sudo apt update
sudo apt dist-upgradeAnd as a matter of fine detail, upgrading the system does not put you in exactly the position as installing a clean image: some differences remain which can cause confusion during troubleshooting.As this is a major version upgrade, we recommend using a clean image; these are available from the Downloads page on our site as usual.
Upgrading an existing Jessie image is possible, but is not guaranteed to work in every circumstance. If you wish to try upgrading a Jessie image to Stretch, we strongly recommend taking a backup first – we can accept no responsibility for loss of data from a failed update.
There is some misunderstanding here.internsrus wrote: ↑Thu Oct 12, 2017 1:17 pmThank you. None of us here are in any way Raspberrypi experts, of necessity we try to learn from one another and from what we see in the forums and internet searches. There has been in the past a repeated stream of advice to do updates and upgrades before anything else, which if we understand you correctly now seems no longer to be what you are currently advising, and which we gladly accept. As it can be almost an all-day task to set up and work at a remoted site, we wanted if possible to update and upgrade without the need for a visit, using our existing facilities and following our records on how to do things and why.
The latest (v2.4.4 at the time of writing) release of the NOOBS Installer comes bundled with a version of Raspbian based on Debian Stretch.to be the same OS as in the latest noobs
