thunderknight99
Help: Best alternative to default Raspbian Stretch Repositories and how to change it
Wed Oct 25, 2017 5:40 am
I have been unable to even use sudo apt-get upgrade without having few connection fails which altogether breaks the package installation. I have checked my internet and it has no problem, I am able to ping mirrordirector.raspbian.org without any packet loss. Tried changing the nameserver to 8.8.8.8 on both the router and the RPi3 (/etc/resolv.conf) but still every installation of package via 'sudo apt-get install' has 5-6 connection fails out of 50-60 'Get. This is the link to that issue I have posted on forum here and on stackexchange - https://raspberrypi.stackexchange.com/q ... g-packages.
So, is there any reliable alternative to the default repositories of Raspbian Stretch? If there are, how do I change the repositories correctly? Last time I tried, I had to reinstall the entire Raspbian Stretch again (I am a noob with linux) because it said something like Release file was missing.
Any help is greatly appreciated!
KLL
Re: Help: Best alternative to default Raspbian Stretch Repositories and how to change it
Wed Oct 25, 2017 5:55 am
you should do
sudo apt-get update
sudo apt-get upgarde
(or)
sudo apt-get dist-upgarde
if it fails wait 30min and try again! until ok.
i have bad internet times here too, but i see no reason to change anything on the OS!
not very sure about this but i just recommend not to try any installs... while above steps not finished successfully
thunderknight99
Wed Oct 25, 2017 6:05 am
you should do
sudo apt-get update
(or)
I have trying this for over a week, and yesterday I changed repository to that of Raspbian Jessie and the sudo apt-get update && sudo apt-get upgrade worked without any problem. The packages are simply not getting downloaded without at least 1 or 2 connection fails in most cases for Raspbian Stretch.
Any leads?
ShiftPlusOne
Wed Oct 25, 2017 6:15 am
Which repo are you seeing the issues on? raspberrypi.org, raspbian.org or both?
KLL
Wed Oct 25, 2017 6:17 am
hm, i can not see that updates on STRETCH would have MORE internet connection problems ( from here )
but if you had a JESSIE system and upgarded to STRETCH you should not try to switch back????
pls download and burn a new setup https://downloads.raspberrypi.org/raspbian_latest
and do update on that.
thunderknight99
Wed Oct 25, 2017 6:24 am
I am currently doing sudo apt-get upgrade and archive.raspberrypi.org is getting some connection fails (so far 2 connections failed out of 73) and yesterday it was mirrordirector.raspbian.org that had connection fails (not too many but few like 5 or 6 out of 70) but anyway it breaks the installation.
thunderknight99
Wed Oct 25, 2017 6:26 am
I have the latest Raspbian Stretch (from the downloads section of raspberrypi.org). I never had Jessie installed as I bought my RPi3 after the release of Raspbian Stretch.
ShiftPlusOne
Wed Oct 25, 2017 6:34 am
Are you able to ping and traceroute the IP it resolves?
thunderknight99
Wed Oct 25, 2017 6:47 am
This is the log of my last sudo apt-get upgrade and similar connection fails are happening on almost every package installation (and not just random, for example, the chromium-mod package has failed every single time I have run sudo apt-get upgrade on 3 different fresh installs of Raspbian Stretch.
[email protected]:~ $ sudo apt-get update
Hit:1 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Reading package lists... Done
[email protected]:~ $ sudo apt-get upgrade
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
  gstreamer1.0-omx
The following packages will be upgraded:
  apt apt-transport-https apt-utils bind9-host bluez curl dbus dbus-user-session dbus-x11 desktop-base
  dhcpcd5 gir1.2-gdkpixbuf-2.0 git git-man gnupg gnupg-agent gpgv libapt-inst2.0 libapt-pkg5.0 libatspi2.0-0
  libavcodec57 libavfilter6 libavformat57 libavresample3 libavutil55 libbind9-140 libbluetooth3 libcurl3
  libcurl3-gnutls libdbus-1-3 libdns-export162 libdns162 libfm-data libfm-extra4 libfm-gtk-data libfm-gtk4
  libfm-modules libfm4 libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-common libgnutls30 libgssapi-krb5-2 libidn2-0
  libisc-export160 libisc160 libisccc140 libisccfg140 libjavascriptcoregtk-4.0-18 libk5crypto3 libkrb5-3
  libkrb5support0 libldap-2.4-2 libldap-common liblwres141 libncurses5 libncursesw5 libnss3 libpostproc54
  libruby2.3 libsmbclient libswresample2 libswscale4 libtinfo5 libwbclient0 libwebkit2gtk-4.0-37 libxfont2
  linux-libc-dev lxpanel lxpanel-data lxplug-bluetooth lxplug-ejecter lxplug-network lxplug-volume
  ncurses-base ncurses-term pcmanfm pigpio python-jwt python-pigpio python-pip python-pip-whl python3-jwt
  python3-pigpio python3-pip raspi-config raspi-copies-and-fills realvnc-vnc-server realvnc-vnc-viewer
  rpi-chromium-mods ruby2.3 samba-common samba-libs scratch2 vim-common vim-tiny wpasupplicant xkb-data
  xserver-common xserver-xorg-core xxd
100 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 146 MB of archives.
After this operation, 3,045 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://mirrordirector.raspbian.org/raspbian stretch/main armhf ncurses-base all 6.0+20161126-1+deb9u1 [238 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libapt-pkg5.0 armhf 1.4.8 [833 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libapt-inst2.0 armhf 1.4.8 [190 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian stretch/main armhf apt armhf 1.4.8 [1,190 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian stretch/main armhf apt-utils armhf 1.4.8 [392 kB]
Get:6 http://mirrordirector.raspbian.org/raspbian stretch/main armhf gpgv armhf 2.1.18-8~deb9u1 [440 kB]
Err:7 http://archive.raspberrypi.org/debian stretch/ui armhf rpi-chromium-mods armhf 20171017
  Connection failed [IP: 93.93.130.104 80]
Get:8 http://archive.raspberrypi.org/debian stretch/main armhf bluez armhf 5.43-2+rpt1+deb9u1 [722 kB]
Get:9 http://mirrordirector.raspbian.org/raspbian stretch/main armhf desktop-base all 9.0.2+deb9u1 [3,507 kB]
Get:10 http://archive.raspberrypi.org/debian stretch/main armhf dhcpcd5 armhf 1:6.11.5-1+rpt2 [135 kB]
Get:11 http://mirrordirector.raspbian.org/raspbian stretch/main armhf git-man all 1:2.11.0-3+deb9u2 [1,432 kB]
Err:12 http://archive.raspberrypi.org/debian stretch/main armhf libbluetooth3 armhf 5.43-2+rpt1+deb9u1
  Connection failed [IP: 93.93.130.214 80]
Get:13 http://archive.raspberrypi.org/debian stretch/ui armhf libfm-data all 1.2.5-1+rpi2 [234 kB]
Get:14 http://archive.raspberrypi.org/debian stretch/ui armhf libfm-extra4 armhf 1.2.5-1+rpi2 [29.2 kB]
Get:15 http://archive.raspberrypi.org/debian stretch/ui armhf libfm-gtk-data all 1.2.5-1+rpi2 [33.9 kB]
Get:16 http://archive.raspberrypi.org/debian stretch/ui armhf libfm-gtk4 armhf 1.2.5-1+rpi2 [133 kB]
Get:17 http://archive.raspberrypi.org/debian stretch/ui armhf libfm4 armhf 1.2.5-1+rpi2 [101 kB]
Get:18 http://archive.raspberrypi.org/debian stretch/ui armhf libfm-modules armhf 1.2.5-1+rpi2 [45.8 kB]
Get:19 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libgnutls30 armhf 3.5.8-5+deb9u3 [823 kB]
Get:20 http://archive.raspberrypi.org/debian stretch/ui armhf lxpanel armhf 0.9.3-1+rpi4 [187 kB]
Get:21 http://archive.raspberrypi.org/debian stretch/ui armhf lxpanel-data all 0.9.3-1+rpi4 [1,050 kB]
Get:22 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libgssapi-krb5-2 armhf 1.15-1+deb9u1 [131 kB]
Get:23 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libkrb5-3 armhf 1.15-1+deb9u1 [262 kB]
Get:24 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libkrb5support0 armhf 1.15-1+deb9u1 [58.1 kB]
Get:25 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libk5crypto3 armhf 1.15-1+deb9u1 [115 kB]
Get:26 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libidn2-0 armhf 0.16-1+deb9u1 [59.5 kB]
Get:27 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libldap-2.4-2 armhf 2.4.44+dfsg-5+deb9u1 [195 kB]
Get:28 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libldap-common all 2.4.44+dfsg-5+deb9u1 [85.4 kB]
Get:29 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libcurl3-gnutls armhf 7.52.1-5+deb9u1 [259 kB]
Get:30 http://mirrordirector.raspbian.org/raspbian stretch/main armhf git armhf 1:2.11.0-3+deb9u2 [3,380 kB]
Get:31 http://archive.raspberrypi.org/debian stretch/ui armhf lxplug-bluetooth armhf 0.4 [15.9 kB]
Get:32 http://archive.raspberrypi.org/debian stretch/ui armhf lxplug-ejecter armhf 0.3 [9,076 B]
Get:33 http://archive.raspberrypi.org/debian stretch/ui armhf lxplug-network armhf 0.5 [28.4 kB]
Get:34 http://archive.raspberrypi.org/debian stretch/ui armhf lxplug-volume armhf 0.7 [15.5 kB]
Get:35 http://archive.raspberrypi.org/debian stretch/ui armhf pcmanfm armhf 1.2.5-3+rpi2 [270 kB]
Get:36 http://archive.raspberrypi.org/debian stretch/main armhf pigpio armhf 1.64-1 [193 kB]
Get:37 http://archive.raspberrypi.org/debian stretch/main armhf python-pigpio all 1.64-1 [33.5 kB]
Get:38 http://archive.raspberrypi.org/debian stretch/main armhf python3-pip all 9.0.1-2+rpt1 [142 kB]
Get:39 http://archive.raspberrypi.org/debian stretch/main armhf python-pip all 9.0.1-2+rpt1 [179 kB]
Get:40 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libwbclient0 armhf 2:4.5.12+dfsg-2 [120 kB]
Get:41 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libsmbclient armhf 2:4.5.12+dfsg-2 [143 kB]
Get:42 http://archive.raspberrypi.org/debian stretch/main armhf python-pip-whl all 9.0.1-2+rpt1 [1,399 kB]
Get:43 http://mirrordirector.raspbian.org/raspbian stretch/main armhf samba-libs armhf 2:4.5.12+dfsg-2 [4,383 kB]
Get:44 http://archive.raspberrypi.org/debian stretch/main armhf python3-pigpio all 1.64-1 [33.5 kB]
Get:45 http://archive.raspberrypi.org/debian stretch/main armhf raspi-copies-and-fills armhf 0.6 [7,226 B]
Get:46 http://mirrordirector.raspbian.org/raspbian stretch/main armhf samba-common all 2:4.5.12+dfsg-2 [172 kB]
Get:47 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libncurses5 armhf 6.0+20161126-1+deb9u1 [73.9 kB]
Get:48 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libtinfo5 armhf 6.0+20161126-1+deb9u1 [288 kB]
Get:49 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libncursesw5 armhf 6.0+20161126-1+deb9u1 [93.3 kB]
Get:50 http://mirrordirector.raspbian.org/raspbian stretch/main armhf gnupg-agent armhf 2.1.18-8~deb9u1 [498 kB]
Err:51 http://archive.raspberrypi.org/debian stretch/main armhf realvnc-vnc-server armhf 6.2.0.29523
  Connection failed [IP: 93.93.128.133 80]
Get:52 http://mirrordirector.raspbian.org/raspbian stretch/main armhf gnupg armhf 2.1.18-8~deb9u1 [1,019 kB]
Get:53 http://archive.raspberrypi.org/debian stretch/main armhf realvnc-vnc-viewer armhf 6.17.731.29523 [2,112 kB]
Get:54 http://mirrordirector.raspbian.org/raspbian stretch/main armhf vim-tiny armhf 2:8.0.0197-4+deb9u1 [339 kB]
Get:55 http://mirrordirector.raspbian.org/raspbian stretch/main armhf xxd armhf 2:8.0.0197-4+deb9u1 [131 kB]
Get:56 http://mirrordirector.raspbian.org/raspbian stretch/main armhf vim-common all 2:8.0.0197-4+deb9u1 [159 kB]
Get:57 http://mirrordirector.raspbian.org/raspbian stretch/main armhf bind9-host armhf 1:9.10.3.dfsg.P4-12.3+deb9u3 [230 kB]
Get:58 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libisc160 armhf 1:9.10.3.dfsg.P4-12.3+deb9u3 [366 kB]
Get:59 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libdns162 armhf 1:9.10.3.dfsg.P4-12.3+deb9u3 [952 kB]
Get:60 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libisccc140 armhf 1:9.10.3.dfsg.P4-12.3+deb9u3 [196 kB]
Get:61 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libisccfg140 armhf 1:9.10.3.dfsg.P4-12.3+deb9u3 [215 kB]
Get:62 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libbind9-140 armhf 1:9.10.3.dfsg.P4-12.3+deb9u3 [204 kB]
Get:63 http://archive.raspberrypi.org/debian stretch/main armhf xserver-common all 2:1.19.2-1+rpt1+deb9u2 [2,059 kB]
Get:64 http://mirrordirector.raspbian.org/raspbian stretch/main armhf liblwres141 armhf 1:9.10.3.dfsg.P4-12.3+deb9u3 [210 kB]
Get:65 http://mirrordirector.raspbian.org/raspbian stretch/main armhf dbus-user-session all 1.10.22-0+deb9u1 [76.6 kB]
Get:66 http://mirrordirector.raspbian.org/raspbian stretch/main armhf dbus-x11 armhf 1.10.22-0+deb9u1 [87.8 kB]
Get:67 http://mirrordirector.raspbian.org/raspbian stretch/main armhf dbus armhf 1.10.22-0+deb9u1 [189 kB]
Get:68 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libdbus-1-3 armhf 1.10.22-0+deb9u1 [173 kB]
Get:69 http://mirrordirector.raspbian.org/raspbian stretch/main armhf ncurses-term all 6.0+20161126-1+deb9u1 [469 kB]
Get:70 http://mirrordirector.raspbian.org/raspbian stretch/main armhf apt-transport-https armhf 1.4.8 [165 kB]
Get:71 http://mirrordirector.raspbian.org/raspbian stretch/main armhf curl armhf 7.52.1-5+deb9u1 [220 kB]
Get:72 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libcurl3 armhf 7.52.1-5+deb9u1 [261 kB]
Get:73 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libgdk-pixbuf2.0-0 armhf 2.36.5-2+deb9u1 [152 kB]
Get:74 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libgdk-pixbuf2.0-common all 2.36.5-2+deb9u1 [310 kB]
Get:75 http://archive.raspberrypi.org/debian stretch/main armhf xserver-xorg-core armhf 2:1.19.2-1+rpt1+deb9u2 [3,120 kB]
Get:76 http://mirrordirector.raspbian.org/raspbian stretch/main armhf gir1.2-gdkpixbuf-2.0 armhf 2.36.5-2+deb9u1 [15.3 kB]
Get:77 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libatspi2.0-0 armhf 2.22.0-6+deb9u1 [52.1 kB]
Get:78 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libavutil55 armhf 7:3.2.8-1~deb9u1 [232 kB]
Get:79 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libswresample2 armhf 7:3.2.8-1~deb9u1 [88.2 kB]
Get:80 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libavcodec57 armhf 7:3.2.8-1~deb9u1 [4,152 kB]
Get:81 http://archive.raspberrypi.org/debian stretch/main armhf raspi-config all 20170926 [18.8 kB]
Get:82 http://archive.raspberrypi.org/debian stretch/main armhf scratch2 armhf 0.17 [67.8 MB]
Get:83 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libavformat57 armhf 7:3.2.8-1~deb9u1 [867 kB]
Get:84 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libavresample3 armhf 7:3.2.8-1~deb9u1 [80.3 kB]
Get:85 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libpostproc54 armhf 7:3.2.8-1~deb9u1 [72.8 kB]
Get:86 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libswscale4 armhf 7:3.2.8-1~deb9u1 [161 kB]
Get:87 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libavfilter6 armhf 7:3.2.8-1~deb9u1 [688 kB]
Get:88 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libisc-export160 armhf 1:9.10.3.dfsg.P4-12.3+deb9u3 [316 kB]
Get:89 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libdns-export162 armhf 1:9.10.3.dfsg.P4-12.3+deb9u3 [764 kB]
Get:90 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libwebkit2gtk-4.0-37 armhf 2.16.6-0+deb9u1+rpi1 [9,127 kB]
Get:91 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libjavascriptcoregtk-4.0-18 armhf 2.16.6-0+deb9u1+rpi1 [1,726 kB]
Get:92 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libnss3 armhf 2:3.26.2-1.1+deb9u1 [946 kB]
Get:93 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libruby2.3 armhf 2.3.3-1+deb9u1+rpi1 [2,865 kB]
Get:94 http://mirrordirector.raspbian.org/raspbian stretch/main armhf libxfont2 armhf 1:2.0.1-3+deb9u1 [117 kB]
Get:95 http://mirrordirector.raspbian.org/raspbian stretch/main armhf linux-libc-dev armhf 4.9.51-1+rpi3 [1,261 kB]
Get:96 http://mirrordirector.raspbian.org/raspbian stretch/main armhf python-jwt all 1.4.2-1+deb9u1 [15.3 kB]
Get:97 http://mirrordirector.raspbian.org/raspbian stretch/main armhf python3-jwt all 1.4.2-1+deb9u1 [15.3 kB]
Get:98 http://mirrordirector.raspbian.org/raspbian stretch/main armhf ruby2.3 armhf 2.3.3-1+deb9u1+rpi1 [187 kB]
Get:99 http://mirrordirector.raspbian.org/raspbian stretch/main armhf wpasupplicant armhf 2:2.4-1+deb9u1 [793 kB]
Get:100 http://mirrordirector.raspbian.org/raspbian stretch/main armhf xkb-data all 2.19-1+deb9u1 [650 kB]
Fetched 131 MB in 18min 9s (120 kB/s)
E: Failed to fetch http://archive.raspberrypi.org/debian/pool/ui/r/rpi-chromium-mods/rpi-chromium-mods_20171017_armhf.deb  Connection failed [IP: 93.93.130.104 80]
E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/b/bluez/libbluetooth3_5.43-2+rpt1+deb9u1_armhf.deb  Connection failed [IP: 93.93.130.214 80]
E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/r/realvnc-vnc/realvnc-vnc-server_6.2.0.29523_armhf.deb  Connection failed [IP: 93.93.128.133 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
and here is the result of Ping and Traceroute
[email protected]:~ $ ping archive.raspberrypi.org
PING lb.raspberrypi.org (93.93.135.188) 56(84) bytes of data.
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=1 ttl=51 time=257 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=2 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=3 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=4 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=5 ttl=51 time=263 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=6 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=7 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=8 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=9 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=10 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=11 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=12 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=13 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=14 ttl=51 time=262 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=15 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=16 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=17 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=18 ttl=51 time=271 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=19 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=20 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=21 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=22 ttl=51 time=258 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=23 ttl=51 time=262 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=24 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=25 ttl=51 time=261 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=26 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=27 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=28 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=29 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=30 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=31 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=32 ttl=51 time=261 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=33 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=34 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=35 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=36 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=37 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=38 ttl=51 time=261 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=39 ttl=51 time=261 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=40 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=41 ttl=51 time=262 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=42 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=43 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=44 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=45 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=46 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=47 ttl=51 time=266 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=48 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=49 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=50 ttl=51 time=294 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=51 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=52 ttl=51 time=261 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=53 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=54 ttl=51 time=261 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=55 ttl=51 time=261 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=56 ttl=51 time=270 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=57 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=58 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=59 ttl=51 time=261 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=60 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=61 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=62 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=63 ttl=51 time=265 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=64 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=65 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=66 ttl=51 time=261 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=67 ttl=51 time=261 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=68 ttl=51 time=258 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=69 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=70 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=71 ttl=51 time=269 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=72 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=73 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=74 ttl=51 time=262 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=75 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=76 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=77 ttl=51 time=258 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=78 ttl=51 time=261 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=79 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=80 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=81 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=82 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=83 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=84 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=85 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=86 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=87 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=88 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=89 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=90 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=91 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=92 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=93 ttl=51 time=266 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=94 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=95 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=96 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=97 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=98 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=99 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=100 ttl=51 time=259 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=101 ttl=51 time=260 ms
64 bytes from 93.93.135.188 (93.93.135.188): icmp_seq=102 ttl=51 time=260 ms
^C
--- lb.raspberrypi.org ping statistics ---
102 packets transmitted, 102 received, 0% packet loss, time 101121ms
rtt min/avg/max/mdev = 257.765/261.143/294.780/4.049 ms
[email protected]:~ $ ping mirrordirector.raspbian.org
PING mirrordirector.raspbian.org (93.93.128.193) 56(84) bytes of data.
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=1 ttl=48 time=293 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=2 ttl=48 time=300 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=3 ttl=48 time=297 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=4 ttl=48 time=287 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=5 ttl=48 time=288 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=6 ttl=48 time=289 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=7 ttl=48 time=288 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=8 ttl=48 time=287 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=9 ttl=48 time=287 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=10 ttl=48 time=289 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=11 ttl=48 time=289 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=12 ttl=48 time=288 ms
^C
--- mirrordirector.raspbian.org ping statistics ---
12 packets transmitted, 12 received, 0% packet loss, time 11001ms
rtt min/avg/max/mdev = 287.602/290.711/300.594/4.100 ms
[email protected]:~ $ traceroute archive.raspberrypi.org
traceroute to archive.raspberrypi.org (93.93.128.133), 30 hops max, 60 byte packets
 1  192.168.1.1 (192.168.1.1)  2.243 ms  5.767 ms  6.301 ms
 2  * * *
 3  218.248.175.206 (218.248.175.206)  65.462 ms  65.609 ms  65.574 ms
 4  * 218.248.235.161 (218.248.235.161)  69.673 ms  70.006 ms
 5  * * 218.248.235.162 (218.248.235.162)  71.856 ms
 6  115.110.161.209.static.vsnl.net.in (115.110.161.209)  62.124 ms  28.547 ms  31.001 ms
 7  172.31.167.49 (172.31.167.49)  45.912 ms  48.508 ms  51.223 ms
 8  172.31.29.245 (172.31.29.245)  74.948 ms  78.774 ms  80.264 ms
 9  ix-ae-0-4.tcore1.MLV-Mumbai.as6453.net (180.87.38.5)  292.836 ms  293.049 ms  270.319 ms
10  * * *
11  * * *
12  if-ae-11-2.tcore1.PVU-Paris.as6453.net (80.231.153.49)  282.845 ms  279.644 ms  282.149 ms
13  * * *
14  * * *
15  * * *
16  * * *
17  * * *
18  * * *
19  * * *
20  * * *
21  * * *
22  * * *
23  * * *
24  * * *
25  * * *
26  * * *
27  * * *
28  * * *
29  * * *
30  * * *
[email protected]:~ $ traceroute mirrordirector.raspbian.org
traceroute to mirrordirector.raspbian.org (93.93.128.193), 30 hops max, 60 byte packets
 1  192.168.1.1 (192.168.1.1)  6.585 ms  7.051 ms  7.464 ms
 2  * * *
 3  * * *
 4  * 218.248.235.161 (218.248.235.161)  63.304 ms  77.537 ms
 5  218.248.235.162 (218.248.235.162)  78.562 ms  81.406 ms  72.295 ms
 6  115.110.161.209.static.vsnl.net.in (115.110.161.209)  74.307 ms  45.690 ms  45.592 ms
 7  172.31.167.49 (172.31.167.49)  58.802 ms  49.759 ms  63.652 ms
 8  172.31.29.245 (172.31.29.245)  77.378 ms  93.589 ms  94.006 ms
 9  ix-ae-0-4.tcore1.MLV-Mumbai.as6453.net (180.87.38.5)  306.653 ms  279.965 ms  282.688 ms
10  * * *
11  * * *
12  if-ae-11-2.tcore1.PVU-Paris.as6453.net (80.231.153.49)  276.986 ms  279.953 ms  278.979 ms
13  * * *
14  * * *
15  * * *
16  * * *
17  * * *
18  * * *
19  * * *
20  * * *
21  * * *
22  * * *
23  * * *
24  * * *
25  * * *
26  * * *
27  * * *
28  * * *
29  * * *
30  * * *
ShiftPlusOne
Wed Oct 25, 2017 6:53 am
Thanks. I'll pass the info on.
thunderknight99
Wed Oct 25, 2017 6:58 am
Thanks!
And here is the result of my last sudo apt-get upgrade --fix-missing
[email protected]:~ $ sudo apt-get upgrade --fix-missing
  gstreamer1.0-omx
Need to get 15.1 MB/146 MB of archives.
Err:1 http://archive.raspberrypi.org/debian stretch/ui armhf rpi-chromium-mods armhf 20171017
Err:2 http://archive.raspberrypi.org/debian stretch/main armhf libbluetooth3 armhf 5.43-2+rpt1+deb9u1
  Connection failed [IP: 93.93.128.211 80]
Err:3 http://archive.raspberrypi.org/debian stretch/main armhf realvnc-vnc-server armhf 6.2.0.29523
  Connection failed [IP: 93.93.130.39 80]
Reading changelogs... Done
Extracting templates from packages: 100%
Preconfiguring packages ...
(Reading database ... 108578 files and directories currently installed.)
Preparing to unpack .../ncurses-base_6.0+20161126-1+deb9u1_all.deb ...
Unpacking ncurses-base (6.0+20161126-1+deb9u1) over (6.0+20161126-1) ...
Setting up ncurses-base (6.0+20161126-1+deb9u1) ...
Preparing to unpack .../libapt-pkg5.0_1.4.8_armhf.deb ...
Unpacking libapt-pkg5.0:armhf (1.4.8) over (1.4.7) ...
Setting up libapt-pkg5.0:armhf (1.4.8) ...
Preparing to unpack .../libapt-inst2.0_1.4.8_armhf.deb ...
Unpacking libapt-inst2.0:armhf (1.4.8) over (1.4.7) ...
Preparing to unpack .../archives/apt_1.4.8_armhf.deb ...
Unpacking apt (1.4.8) over (1.4.7) ...
Setting up apt (1.4.8) ...
Preparing to unpack .../apt-utils_1.4.8_armhf.deb ...
Unpacking apt-utils (1.4.8) over (1.4.7) ...
Preparing to unpack .../gpgv_2.1.18-8~deb9u1_armhf.deb ...
Unpacking gpgv (2.1.18-8~deb9u1) over (2.1.18-6) ...
Setting up gpgv (2.1.18-8~deb9u1) ...
Preparing to unpack .../00-desktop-base_9.0.2+deb9u1_all.deb ...
Unpacking desktop-base (9.0.2+deb9u1) over (9.0.2) ...
Preparing to unpack .../01-git-man_1%3a2.11.0-3+deb9u2_all.deb ...
Unpacking git-man (1:2.11.0-3+deb9u2) over (1:2.11.0-3) ...
Preparing to unpack .../02-libgnutls30_3.5.8-5+deb9u3_armhf.deb ...
Unpacking libgnutls30:armhf (3.5.8-5+deb9u3) over (3.5.8-5+deb9u2) ...
Preparing to unpack .../03-libgssapi-krb5-2_1.15-1+deb9u1_armhf.deb ...
Unpacking libgssapi-krb5-2:armhf (1.15-1+deb9u1) over (1.15-1) ...
Preparing to unpack .../04-libkrb5-3_1.15-1+deb9u1_armhf.deb ...
Unpacking libkrb5-3:armhf (1.15-1+deb9u1) over (1.15-1) ...
Preparing to unpack .../05-libkrb5support0_1.15-1+deb9u1_armhf.deb ...
Unpacking libkrb5support0:armhf (1.15-1+deb9u1) over (1.15-1) ...
Preparing to unpack .../06-libk5crypto3_1.15-1+deb9u1_armhf.deb ...
Unpacking libk5crypto3:armhf (1.15-1+deb9u1) over (1.15-1) ...
Preparing to unpack .../07-libidn2-0_0.16-1+deb9u1_armhf.deb ...
Unpacking libidn2-0:armhf (0.16-1+deb9u1) over (0.16-1) ...
Preparing to unpack .../08-libldap-2.4-2_2.4.44+dfsg-5+deb9u1_armhf.deb ...
Unpacking libldap-2.4-2:armhf (2.4.44+dfsg-5+deb9u1) over (2.4.44+dfsg-5) ...
Preparing to unpack .../09-libldap-common_2.4.44+dfsg-5+deb9u1_all.deb ...
Unpacking libldap-common (2.4.44+dfsg-5+deb9u1) over (2.4.44+dfsg-5) ...
Preparing to unpack .../10-libcurl3-gnutls_7.52.1-5+deb9u1_armhf.deb ...
Unpacking libcurl3-gnutls:armhf (7.52.1-5+deb9u1) over (7.52.1-5) ...
Preparing to unpack .../11-git_1%3a2.11.0-3+deb9u2_armhf.deb ...
Unpacking git (1:2.11.0-3+deb9u2) over (1:2.11.0-3) ...
Preparing to unpack .../12-libwbclient0_2%3a4.5.12+dfsg-2_armhf.deb ...
Unpacking libwbclient0:armhf (2:4.5.12+dfsg-2) over (2:4.5.8+dfsg-2+deb9u1) ...
Preparing to unpack .../13-libsmbclient_2%3a4.5.12+dfsg-2_armhf.deb ...
Unpacking libsmbclient:armhf (2:4.5.12+dfsg-2) over (2:4.5.8+dfsg-2+deb9u1) ...
Preparing to unpack .../14-samba-libs_2%3a4.5.12+dfsg-2_armhf.deb ...
Unpacking samba-libs:armhf (2:4.5.12+dfsg-2) over (2:4.5.8+dfsg-2+deb9u1) ...
Preparing to unpack .../15-samba-common_2%3a4.5.12+dfsg-2_all.deb ...
Unpacking samba-common (2:4.5.12+dfsg-2) over (2:4.5.8+dfsg-2+deb9u1) ...
Preparing to unpack .../16-libncurses5_6.0+20161126-1+deb9u1_armhf.deb ...
Unpacking libncurses5:armhf (6.0+20161126-1+deb9u1) over (6.0+20161126-1) ...
Preparing to unpack .../17-libtinfo5_6.0+20161126-1+deb9u1_armhf.deb ...
Unpacking libtinfo5:armhf (6.0+20161126-1+deb9u1) over (6.0+20161126-1) ...
Setting up libtinfo5:armhf (6.0+20161126-1+deb9u1) ...
Preparing to unpack .../libncursesw5_6.0+20161126-1+deb9u1_armhf.deb ...
Unpacking libncursesw5:armhf (6.0+20161126-1+deb9u1) over (6.0+20161126-1) ...
Setting up libncursesw5:armhf (6.0+20161126-1+deb9u1) ...
Preparing to unpack .../gnupg-agent_2.1.18-8~deb9u1_armhf.deb ...
Unpacking gnupg-agent (2.1.18-8~deb9u1) over (2.1.18-6) ...
Setting up gnupg-agent (2.1.18-8~deb9u1) ...
Preparing to unpack .../gnupg_2.1.18-8~deb9u1_armhf.deb ...
Unpacking gnupg (2.1.18-8~deb9u1) over (2.1.18-6) ...
Setting up gnupg (2.1.18-8~deb9u1) ...
(Reading database ... 108577 files and directories currently installed.)
Preparing to unpack .../00-vim-tiny_2%3a8.0.0197-4+deb9u1_armhf.deb ...
Unpacking vim-tiny (2:8.0.0197-4+deb9u1) over (2:8.0.0197-4) ...
Preparing to unpack .../01-xxd_2%3a8.0.0197-4+deb9u1_armhf.deb ...
Unpacking xxd (2:8.0.0197-4+deb9u1) over (2:8.0.0197-4) ...
Preparing to unpack .../02-vim-common_2%3a8.0.0197-4+deb9u1_all.deb ...
Unpacking vim-common (2:8.0.0197-4+deb9u1) over (2:8.0.0197-4) ...
Preparing to unpack .../03-bind9-host_1%3a9.10.3.dfsg.P4-12.3+deb9u3_armhf.deb ...
Unpacking bind9-host (1:9.10.3.dfsg.P4-12.3+deb9u3) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../04-libisc160_1%3a9.10.3.dfsg.P4-12.3+deb9u3_armhf.deb ...
Unpacking libisc160:armhf (1:9.10.3.dfsg.P4-12.3+deb9u3) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../05-libdns162_1%3a9.10.3.dfsg.P4-12.3+deb9u3_armhf.deb ...
Unpacking libdns162:armhf (1:9.10.3.dfsg.P4-12.3+deb9u3) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../06-libisccc140_1%3a9.10.3.dfsg.P4-12.3+deb9u3_armhf.deb ...
Unpacking libisccc140:armhf (1:9.10.3.dfsg.P4-12.3+deb9u3) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../07-libisccfg140_1%3a9.10.3.dfsg.P4-12.3+deb9u3_armhf.deb ...
Unpacking libisccfg140:armhf (1:9.10.3.dfsg.P4-12.3+deb9u3) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../08-libbind9-140_1%3a9.10.3.dfsg.P4-12.3+deb9u3_armhf.deb ...
Unpacking libbind9-140:armhf (1:9.10.3.dfsg.P4-12.3+deb9u3) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../09-liblwres141_1%3a9.10.3.dfsg.P4-12.3+deb9u3_armhf.deb ...
Unpacking liblwres141:armhf (1:9.10.3.dfsg.P4-12.3+deb9u3) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../10-dbus-user-session_1.10.22-0+deb9u1_all.deb ...
Unpacking dbus-user-session (1.10.22-0+deb9u1) over (1.10.18-1) ...
Preparing to unpack .../11-dbus-x11_1.10.22-0+deb9u1_armhf.deb ...
Unpacking dbus-x11 (1.10.22-0+deb9u1) over (1.10.18-1) ...
Preparing to unpack .../12-dbus_1.10.22-0+deb9u1_armhf.deb ...
Unpacking dbus (1.10.22-0+deb9u1) over (1.10.18-1) ...
Preparing to unpack .../13-libdbus-1-3_1.10.22-0+deb9u1_armhf.deb ...
Unpacking libdbus-1-3:armhf (1.10.22-0+deb9u1) over (1.10.18-1) ...
Preparing to unpack .../14-ncurses-term_6.0+20161126-1+deb9u1_all.deb ...
Unpacking ncurses-term (6.0+20161126-1+deb9u1) over (6.0+20161126-1) ...
Preparing to unpack .../15-apt-transport-https_1.4.8_armhf.deb ...
Unpacking apt-transport-https (1.4.8) over (1.4.7) ...
Preparing to unpack .../16-bluez_5.43-2+rpt1+deb9u1_armhf.deb ...
Unpacking bluez (5.43-2+rpt1+deb9u1) over (5.43-2+rpi1) ...
Preparing to unpack .../17-curl_7.52.1-5+deb9u1_armhf.deb ...
Unpacking curl (7.52.1-5+deb9u1) over (7.52.1-5) ...
Preparing to unpack .../18-libcurl3_7.52.1-5+deb9u1_armhf.deb ...
Unpacking libcurl3:armhf (7.52.1-5+deb9u1) over (7.52.1-5) ...
Preparing to unpack .../19-dhcpcd5_1%3a6.11.5-1+rpt2_armhf.deb ...
Unpacking dhcpcd5 (1:6.11.5-1+rpt2) over (1:6.10.1-1+rpi3) ...
Preparing to unpack .../20-libgdk-pixbuf2.0-0_2.36.5-2+deb9u1_armhf.deb ...
Unpacking libgdk-pixbuf2.0-0:armhf (2.36.5-2+deb9u1) over (2.36.5-2) ...
Preparing to unpack .../21-libgdk-pixbuf2.0-common_2.36.5-2+deb9u1_all.deb ...
Unpacking libgdk-pixbuf2.0-common (2.36.5-2+deb9u1) over (2.36.5-2) ...
Preparing to unpack .../22-gir1.2-gdkpixbuf-2.0_2.36.5-2+deb9u1_armhf.deb ...
Unpacking gir1.2-gdkpixbuf-2.0:armhf (2.36.5-2+deb9u1) over (2.36.5-2) ...
Preparing to unpack .../23-libatspi2.0-0_2.22.0-6+deb9u1_armhf.deb ...
Unpacking libatspi2.0-0:armhf (2.22.0-6+deb9u1) over (2.22.0-6) ...
Preparing to unpack .../24-libavutil55_7%3a3.2.8-1~deb9u1_armhf.deb ...
Unpacking libavutil55:armhf (7:3.2.8-1~deb9u1) over (7:3.2.5-1) ...
Preparing to unpack .../25-libswresample2_7%3a3.2.8-1~deb9u1_armhf.deb ...
Unpacking libswresample2:armhf (7:3.2.8-1~deb9u1) over (7:3.2.5-1) ...
Preparing to unpack .../26-libavcodec57_7%3a3.2.8-1~deb9u1_armhf.deb ...
Unpacking libavcodec57:armhf (7:3.2.8-1~deb9u1) over (7:3.2.5-1) ...
Preparing to unpack .../27-libavformat57_7%3a3.2.8-1~deb9u1_armhf.deb ...
Unpacking libavformat57:armhf (7:3.2.8-1~deb9u1) over (7:3.2.5-1) ...
Preparing to unpack .../28-libavresample3_7%3a3.2.8-1~deb9u1_armhf.deb ...
Unpacking libavresample3:armhf (7:3.2.8-1~deb9u1) over (7:3.2.5-1) ...
Preparing to unpack .../29-libpostproc54_7%3a3.2.8-1~deb9u1_armhf.deb ...
Unpacking libpostproc54:armhf (7:3.2.8-1~deb9u1) over (7:3.2.5-1) ...
Preparing to unpack .../30-libswscale4_7%3a3.2.8-1~deb9u1_armhf.deb ...
Unpacking libswscale4:armhf (7:3.2.8-1~deb9u1) over (7:3.2.5-1) ...
Preparing to unpack .../31-libavfilter6_7%3a3.2.8-1~deb9u1_armhf.deb ...
Unpacking libavfilter6:armhf (7:3.2.8-1~deb9u1) over (7:3.2.5-1) ...
Preparing to unpack .../32-libisc-export160_1%3a9.10.3.dfsg.P4-12.3+deb9u3_armhf.deb ...
Unpacking libisc-export160 (1:9.10.3.dfsg.P4-12.3+deb9u3) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../33-libdns-export162_1%3a9.10.3.dfsg.P4-12.3+deb9u3_armhf.deb ...
Unpacking libdns-export162 (1:9.10.3.dfsg.P4-12.3+deb9u3) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../34-libfm-data_1.2.5-1+rpi2_all.deb ...
Unpacking libfm-data (1.2.5-1+rpi2) over (1.2.5-1+rpi1) ...
Preparing to unpack .../35-libfm-extra4_1.2.5-1+rpi2_armhf.deb ...
Unpacking libfm-extra4:armhf (1.2.5-1+rpi2) over (1.2.5-1+rpi1) ...
Preparing to unpack .../36-libfm-gtk-data_1.2.5-1+rpi2_all.deb ...
Unpacking libfm-gtk-data (1.2.5-1+rpi2) over (1.2.5-1+rpi1) ...
Preparing to unpack .../37-libfm-gtk4_1.2.5-1+rpi2_armhf.deb ...
Unpacking libfm-gtk4:armhf (1.2.5-1+rpi2) over (1.2.5-1+rpi1) ...
Preparing to unpack .../38-libfm4_1.2.5-1+rpi2_armhf.deb ...
Unpacking libfm4:armhf (1.2.5-1+rpi2) over (1.2.5-1+rpi1) ...
Preparing to unpack .../39-libfm-modules_1.2.5-1+rpi2_armhf.deb ...
Unpacking libfm-modules:armhf (1.2.5-1+rpi2) over (1.2.5-1+rpi1) ...
Preparing to unpack .../40-libwebkit2gtk-4.0-37_2.16.6-0+deb9u1+rpi1_armhf.deb ...
Unpacking libwebkit2gtk-4.0-37:armhf (2.16.6-0+deb9u1+rpi1) over (2.16.3-2+rpi1) ...
Preparing to unpack .../41-libjavascriptcoregtk-4.0-18_2.16.6-0+deb9u1+rpi1_armhf.deb ...
Unpacking libjavascriptcoregtk-4.0-18:armhf (2.16.6-0+deb9u1+rpi1) over (2.16.3-2+rpi1) ...
Preparing to unpack .../42-libnss3_2%3a3.26.2-1.1+deb9u1_armhf.deb ...
Unpacking libnss3:armhf (2:3.26.2-1.1+deb9u1) over (2:3.26.2-1.1) ...
Preparing to unpack .../43-libruby2.3_2.3.3-1+deb9u1+rpi1_armhf.deb ...
Unpacking libruby2.3:armhf (2.3.3-1+deb9u1+rpi1) over (2.3.3-1) ...
Preparing to unpack .../44-libxfont2_1%3a2.0.1-3+deb9u1_armhf.deb ...
Unpacking libxfont2:armhf (1:2.0.1-3+deb9u1) over (1:2.0.1-3) ...
Preparing to unpack .../45-linux-libc-dev_4.9.51-1+rpi3_armhf.deb ...
Unpacking linux-libc-dev:armhf (4.9.51-1+rpi3) over (3.18.5-1~exp1+rpi19+stretch) ...
Preparing to unpack .../46-lxpanel_0.9.3-1+rpi4_armhf.deb ...
Unpacking lxpanel (0.9.3-1+rpi4) over (0.9.3-1+rpi3) ...
Preparing to unpack .../47-lxpanel-data_0.9.3-1+rpi4_all.deb ...
Unpacking lxpanel-data (0.9.3-1+rpi4) over (0.9.3-1+rpi3) ...
Preparing to unpack .../48-lxplug-bluetooth_0.4_armhf.deb ...
Unpacking lxplug-bluetooth (0.4) over (0.3) ...
Preparing to unpack .../49-lxplug-ejecter_0.3_armhf.deb ...
Unpacking lxplug-ejecter (0.3) over (0.2) ...
Preparing to unpack .../50-lxplug-network_0.5_armhf.deb ...
Unpacking lxplug-network (0.5) over (0.2) ...
Preparing to unpack .../51-lxplug-volume_0.7_armhf.deb ...
Unpacking lxplug-volume (0.7) over (0.5) ...
Preparing to unpack .../52-pcmanfm_1.2.5-3+rpi2_armhf.deb ...
Unpacking pcmanfm (1.2.5-3+rpi2) over (1.2.5-3+rpi1) ...
Preparing to unpack .../53-pigpio_1.64-1_armhf.deb ...
Unpacking pigpio (1.64-1) over (1.60-1) ...
Preparing to unpack .../54-python-jwt_1.4.2-1+deb9u1_all.deb ...
Unpacking python-jwt (1.4.2-1+deb9u1) over (1.4.2-1) ...
Preparing to unpack .../55-python-pigpio_1.64-1_all.deb ...
Unpacking python-pigpio (1.64-1) over (1.60-1) ...
Preparing to unpack .../56-python3-pip_9.0.1-2+rpt1_all.deb ...
Unpacking python3-pip (9.0.1-2+rpt1) over (9.0.1-2) ...
Preparing to unpack .../57-python-pip_9.0.1-2+rpt1_all.deb ...
Unpacking python-pip (9.0.1-2+rpt1) over (9.0.1-2) ...
Preparing to unpack .../58-python-pip-whl_9.0.1-2+rpt1_all.deb ...
Unpacking python-pip-whl (9.0.1-2+rpt1) over (9.0.1-2) ...
Preparing to unpack .../59-python3-jwt_1.4.2-1+deb9u1_all.deb ...
Unpacking python3-jwt (1.4.2-1+deb9u1) over (1.4.2-1) ...
Preparing to unpack .../60-python3-pigpio_1.64-1_all.deb ...
Unpacking python3-pigpio (1.64-1) over (1.60-1) ...
Preparing to unpack .../61-raspi-copies-and-fills_0.6_armhf.deb ...
Unpacking raspi-copies-and-fills (0.6) over (0.5-1) ...
Preparing to unpack .../62-realvnc-vnc-viewer_6.17.731.29523_armhf.deb ...
Unpacking realvnc-vnc-viewer (6.17.731.29523) over (6.1.1.28093) ...
Preparing to unpack .../63-ruby2.3_2.3.3-1+deb9u1+rpi1_armhf.deb ...
Unpacking ruby2.3 (2.3.3-1+deb9u1+rpi1) over (2.3.3-1) ...
Preparing to unpack .../64-wpasupplicant_2%3a2.4-1+deb9u1_armhf.deb ...
Unpacking wpasupplicant (2:2.4-1+deb9u1) over (2:2.4-1) ...
Preparing to unpack .../65-xkb-data_2.19-1+deb9u1_all.deb ...
Unpacking xkb-data (2.19-1+deb9u1) over (2.19-1) ...
Preparing to unpack .../66-xserver-common_2%3a1.19.2-1+rpt1+deb9u2_all.deb ...
Unpacking xserver-common (2:1.19.2-1+rpt1+deb9u2) over (2:1.19.2-1+deb9u1+rpi1) ...
Preparing to unpack .../67-xserver-xorg-core_2%3a1.19.2-1+rpt1+deb9u2_armhf.deb ...
Unpacking xserver-xorg-core (2:1.19.2-1+rpt1+deb9u2) over (2:1.19.2-1+deb9u1+rpi1) ...
Preparing to unpack .../68-raspi-config_20170926_all.deb ...
Unpacking raspi-config (20170926) over (20170811) ...
Preparing to unpack .../69-scratch2_0.17_armhf.deb ...
Unpacking scratch2 (0.17) over (0.16) ...
Setting up libncurses5:armhf (6.0+20161126-1+deb9u1) ...
Setting up python-pip-whl (9.0.1-2+rpt1) ...
Setting up ncurses-term (6.0+20161126-1+deb9u1) ...
Setting up libapt-inst2.0:armhf (1.4.8) ...
Setting up git-man (1:2.11.0-3+deb9u2) ...
Setting up libwbclient0:armhf (2:4.5.12+dfsg-2) ...
Setting up scratch2 (0.17) ...
Setting up lxpanel-data (0.9.3-1+rpi4) ...
Setting up libidn2-0:armhf (0.16-1+deb9u1) ...
Setting up libisc160:armhf (1:9.10.3.dfsg.P4-12.3+deb9u3) ...
Setting up libisc-export160 (1:9.10.3.dfsg.P4-12.3+deb9u3) ...
Setting up raspi-copies-and-fills (0.6) ...
Setting up libavutil55:armhf (7:3.2.8-1~deb9u1) ...
Processing triggers for mime-support (3.60) ...
Setting up xxd (2:8.0.0197-4+deb9u1) ...
Setting up python3-pigpio (1.64-1) ...
Processing triggers for desktop-file-utils (0.23-1) ...
Setting up libldap-common (2.4.44+dfsg-5+deb9u1) ...
Setting up apt-utils (1.4.8) ...
Processing triggers for install-info (6.3.0.dfsg.1-1+b1) ...
Setting up dhcpcd5 (1:6.11.5-1+rpt2) ...
Installing new version of config file /etc/dhcpcd.conf ...
Setting up realvnc-vnc-viewer (6.17.731.29523) ...
Processing triggers for libglib2.0-0:armhf (2.50.3-2) ...
Setting up xkb-data (2.19-1+deb9u1) ...
Setting up python-pigpio (1.64-1) ...
Setting up linux-libc-dev:armhf (4.9.51-1+rpi3) ...
Setting up libgnutls30:armhf (3.5.8-5+deb9u3) ...
Setting up libdns-export162 (1:9.10.3.dfsg.P4-12.3+deb9u3) ...
Setting up samba-common (2:4.5.12+dfsg-2) ...
Setting up libnss3:armhf (2:3.26.2-1.1+deb9u1) ...
Setting up libgdk-pixbuf2.0-common (2.36.5-2+deb9u1) ...
Setting up libxfont2:armhf (1:2.0.1-3+deb9u1) ...
Setting up libfm-data (1.2.5-1+rpi2) ...
Setting up pigpio (1.64-1) ...
Setting up libswresample2:armhf (7:3.2.8-1~deb9u1) ...
Setting up libkrb5support0:armhf (1.15-1+deb9u1) ...
Setting up python-jwt (1.4.2-1+deb9u1) ...
Setting up raspi-config (20170926) ...
Setting up libfm-extra4:armhf (1.2.5-1+rpi2) ...
Setting up libisccc140:armhf (1:9.10.3.dfsg.P4-12.3+deb9u3) ...
Processing triggers for libc-bin (2.24-11+deb9u1) ...
Setting up libldap-2.4-2:armhf (2.4.44+dfsg-5+deb9u1) ...
Setting up libswscale4:armhf (7:3.2.8-1~deb9u1) ...
Processing triggers for systemd (232-25+deb9u1) ...
Setting up liblwres141:armhf (1:9.10.3.dfsg.P4-12.3+deb9u3) ...
Setting up python3-pip (9.0.1-2+rpt1) ...
Setting up desktop-base (9.0.2+deb9u1) ...
update-initramfs: deferring update (trigger activated)
Setting up libpostproc54:armhf (7:3.2.8-1~deb9u1) ...
Setting up vim-common (2:8.0.0197-4+deb9u1) ...
Setting up libfm-gtk-data (1.2.5-1+rpi2) ...
Processing triggers for man-db (2.7.6.1-2) ...
Processing triggers for shared-mime-info (1.8-1) ...
Setting up libjavascriptcoregtk-4.0-18:armhf (2.16.6-0+deb9u1+rpi1) ...
Processing triggers for gnome-menus (3.13.3-9) ...
Setting up libruby2.3:armhf (2.3.3-1+deb9u1+rpi1) ...
Setting up python-pip (9.0.1-2+rpt1) ...
Processing triggers for hicolor-icon-theme (0.15-1) ...
Setting up python3-jwt (1.4.2-1+deb9u1) ...
Setting up libdbus-1-3:armhf (1.10.22-0+deb9u1) ...
Setting up vim-tiny (2:8.0.0197-4+deb9u1) ...
Setting up libk5crypto3:armhf (1.15-1+deb9u1) ...
Setting up xserver-common (2:1.19.2-1+rpt1+deb9u2) ...
Setting up samba-libs:armhf (2:4.5.12+dfsg-2) ...
Setting up libavresample3:armhf (7:3.2.8-1~deb9u1) ...
Setting up libatspi2.0-0:armhf (2.22.0-6+deb9u1) ...
Setting up libfm4:armhf (1.2.5-1+rpi2) ...
Setting up libgdk-pixbuf2.0-0:armhf (2.36.5-2+deb9u1) ...
Setting up libavcodec57:armhf (7:3.2.8-1~deb9u1) ...
Setting up wpasupplicant (2:2.4-1+deb9u1) ...
Setting up gir1.2-gdkpixbuf-2.0:armhf (2.36.5-2+deb9u1) ...
Setting up ruby2.3 (2.3.3-1+deb9u1+rpi1) ...
Setting up xserver-xorg-core (2:1.19.2-1+rpt1+deb9u2) ...
Setting up libsmbclient:armhf (2:4.5.12+dfsg-2) ...
Setting up libkrb5-3:armhf (1.15-1+deb9u1) ...
Setting up dbus (1.10.22-0+deb9u1) ...
A reboot is required to replace the running dbus-daemon.
Please reboot the system when convenient.
Setting up libfm-gtk4:armhf (1.2.5-1+rpi2) ...
Setting up bluez (5.43-2+rpt1+deb9u1) ...
Setting up libavformat57:armhf (7:3.2.8-1~deb9u1) ...
Setting up libfm-modules:armhf (1.2.5-1+rpi2) ...
Setting up libwebkit2gtk-4.0-37:armhf (2.16.6-0+deb9u1+rpi1) ...
Setting up libavfilter6:armhf (7:3.2.8-1~deb9u1) ...
Setting up dbus-x11 (1.10.22-0+deb9u1) ...
Setting up dbus-user-session (1.10.22-0+deb9u1) ...
Setting up libgssapi-krb5-2:armhf (1.15-1+deb9u1) ...
Setting up pcmanfm (1.2.5-3+rpi2) ...
Setting up libdns162:armhf (1:9.10.3.dfsg.P4-12.3+deb9u3) ...
Setting up lxpanel (0.9.3-1+rpi4) ...
Setting up lxplug-network (0.5) ...
Setting up libcurl3:armhf (7.52.1-5+deb9u1) ...
Setting up libcurl3-gnutls:armhf (7.52.1-5+deb9u1) ...
Setting up lxplug-volume (0.7) ...
Setting up libisccfg140:armhf (1:9.10.3.dfsg.P4-12.3+deb9u3) ...
Setting up lxplug-ejecter (0.3) ...
Setting up lxplug-bluetooth (0.4) ...
Setting up libbind9-140:armhf (1:9.10.3.dfsg.P4-12.3+deb9u3) ...
Setting up git (1:2.11.0-3+deb9u2) ...
Setting up bind9-host (1:9.10.3.dfsg.P4-12.3+deb9u3) ...
Setting up apt-transport-https (1.4.8) ...
Setting up curl (7.52.1-5+deb9u1) ...
Processing triggers for initramfs-tools (0.130) ...
E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/b/bluez/libbluetooth3_5.43-2+rpt1+deb9u1_armhf.deb  Connection failed [IP: 93.93.128.211 80]
E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/r/realvnc-vnc/realvnc-vnc-server_6.2.0.29523_armhf.deb  Connection failed [IP: 93.93.130.39 80]
again the same packages are failing and when I manually try to, they get stuck at Waiting for header [90%] and then returns connection failed. I can't figure out if its the repository or me!
thunderknight99
Wed Oct 25, 2017 7:09 am
Here is another one when I am trying to install Tight VNC Server. It has been failing since yesterday.
[email protected]:~ $ sudo apt-get install tightvncserver
The following additional packages will be installed:
  xfonts-base
Suggested packages:
  tightvnc-java
The following packages will be REMOVED:
  realvnc-vnc-server
The following NEW packages will be installed:
  tightvncserver xfonts-base
0 upgraded, 2 newly installed, 1 to remove and 3 not upgraded.
Need to get 6,461 kB of archives.
After this operation, 25.6 MB disk space will be freed.
Get:1 http://mirrordirector.raspbian.org/raspbian stretch/main armhf tightvncserver armhf 1:1.3.9-9 [550 kB]
Err:2 http://mirrordirector.raspbian.org/raspbian stretch/main armhf xfonts-base all 1:1.0.4+nmu1
  Connection failed [IP: 93.93.128.193 80]
Fetched 550 kB in 30s (17.8 kB/s)
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/x/xfonts-base/xfonts-base_1.0.4+nmu1_all.deb  Connection failed [IP: 93.93.128.193 80]
and additionally this is my ifconfig
[email protected]:~ $ ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b8:27:eb:cc:47:74  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 9  bytes 524 (524.0 B)
        TX packets 9  bytes 524 (524.0 B)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.106  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::777f:2a06:b72b:c207  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:99:12:21  txqueuelen 1000  (Ethernet)
        RX packets 110247  bytes 151002727 (144.0 MiB)
        TX packets 76659  bytes 8165560 (7.7 MiB)
thunderknight99
Wed Oct 25, 2017 7:22 am
Again after a reboot, this is what is happening. Same Get prompt of the package is failing.
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Hit:2 http://mirrordirector.raspbian.org/raspbian stretch InRelease
[email protected]:~ $ tightvncserver
You will require a password to access your desktops.
Password:
Verify:
Would you like to enter a view-only password (y/n)? n
Couldn't start Xtightvnc; trying default font path.
Please set correct fontPath in the tightvncserver script.
Couldn't start Xtightvnc process.
25/10/17 07:17:58 Xvnc version TightVNC-1.3.9
25/10/17 07:17:58 Copyright (C) 2000-2007 TightVNC Group
25/10/17 07:17:58 Copyright (C) 1999 AT&T Laboratories Cambridge
25/10/17 07:17:58 All Rights Reserved.
25/10/17 07:17:58 See http://www.tightvnc.com/ for information on TightVNC
25/10/17 07:17:58 Desktop name 'X' (raspberrypi:1)
25/10/17 07:17:58 Protocol versions supported: 3.3, 3.7, 3.8, 3.7t, 3.8t
25/10/17 07:17:58 Listening for VNC connections on TCP port 5901
Font directory '/usr/share/fonts/X11/misc/' not found - ignoring
Font directory '/usr/share/fonts/X11/75dpi/' not found - ignoring
Fatal server error:
could not open default font 'fixed'
25/10/17 07:17:59 Xvnc version TightVNC-1.3.9
25/10/17 07:17:59 Copyright (C) 2000-2007 TightVNC Group
25/10/17 07:17:59 Copyright (C) 1999 AT&T Laboratories Cambridge
25/10/17 07:17:59 All Rights Reserved.
25/10/17 07:17:59 See http://www.tightvnc.com/ for information on TightVNC
25/10/17 07:17:59 Desktop name 'X' (raspberrypi:1)
25/10/17 07:17:59 Protocol versions supported: 3.3, 3.7, 3.8, 3.7t, 3.8t
25/10/17 07:17:59 Listening for VNC connections on TCP port 5901
Font directory '/usr/share/fonts/X11/Speedo/' not found - ignoring
Fatal server error:
[email protected]:~ $ sudo apt-get install tightvncserver --fix-broken
tightvncserver is already the newest version (1:1.3.9-9).
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
[email protected]:~ $ sudo apt-get install tightvncserver --fix-missing
[email protected]:~ $ sudo apt-get remove tightvncserver
  tightvncserver
0 upgraded, 0 newly installed, 1 to remove and 3 not upgraded.
After this operation, 1,433 kB disk space will be freed.
(Reading database ... 108585 files and directories currently installed.)
Removing tightvncserver (1:1.3.9-9) ...
[email protected]:~ $ sudo apt-get clean
  xfonts-base
Suggested packages:
  tightvnc-java
0 upgraded, 2 newly installed, 0 to remove and 3 not upgraded.
After this operation, 8,771 kB of additional disk space will be used.
Fetched 550 kB in 29s (18.4 kB/s)
thunderknight99
Wed Oct 25, 2017 7:30 am
And this is when I manually try to install that package which had failed connection.
[email protected]:~ $ sudo apt-get install xfonts-base
  xfonts-base
0 upgraded, 1 newly installed, 0 to remove and 3 not upgraded.
Need to get 5,911 kB of archives.
After this operation, 7,338 kB of additional disk space will be used.
Err:1 http://mirrordirector.raspbian.org/raspbian stretch/main armhf xfonts-base all 1:1.0.4+nmu1
I seriously suspect it is the repository. Is there a repository that has most packages (Open CV, Dlib, GTK, etc) which can be used instead of the default repositories? If so, please also give me a brief explanation on what to do with the sources.list and raspi.list so that I don't get any trouble in the near-future! :)
ShiftPlusOne
Wed Oct 25, 2017 7:40 am
I don't think there is anything wrong with the repository. I think there is something wrong between your ISP and the server, but let's wait until we hear back from the hosting provider.
thunderknight99
Wed Oct 25, 2017 7:50 am
Well, I think I mentioned before somewhere here but maybe bringing it up can help!? I experimented with the sources.list and raspi.list files and changed it as per some old post when Raspbian Jessie was released, they mixed up Jessie and Wheezy repository (i skipped the preference part). And well, with that, I ran sudo apt-get update && sudo apt-get upgrade which worked without any problem of connection fails. But in the end, it was all trouble because I had updated and upgraded with a mix of packages stretching over 3 different Debian versions so I had to do another fresh install of Raspbian Stretch.
And btw, I am running on a clock! Have to finish this project in two days maximum. I have the program ready but installing packages are giving me headache since 2 weeks!
KLL
Wed Oct 25, 2017 8:43 am
besides the connection problems,
you wrote:fresh install of Raspbian Stretch
? why you want install tightvncserver ( what kills realVNCserver )
for some time / JESSIE / STRETCH / all use the pre installed realVNC server
( need enable by 'sudo raspi-config' and install realVNC client on PC )
or you just follow again a very old internet manual to use your RPI headless / remote??
you wrote:what to do with the sources.list and raspi.list
i don't know, i never touched!
if you burned a new RASPBIAN STRETCH show us the link what says you should change there something for use JESSIE ??
you wrote: I have the program ready but installing packages are giving me headache
what you try to do? what packages , what program language...?
thunderknight99
Wed Oct 25, 2017 8:56 am
Well, I used an internet manual for headless install and I know realVNC is there but to use it via desktop client, I have to register/signup etc so that made it a bit tedious. So, I have been using TightVNC which seemed to be more convenient to me.
I don't remember which post was it but it's on the raspberrypi.org/forums and was posted in 2013 or something. All it did was include Wheezy repository along with Jessie since that time people had some trouble with the newly released Jessie's repo.
And I am trying to Install OpenCV and Dlib for image processing - face recognition.
bensimmo
Wed Oct 25, 2017 8:58 am
I'm confused now.
You say stretch, and started with stretch.
What has Jessie and weezie it to do with it.
Anyway, given the time constraint, download the latest image on a new SD card and start again. If problems persist, then it is routing problems or ISP problems.
thunderknight99
Wed Oct 25, 2017 9:04 am
I'm confused now.
I just added the repositories of Jessie and Wheezy into the sources.list and raspi.list files as an experiment and it worked (no connection fails). But, it altogether broke the Debian I guess so, I did again a fresh install of Raspbian Stretch and left the repositories as it is. And I have the latest image installed (which is Raspbian Stretch ).
Why is it an issue with ISP or routing since every time on every fresh install of Raspbian Stretch I have done in the past 3 days, the same packages are getting connection fails such as the rpi-chromium-mods while the rest are downloaded without issue. There is no packet loss to the server either.
KLL
Wed Oct 25, 2017 9:09 am
you wrote: Well, I used an internet manual for headless install and I know realVNC is there but to use it via desktop client, I have to register/signup etc so that made it a bit tedious. So, I have been using TightVNC which seemed to be more convenient to me.
?? i have VNC viewer installed on win7 PCs and all works fine ( inside one network)
i live in thailand and was never able to register/signup ( i have to assume my country is blocked? 10 years already? )
so again, if you use a new burned STRETCH
for headless work enable SSH and VNC ( by sudo raspi-config OR by the file trick )
and ONLY do the
sudo apt-get update successfully
you can try to install the tools you need for your programming
BUT
you wrote:Have to finish this project in two days maximum
555
bensimmo
Wed Oct 25, 2017 9:11 am
I notice on a list in there.
Do
- sudo apt-get clean
- sudo apt update
- sudo apt-get install apt apt-transport-https apt-utils
This should update just apt
(apt-get is an extension of it as far as I know, apt just displays a bit prettier)
Then
- sudo apt update
- sudo apt upgrade
First turn back everything you altered to default though.
Edit, I see, ah so lesson.. ignore anything related to older releases. ;-)
It could be a routing issue as the connection is failing, be it the route, timeout, whatever.
RPi are doing whatever they are doing their end to check
I don't know if you can specify a particular mirror server. But. It's not just one and most can connect.
For me it's the damn IPv6 servers that make mine fail, and apt is not clever enough to roll over to another server on the mirror.
thunderknight99
Wed Oct 25, 2017 9:16 am
and ONLY do the
BUT
555
Installing package from the repo is my only problem. TightVNC was downloaded without issue (but other packages were not) and was using for over a month till 4-5 days ago when I experimented too much and I thought I needed a fresh install or everything will be a disaster.
thunderknight99
Wed Oct 25, 2017 9:18 am
Do
sudo apt-get clean
sudo apt update
Then
sudo apt update
sudo apt upgrade
Okay I will try that. But I haven't altered anything. I am working on a fresh install of Raspbian Stretch. Did a headless install, enabled SSH and configured my WIFI (wpa_supplicant.conf) and nothing else other than attempting to download the packages of which I have provided the log above.
bensimmo
Wed Oct 25, 2017 9:21 am
I noticed that :-)
Just check the edited post.
This is just to update apt, the program that does the update buisiness.
(I don't know if apt would update the other two apt bits so I added them to the line)
Worth a try anyway
