Hello!
There is probably a very simple explanation to this but I only got the pi in September and i'm still getting used to it. I have been trying to download gimp using the command "sudo apt-get install gimp" but I get this output;
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
ghostscript gimp-data libamd2.3.1 libbabl-0.1-0 libcamd2.3.1 libccolamd2.8.0
libcholmod2.1.2 libgegl-0.2-0 libgimp2.0 libgs9 libgs9-common libijs-0.35
libjbig2dec0 libopenraw1 libpaper-utils libpaper1 libpoppler-glib8
libumfpack5.6.2 libwmf0.2-7
Suggested packages:
ghostscript-x gimp-help-en gimp-help gimp-data-extras
The following NEW packages will be installed:
ghostscript gimp gimp-data libamd2.3.1 libbabl-0.1-0 libcamd2.3.1
libccolamd2.8.0 libcholmod2.1.2 libgegl-0.2-0 libgimp2.0 libgs9
libgs9-common libijs-0.35 libjbig2dec0 libopenraw1 libpaper-utils libpaper1
libpoppler-glib8 libumfpack5.6.2 libwmf0.2-7
0 upgraded, 20 newly installed, 0 to remove and 0 not upgraded.
Need to get 3,715 kB/19.3 MB of archives.
After this operation, 80.0 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libjbig2dec0 armhf 0.13-4~deb8u1
404 Not Found [IP: 93.93.128.193 80]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgs9-common all 9.06~dfsg-2+deb8u4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libgs9 armhf 9.06~dfsg-2+deb8u4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main ghostscript armhf 9.06~dfsg-2+deb8u4
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... u4_all.deb 404 Not Found [IP: 93.93.128.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I tried the suggestions of apt-get update and --fix-missing but I may be inputing them wrong
Suggested packages:
I tried both suggestions at the bottom of the output, however i may have typed them wrong. I also looked on the internet to look for alternative inputs but i cant find anything that works. It'd be great if someone could help me out, thank you in advance,
THEITCROWDNERDMOSS
