VascoFerraz
apt-get segmentation fault
Sun Oct 22, 2017 12:57 pm
Can anyone please help with this:
xx@zzzzzzzzzzzz:~ $ sudo apt-get install --reinstall ntfs-3g
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 375 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian stretch/main armhf ntfs-3g armhf 1:2016.2.22AR.1+dfsg-1 [375 kB]
Fetched 375 kB in 20s (18.1 kB/s)
Segmentation fault
E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 returned an error code (1)
E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10
Vasco Ferraz
gkaiseril
Re: apt-get segmentation fault
Sun Oct 22, 2017 5:18 pm
Some part of the upgrade process failed.
I would restart the computer and try again. This should clear any locked files.
If it still fails. then you may need to clear some of the file directories used by apt-get.
sudo rm -rf /var/cache/apt/*.bin
sudo rm -rf /usr/bin/apt-listchanges/*.*
And try again.
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
VascoFerraz
Mon Oct 23, 2017 8:47 am
And try again.
Problem is still present :(
Vasco Ferraz
VascoFerraz
Mon Oct 23, 2017 1:28 pm
I think the problem is in the apt-listchanges
But if I download it and install it with dpkg I get:
user@host:~ $ sudo dpkg -i apt-listchanges_3.14_all.deb
(Reading database ... 125795 files and directories currently installed.)
Preparing to unpack apt-listchanges_3.14_all.deb ...
Segmentation fault
dpkg: warning: subprocess old pre-removal script returned error exit status 139
dpkg: trying script from the new package instead ...
Segmentation fault
dpkg: error processing archive apt-listchanges_3.14_all.deb (--install):
 subprocess new pre-removal script returned error exit status 139
Segmentation fault
dpkg: error while cleaning up:
 subprocess installed post-installation script returned error exit status 139
Vasco Ferraz
asavah
Mon Oct 23, 2017 2:53 pm
Do you have any free space left on sdcard?
Check with
df -h
VascoFerraz
Mon Oct 23, 2017 3:11 pm
Check with
df -h
xxxx@yyyy:~ $ sudo df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        15G  4.3G  9.7G  31% /
devtmpfs        370M     0  370M   0% /dev
tmpfs           375M     0  375M   0% /dev/shm
tmpfs           375M   11M  365M   3% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           375M     0  375M   0% /sys/fs/cgroup
/dev/sda1        15G  1.1G   14G   7% /media/pen16gb
/dev/sdb1        60G   47G   14G  78% /media/pen64gb
/dev/mmcblk0p1   42M   21M   21M  51% /boot
tmpfs            75M     0   75M   0% /run/user/109
tmpfs            75M     0   75M   0% /run/user/1000
I downloaded some packages from the repository and I was able to install successfully using dpkg.
Except for: apt-listchanges_3.14_all.deb
Vasco Ferraz
Mon Oct 23, 2017 3:16 pm
Why are you trying to install an X86_64 package on an ARM based processor. If you want that function you will need to build it from source code.
rpdom
Mon Oct 23, 2017 3:21 pm
I see no X86_64 package.
VascoFerraz
Mon Oct 23, 2017 3:28 pm
As far as I know I am on the RPI repository.
Where did you see in my posts that I am installing a X86_64 package?
Vasco Ferraz
Mon Oct 23, 2017 3:29 pm
apt-listchanges_3.14_all.deb appears to be an Ubuntu X86_64 package. No armhf version available, as far as I can see.
VascoFerraz
Mon Oct 23, 2017 3:34 pm
Is it normal to have a X86_64 package in the Raspbian repository?
http://mirrordirector.raspbian.org/rasp ... stchanges/
Vasco Ferraz
Mon Oct 23, 2017 4:41 pm
It's just that a segfault is normally (as in 99.9999% of the time) due to trying to run X86/X86_64 code on a Raspberry.
gkaiseril
Mon Oct 23, 2017 6:15 pm
I had no problem installing it in stretch on a 32 GB card on a Pi 3.
rpdom
Mon Oct 23, 2017 6:23 pm
The "_all" in the name is an indication that it is for ALL architectures. There should be no arch specific code in it.
VascoFerraz
Tue Oct 24, 2017 8:41 am
I have no idea what is going on. I think I have to reflash the Pi.
I never did a rpi-update, just apt-get update, upgrade and dist-upgrade
That's strange because my Pi1 never had this kind of issues.
Pi3 suddenly breaks regularly out of nothing (this is not the first time).
Vasco Ferraz
VascoFerraz
Tue Oct 24, 2017 2:51 pm
After messing around with some packages I found that python3.5 also had problems.
I manually installed all python3.5 dependencies.
Then, I manually installed python3.5 and finally apt-listchanges.
Problem solved.
Vasco Ferraz
chrstphrchvz
Mon Aug 20, 2018 9:55 am
Problem solved.
This makes sense. If there is a segmentation fault running `python3`, then the same would happen for running `apt-listchanges` since it is just a Python 3 script.
I'm using packages from debian testing, and encountered an issue very similar to this with Python 3.6.5-rc1, where even trying to reinstall/upgrade apt-listchanges didn't seem possible due to errors running apt-listchanges. Manually upgrading everything currently installed from the python36 and python3-stdlib-extensions source packages to 3.6.6 seemed to solve the problem for me.
duceduc
Thu May 28, 2020 12:17 pm
I have the exact same error message and file in question as well. Like the OP, this isn't the first time this error popped up. It happened a few months ago, but the segmentation fault was for a different package. I couldn't figure it out so I just reinstall from fresh.
This time around, I've tried to manually reinstalling all the python pkg like the OP, but the issue was still there. I found another post suggesting to rename 20listchanges file located in /etc/apt/apt.conf.d. It fixed it. I don't understand why, but it works.
