hilygon
/dev/video0 not appeared
Fri Sep 29, 2017 12:37 pm
I'm trying to set up a tvheadend server. For transcoding I'm setting up ffmpeg and video4linux2.
But I faced a problem. /dev/video0 not appeared.
What I did :
1. install OS from Raspbian 9/7 2017 version.
2. sudo apt-get update
3. sudo apt-get upgrade
4. sudo rpi-update
5. sudo modprobe bcm2835-v4l2
6. ls /dev/vi*
ls: cannot access /dev/video0: No such file or directory
I already read this thread viewtopic.php?t=68247
But it doesn't help on my problem. Can anyone help on this?
Many thanks.
Re: /dev/video0 not appeared
Fri Sep 29, 2017 3:15 pm
What I did :
4. sudo rpi-update
6. ls /dev/vi*
Many thanks.
4. sudo rpi-update
Not recommended as installs a Beta / Testing Kernel / Firmware.
The recommended way to fully update Raspbian:
sudo apt-get update
sudo apt-get dist-upgrade
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
Fri Sep 29, 2017 3:30 pm
Don't run rpi-update, it can break your system.
That modprobe only works if the camera is supported and detected. To get that working you need
gpu_mem=128
start_x=1
in /boot/config.txt. Then after rebooting test that with a vcgencmd get_camera command.
When you modprobe the bcm2835-v4l2 module you should see
[ 8168.309685] media: Linux media interface: v0.10
[ 8168.350580] Linux video capture interface: v2.00
[ 8168.422598] bcm2835-v4l2: scene mode selected 0, was 0
[ 8168.423260] bcm2835-v4l2: V4L2 device registered as video0 - stills mode > 1280x720
[ 8168.428877] bcm2835-v4l2: Broadcom 2835 MMAL video capture ver 0.0.2 loaded.
[ 8179.420939] bcm2835-v4l2: error 0 waiting for frame completion
in the output from a dmesg | less command (timestamps will be different).
If the camera isn't supported you'll get
[338314.067319] media: Linux media interface: v0.10
[338314.117788] Linux video capture interface: v2.00
but nothing else.
If you want to load the video0 driver at every boot add a line in /etc/modules and the system will "modprobe" it for you automatically.
This is a doctor free zone.
hilygon
Tue Oct 03, 2017 1:48 am
Really thank you all. I'm not able to access my raspi at this present. I'm on a trip. I'll try again once I'm back home.
deas
Mon Nov 06, 2017 3:16 pm
I think I am seeing the same thing and we might have a kernel regression. My post is here: viewtopic.php?f=28&t=197025.
regards
Andreas
