FinPat
All icons and menu items missing after update
Fri Oct 13, 2017 6:32 am
Hello
Run the update today and after restart almost all icons and pictures are missing.
Also on the menu bar all items are super thin and only showing a line when mouse over.
Cant find any similar with search to my problem.
See attached image how it looks at the desktop at this moment.
It is the same if i use VNC or Teamviewer.
Any pointing to where i can find the solution to get it back to normal without reinstalling would be appreciated.
As i use it for my weather station to update my homepage.
Pi desktop.jpg (22.29 KiB) Viewed 4613 times
MaxK1
Re: All icons and menu items missing after update
Sat Oct 14, 2017 8:23 am
Only time I have seen those symptoms is when there is some kind of problem with my primary storage device - in my case /dev/sda.
Does dmesg show any errors on the sd card or did the update/upgrade show any errors?
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
FinPat
Thu Nov 09, 2017 12:39 pm
Hello
As far as i remember there was no errors when updating the PI.
Also cant see any error in demsg either.
Is there a way of getting the screen back?
Or is it reinstall that i have to do?
R
Megosalat
Fri Nov 10, 2017 6:06 am
Try to sudo update and sudo upgrade again. I had same problem. Guess installation of update was failed
MaxK1
Fri Nov 10, 2017 6:45 am
Is the SD card full?
FinPat
Fri Nov 10, 2017 10:25 am
Hello
Sudo update and sudo upgrade done several times and no changes.
According to file manager there is 7.7GB free space on SD card.
Also all icons in file manager is gone.
R
JakeHarrison92
Tue Jan 16, 2018 7:52 pm
Did you manage to fix this issue? Currently having the exact same problem.
FinPat
Wed Jan 17, 2018 1:36 am
Problem is still not resolved for me.
If you come up with some information on how to resolve it please shared it
R,
FinPat
marco.paggioro
Wed Jan 17, 2018 12:44 pm
Same problem -.-
Wed Jan 17, 2018 2:28 pm
Suggestion:
move the .local folder in your user root folder to somewhere else as a backup.
e.g.
cd /home/pi
mv .local .oldlocal
Restart
Ganderson65w
Wed Jan 17, 2018 2:52 pm
That doesn’t work for me.
If it was meant to produce a new version of .local it didn’t. Can see .oldlocal so did do move correctly.
Wed Jan 17, 2018 3:23 pm
OK, will see what else we can come up with. Not sure if it is meant to produce a new .local folder.
FinPat
Thu Feb 22, 2018 12:09 pm
Hello all reading this.
Today i did the update/upgrade and all my icons and menus are back
Now looking normal again
R
FinPat
JakeHarrison92
Thu Feb 22, 2018 12:24 pm
Didn't work for me, even with a reboot
PhilBr
Thu Feb 22, 2018 7:33 pm
I had that problem but with a Ubuntu system - not on a Pi.
This fixed it:
sudo apt-get update
sudo dpkg --configure -a
hth
Phil
Ganderson65w
Sun Feb 25, 2018 10:51 am
Icons and menu items reappeared after update & upgrade.
All OK now.
BlackKnight_UK
Tue Mar 13, 2018 11:55 am
I installed a fresh download of Raspbian two days ago (2017-11-29-raspbian-stretch.zip) onto a Pi Zero W.
When I booted this morning it said it had updated to the latest version and I have no main menu icon, the raspberry has gone - the menu is there but I couldn't see it until I changed the icon from the properties menu.
My wifi icon has changed to a LAN one. The other icons are there still.
Not as drastic as losing all the icons but still annoying.
RLBgator
Thu Apr 26, 2018 5:30 pm
I'm in the same boat as BlackKnight_UK; fresh install from NOOBS, then update - raspberry icon missing from now-narrow Menu button, and wi-fi icon switched. I'm also experiencing what I can only call "missing chrome." Menus and windows missing borders, sometimes immovably stuck to top of screen. Little weirdnesses.
rmiles7721
Fri May 04, 2018 8:59 pm
I'm currently having the same problem. Any update on this? Tried the couple of things listed above and they have not worked for me.
wizofe
Tue Jun 26, 2018 8:50 am
Hey @rmiles7721. Can you confirm that happens in the vanilla Raspbian? A solution for you is the following: :geek:
$ wget http://ftp.us.debian.org/debian/pool/ma ... _armhf.deb
$ sudo dpkg -i libfm4_1.3.0.2-1_armhf.deb
It seems that the latest `pcmanfm` library solves the issue.
DavidHaworth
Wed Jun 12, 2019 12:12 am
Installed image Ubuntu Mate 118.04 and no top or bottom menus or icons were displayed in the black bands.
Tried the updates & upgrades with no success.
Cursor changed to vertical line in upper left corner.
Right click, select Reset Panel, fixed the top and bottom menus and icons.
73 David WA9ONY
RailRodder22
Wed Jul 10, 2019 3:08 pm
Hi
This problem raised its ugly head again for me installing Buster on the new Pi 4. After the install did the usual update/upgrade, and the icons disappeared.
did a full compare between before and after and found this directory and sub-directories had lost the world readable attribute.(ls -lR /usr/lib/arm-linux-gnueabihf/gdk-pixbuf-2.0/2.10.0 )
Did "sudo chmod o+r /usr/lib/arm-linux-gnueabihf/gdk-pixbuf-2.0/2.10.0 -R", rebotted and all was good.
Steve G.
