Jenkins
[HOW TO] Wireless Hotspot With Realtek RTL8188CUS
Mon Oct 08, 2012 5:40 pm
As part of my project use the raspberry pi to control my dlsr I wanted it to create a wireless hotspot if it was unable to connect to a wireless network. This is how I got it working for me with a Edimax EW-7811Un (Realtek RTL8188CUS) .
I used the latest Raspbian image so did not need to install any drivers for the wifi dongle.
You need to check the name of your wifi dongle mine was "wlan0" , this can be done using the command.
ifconfig
To connect to wifi on boot you need to configure the interfaces file. This is the network which the pi trys to connect to first.
nano /etc/network/interfaces
My interfaces file looks like this, make sure you change "your-ssid" and "your-password"
auto lo wlan0
iface lo inet loopback
iface wlan0 inet dhcp
wpa-ssid your-ssid
wpa-psk your-password
iface eth0 inet dhcp
Next install the dhcp server
apt-get install isc-dhcp-server
Now so set up the dhcp, edit the file
nano /etc/default/isc-dhcp-server
So the bottom line reads
INTERFACES="wlan0"
Now edit this file
nano /etc/dhcp/dhcpd.conf
So it looks like:
Change any names/settings to suit your requirements. The hardware address will need changing to match yours, it can be found by running
ifconfig
DDHCPDARGS=wlan0; # to specify to which interface your dhcpd server have to listen
default-lease-time 600;
max-lease-time 7200;
option subnet-mask 255.255.255.0;
option broadcast-address 192.168.1.255;
option routers 192.168.1.255;
option domain-name "DSLR.PI";
subnet 192.168.1.0 netmask 255.255.255.0 {
range 192.168.1.1 192.168.1.10;
host raspberrypi {
hardware ethernet 80:1f:02:61:0e:b1;
fixed-address 192.168.1.3;
Because this file is not created when isc-dhcp-server is installed you need to create it.
touch /var/lib/dhcp/dhcpd.leases
Finally so that the wifi hotspot is created if you are not connected to a network edit this file :
nano /etc/rc.local
Adding this in changing "your-ssid", and any of the settings sicha s teh essid and the key.
if iwconfig | grep your-ssid
then
echo "Already conneced to wireless network"
else
echo "Setting up wireless hotspot"
ip link set wlan0 down
iwconfig wlan0 mode ad-hoc
iwconfig wlan0 channel 4
iwconfig wlan0 essid 'RasPiDSLR'
iwconfig wlan0 key password
ip addr add 192.168.1.255/16 dev wlan0
ip link set wlan0 up
/usr/sbin/dhcpd wlan0
fi
Hope this helps people.
DOSSTONED
Re: [HOW TO] Wireless Hotspot With Realtek RTL8188CUS
Tue Oct 09, 2012 2:51 pm
I'll try it.
1. Always wanted to use IPv6 in the subnet(IPv6 advertisement is handled by the gateway, and I just pass the traffic from eth0 to wlan0)
2. Maybe we can wait for the new driver cause the current driver DOES NOT provide AP mode, but I made the AP possible under Fedora 17 X86_64. You know, ad-hoc seems not support with smart phones.
Jenkins
Tue Oct 09, 2012 4:42 pm
DOSSTONED wrote: You know, ad-hoc seems not support with smart phones.
Hopefully it works for you, I can connect to the ad-hoc network and ssh into my pi with my htc desire and the connect bot app.
Edit: I am running the oxygen rom
Colly
Tue Jan 15, 2013 8:49 am
Jenkins wrote:As part of my project use the raspberry pi to control my dlsr I wanted it to create a wireless hotspot if it was unable to connect to a wireless network.
What's a "dlsr"? Something new I hadn't heard of?
Is it one of the things in this list? http://www.acronymgeek.com/DLSR
I especially like your idea that it should create a wi-fi hotspot even if it can't connect to the net.
Jenkins
Fri Jan 18, 2013 10:05 pm
DSLR stands for digital single lens reflex digital camera such as these ones by Nikon http://www.nikonusa.com/en/Nikon-Produc ... index.page
Colly
Sat Jan 19, 2013 4:40 am
Ah - so then "DLSR" was just a typo with the L & S swapped,
Jenkins
Sun Jan 20, 2013 2:14 pm
Opps had not spotted that thanks!
Tickle
Tue Jan 22, 2013 4:30 pm
Sweet! I'm so glad you included what Wifi dongle you used, I had been usure of which one to buy. I will use this as soon as my Pi comes in the mail (literally the slowest few weeks of my life :lol: )
Hunter's Pi Projects: http://www.hunterthornsberry.com/raspberrypi.html
Who is online
Users browsing this forum: No registered users and 11 guests
