davity
Experiencing slow response with Raspbian 2012-09-18
Sat Oct 06, 2012 5:57 pm
Hi
After some months without time to "play" with my raspy, yesterday I downloaded the last raspbian image from raspberrypi main site and installed it in substitution to my old debian 2012-4-19.
In a first moment I was very happy about the performance of the system and also the new configuration tool (overclock, locale set, etc), in general it runs faster than my old debian. But I noticed some lag at using the system, like some micro-hangs when writting at console. I have never experienced this with my old debian and it wasn't very serious.
The real problem started when I set up an openssh server and a mumble server (voip server). When I connect to raspi from my main computer it tooks more than 5 seconds to the system to ask me for my passphrase (I'm using a public key auth) after I gave it the user, wich is a considerable retardment considering that two computers are at the same LAN network. With my old debian it was almost instant, no noticeable lag at all. Again, I didn't consider it very serious, just some seconds lost. Then I try to make a connection with my mumble server. It took more than 15 seconds after I pressed the Connect button until it finally connected to the server. Even the creation of a new channel at the server took several seconds to show the new channel. Again, in my old Debian everything works like lightning.
I thought that it could be some weird problem with my network, so I connect my raspi to my monitor and installed a mumble client in local. But the problem still remains in a local environment: it tooks more than 15 seconds to connect to a local server.
Apart of that initial connection time, everything works fine, I can chat with 5 people in server without problem or noticeable lag.
I don't know what could be going on. I tried to overclock to 800MHz using the raspi-conf but everythinway. I have installed just the mumble server, openssh server and a noip server to use a domain (problems shows after and before install noip server). Top don't show any process taking 100% of the cpu or something.
Someone knows what can be going on? Some idea? I know that it's a very weird problem, but it was working well with my old Debian! I appreciate any help you can give me :)
Regards
David
EDIT: I have setup a proftp server and it took more than 6 seconds to connect to server, so the problem is not only with mumble or openssh.
broo0ose
Re: Experiencing slow response with Raspbian 2012-09-18
Sat Oct 06, 2012 7:37 pm
I'm not saying this is all of your problem but ssh sessions can be slow to start because the server does a DNS lookup of the client. This is an SSH thing, nothing to do with the Pi.
you can speed it up by adding the clients name and ip address to /etc/hosts
fivdi
Sat Oct 06, 2012 7:56 pm
I've also noticed the "micro-hangs" when using a SSH console. You're typing away normally and the console freezes for a few seconds. Then everything turns back to normal. I've seen it a few times since updating to 2012-09-18-wheezy-raspbian in combination with turbo mode.
davity
Sat Oct 06, 2012 8:26 pm
broo0ose wrote:I'm not saying this is all of your problem but ssh sessions can be slow to start because the server does a DNS lookup of the client. This is an SSH thing, nothing to do with the Pi.
I will try but, ftp makes a DNS lookup too? the problem is the same with both of them.
fivdi wrote:I've also noticed the "micro-hangs" when using a SSH console. You're typing away normally and the console freezes for a few seconds. Then everything turns back to normal. I've seen it a few times since updating to 2012-09-18-wheezy-raspbian in combination with turbo mode.
I notice that "micro-hangs" too under the same conditions (ssh and raspbian 2012-09-18. Also in local mode (with screen and keyboard connected to pi) I notice a tiny hangs in console and some key repetition very often, didn't notice it with debian 2012-4-19.
milhouse
Sat Oct 06, 2012 8:42 pm
Have you checked your syslog for mention of "kevent 2 may have been dropped" and out of memory (OOM) tracebacks? I had an OOM situation (running Logitech Media Server, Sickbeard and Transmission) that manifested itself as "freezes" of several seconds (between 5 and 10 seconds) while the Pi sorted itself out. I fixed it by increasing the minimum free memory in /etc/sysctl.conf from vm.min_free_kbytes=8192 (8MB) to vm.min_free_kbytes=16384 (16MB) and now the Pi runs absolutely fine - no OOM problems and no freezes.
Hangs of much shorter duration are likely to be something else, maybe dropped USB packets.
fivdi
Sat Oct 06, 2012 9:20 pm
There's no mention of either of these in the syslog. I'll check it directly after it happens the next time. It doesn't happen very often.
@davity: does your syslog mention anything?
davity
Sat Oct 06, 2012 9:29 pm
There's no mention to any kevent in my /var/log/syslog, just some error wich says
raspberrypi kernel: [14836.466063] The scan_unevictable_pages sysctl/node-interface has been disabled for lack of a legitimate use case.  If you have one, please send an email to linux-mm@kvack.org.
But should be fortuite, because I can't repeat it.
I tried to open some ftp and ssh connection but any error appear at syslog.
EDIT: I tried to make the same change at sysctl but still several seconds to connect to anything and no error in syslog
davity
Mon Oct 08, 2012 12:25 pm
After change the systcl memory I've observed smoother movement of mouse at desktop, very pleasant now, don't get stucked randomly.
On the other side, I've observed a considerable lag when a user login. System ask for user, and then several seconds to ask for password. After that, another several seconds to get the prompt.
I've also watched with wireshark a standar ftp connection with the pi, but no mass retransmisions noticed, so it should be some internal raspbian problem.
After try overclock to 1GHz, I notice a improve in general system performance (loading, web wrowsing, etc) but not at all the problems related before.
jnd
Mon Oct 08, 2012 4:09 pm
I noticed the ssh prompt delay few weeks ago, I update regularly but the problem still remains. I have no idea why it is like that but on Arch in works instantly as it should on any system.
Testa
Fri Nov 30, 2012 3:38 am
I had that problem to.
:idea: My solution:
$ sudo dphys-swapfile swapoff
$ sudo update-rc.d -f dphys-swapfile remove
$ echo 0 > /proc/sys/vm/swappiness
/etc/sysctl.conf
vm.swappiness = 0
:P
Riccardo90
Sun Dec 02, 2012 11:42 am
after some weeks of brainstorming i've found the solution for the slow mumble server... the problem was the most obvious: slow SD card!! i tried to put the mumble database in a temporary ram partition, now it works flawlessly. I'm writing a script that mounts tmpfs on boot and backup the database on shutdown, it still needs some minor improvement
... sorry for my crappy english
davity
Sun Dec 02, 2012 8:34 pm
Testa wrote:I had that problem to.
:idea: My solution:
/etc/sysctl.conf
vm.swappiness = 0
:P
I will try that.
After some research some time ago I ended up with Riccardo90 solution (asking in mumble IRC), so for the moment it run fine.
Riccardo90, I included a call to the mount script in the mumble-server file at /etc/init.d, so I assure that it will be mount in order everytime. It's a bit sloppy, but it works very well :)
Riccardo90
Sun Dec 02, 2012 11:33 pm
this is my script
http://pastebin.com/99d1QEt0
i'm using it on my raspi, if you want to try it just paste it in a file and chmod +x and read carefully the comments!
"sudo script.sh start" will mount and populate tmpfs
"sudo script.sh stop" will dump the database and unmount tmpfs
