Personally I have never experienced this SD cards going read only.
I have used Kingston SD card right for my first pi B which used full size SD cards, and moved to Kingston micro Sd cards from the B+. I don't even use the fastest one only the class4 versions.
I have had several pi's that ran 24/7 one wrote to the SD card 10 -16 times a day and even suffered several sudden power outages with no harmful affects and ran for 2 years on the same SD card before the pi was no longer required, the card is still in use on other shorter term projects and works to this day.
My other long running pi has been running for 3 years 24/7 has suffered one card corruption which was my fault as I let the card become full which crashed the system, a re-flash of the OS and software re-load and it was back working, it writes to the card every 2 mins and every 15 min saving 2 different sets of data and creating new data files every 24 hours while archiving the old ones.
I have 4 or 5 SD cards which I use as test cards when helping people here which regularly get re-flashed with new OS image.
So with all this writing to and flashing of SD cards if it was a pi problem I would have expected to see such failures myself by now, I may be it just down to poor quality or fake SD cards.
With the number of pi's out there now if it was an inherent problem on the pi its self I would have expected to see many many many more reports of SD card failures, with 12.5 million pi's having been sold if just 1% of people experienced this problem that would be 120,000 people having a problem, I think by now if that many people were having this problem this forum would be snowed under with reports of SD card failures.
just my humble opinion.
