Hiddenworlds225
How to detect and use files in BASH
Thu Oct 05, 2017 12:06 am
Hey, so i'm in a cyber security class and with what i have learned i wanted to test something: I built an encryption program that links to the BASH shell, yet i'm literally stuck until i can get the shell to detect certain files within a folder, but how?
I know only the basics of using the shell but not programming it.
Any suggestions?
scruss
Re: How to detect and use files in BASH
Thu Oct 05, 2017 12:12 am
Think you might be slightly in the wrong subforum with this question, but you're looking for the test command.
Test can also be called with the [ command, for the slightly odd looking constructs:
[ -f full.fzz ] && echo "file full.fzz is real"
[ -d blorp ] || echo "there is no blorp folder here"
Hiddenworlds225
Thu Oct 05, 2017 7:55 pm
Thanks man, plus,i'm not saying anything, But wouldn't BASH be classified as a bare metal because its what the system runs on, unless if you have it set up differently.
Thu Oct 05, 2017 8:01 pm
Bare metal is a system without a standard OS (no Linux, for example).
Bash is merely one of the possible command line interpreters that can be run on the system. The system doesn't run on bash, bash runs on the system, as does everything else.
Hiddenworlds225
Fri Oct 13, 2017 7:53 pm
ah... So he was correct.
Return to “Advanced users”
