Asmox
Transmission cannot connect with any port
Mon Oct 23, 2017 10:27 pm
Hello!
For some time I have been using Transmission with web interface. Then I have had a pause and now for unknown reasons I cannot use it any more. Every port I try to pick is said to be closed.
I have upnp enabled and no matter if I switch on port forwarding or not, it doesn't work. I also tried to reinstall transmission with no effect. Can you help me please?
allfox
Re: Transmission cannot connect with any port
Tue Oct 24, 2017 10:36 am
It might be your Internet Service Provider, who might now is giving you a private IP.
Check your router to tell if you are now with an IP like 100.64.x.y
IPv4 address is in short.
My ISP did this once, during a dark windy night, without declaration. I asked them to switch back.
Asmox
Tue Oct 24, 2017 6:40 pm
It doesn't look like change in IP. Here is a screenshot from my router:
Strange thing is that I can use transmission from my own PC connected to the same LAN. In case of my computer (not Raspberry) I'm getting message that ports are opened.
Return to “Raspberry Pi OS”
