/media/emby/ffmpeg-stuff/FFmpeg/ffmpeg -fflags +igndts -c:v mpeg2_mmal -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/33d6a801fda343d8ad20032ad127b83f/stream.ts" -map_metadata -1 -map_chapters -1 -threads 0 -sn -codec:v:0 h264_omx -b:v 5000000 -maxrate 5000000 -bufsize 10000000 -force_key_frames "expr:gte(t,n_forced*3)" -vf "yadif=0:-1:0,scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -flags -global_header -vsync cfr -codec:a:0 aac -strict experimental -ac 6 -ab 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/068a9456c2ce056b2e1e1e6b7c5cb0b2/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "/emby/emby-paths/transcode-temp/transcoding-temp/068a9456c2ce056b2e1e1e6b7c5cb0b2.m3u8" -y "/emby/emby-paths/transcode-temp/transcoding-temp/068a9456c2ce056b2e1e1e6b7c5cb0b2%d.ts"
frame= 38 fps= 23 q=-0.0 size=N/A time=00:00:01.16 bitrate=N/A dup=34 drop=0 speed=0.72x frame= 47 fps= 22 q=-0.0 size=N/A time=00:00:01.46 bitrate=N/A dup=36 drop=0 speed=0.685x frame=
52 fps= 20 q=-0.0 size=N/A time=00:00:01.63 bitrate=N/A dup=37 drop=0 speed=0.613x frame= 60 fps= 19 q=-0.0 size=N/A time=00:00:01.90 bitrate=N/A dup=38 drop=0 speed=0.597x frame= 65 fps= 18 q=-0.0 size=N/A time=00:00:02.06 bitrate=N/A dup=39 drop=0 speed=0.56x
frame= 75 fps= 18 q=-0.0 size=N/A time=00:00:02.40 bitrate=N/A dup=41 drop=0 speed=0.572x frame= 80 fps= 17 q=-0.0 size=N/A time=00:00:02.56 bitrate=N/A dup=42 drop=0 speed=0.547x
/media/emby/ffmpeg-stuff/FFmpeg/ffmpeg -fflags +igndts -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/66f70efc2799416eb57a1fdba3fb51e3/stream.ts" -map_metadata -1 -map_chapters -1 -threads 0 -sn -codec:v:0 h264_omx -b:v 5000000 -maxrate 5000000 -bufsize 10000000 -force_key_frames "expr:gte(t,n_forced*3)" -vf "yadif=0:-1:0,scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -flags -global_header -vsync cfr -codec:a:0 aac -strict experimental -ac 6 -ab 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/88886cb8ad432f7078f78b278ebe4217/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "/emby/emby-paths/transcode-temp/transcoding-temp/88886cb8ad432f7078f78b278ebe4217.m3u8" -y "/emby/emby-paths/transcode-temp/transcoding-temp/88886cb8ad432f7078f78b278ebe4217%d.ts"
frame= 43 fps= 35 q=-0.0 size=N/A time=00:00:01.33 bitrate=N/A dup=41 drop=0 speed=1.07x frame= 51 fps= 29 q=-0.0 size=N/A time=00:00:01.60 bitrate=N/A dup=41 drop=0 speed=0.905x frame=
55 fps= 24 q=-0.0 size=N/A time=00:00:01.73 bitrate=N/A dup=41 drop=0 speed=0.75x frame= 65 fps= 23 q=-0.0 size=N/A time=00:00:02.06 bitrate=N/A dup=41 drop=0 speed=0.732x frame= 71 fps= 21 q=-0.0 size=N/A time=00:00:02.26 bitrate=N/A dup=41 drop=0 speed=0.675x
frame= 79 fps= 20 q=-0.0 size=N/A time=00:00:02.53 bitrate=N/A dup=41 drop=0 speed=0.654x frame= 86 fps= 20 q=-0.0 size=N/A time=00:00:02.76 bitrate=N/A dup=41 drop=0 speed=0.632x frame=
91 fps= 19 q=-0.0 size=N/A time=00:00:02.93 bitrate=N/A dup=41 drop=0 speed=0.599x frame= 97 fps= 18 q=-0.0 size=N/A time=00:00:03.13 bitrate=N/A dup=41 drop=0 speed=0.578x frame= 107 fps= 18 q=-0.0 size=N/A time=00:00:03.47 bitrate=N/A dup=41 drop=0 speed=0.584x
frame= 114 fps= 18 q=-0.0 size=N/A time=00:00:03.70 bitrate=N/A dup=41 drop=0 speed=0.571x
