Fri Oct 12, 2012 1:09 pm
Hmm not an expert on codecs and video transcode.
How do I determine them
Using ffmpeg on a ts I get the following, does that help ?
ffmpeg version 0.8.3-4:0.8.3-0ubuntu0.12.04.1, Copyright (c) 2000-2012 the Libav developers
built on Jun 12 2012 16:52:09 with gcc 4.6.3
*** THIS PROGRAM IS DEPRECATED ***
This program is only provided for compatibility and will be removed in a future release. Please use avconv instead.
[mpegts @ 0x24357a0] max_analyze_duration reached
Input #0, mpegts, from 'wnmhgb.ts':
Duration: 00:48:20.06, start: 0.287267, bitrate: 5349 kb/s
Program 258
Stream #0.0[0xe0]: Video: mpeg2video (Main), yuv420p, 720x576 [PAR 16:15 DAR 4:3], 9800 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0.1[0x80](eng): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Stream #0.2[0x81](eng): Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
Stream #0.3[0x82](eng): Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
Stream #0.4[0x83](eng): Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
Stream #0.5[0x84](eng): Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
At least one output file must be specified
