to play anything, so it doesn't. What were you expecting?
DirkS
Re: aplay
Thu Oct 26, 2017 7:11 pm
Or did you actually try to get a list of devices?
For that the parameter is l (for list) not i (for interactive)
Douglas6
Re: aplay
Thu Oct 26, 2017 9:16 pm
And that's a lower-case 'L' (for list), not an upper-case 'i'.
CapnWinky07
Re: aplay
Fri Oct 27, 2017 3:38 pm
Thanks again. I tried out a new SD card and it seems to be resolved as well as some other issues!
Douglas6
Re: aplay
Fri Oct 27, 2017 3:47 pm
Using the proper command probably didn't hurt either.
