kg5nna
Raspberri Pi 3 Mod B Wi-Fi Won't Connect
Thu Sep 21, 2017 2:50 am
Greetings.
I have looked around on the forum here for posts regarding the Raspberry Pi3 mod b Wi-Fi problems but I don't seem to see specifically that troubleshoot string anywhere. Maybe I could begin a threat for this.
I received my Pi3 Mod B yesterday and everything seemed to work fine until I got to trying to connect to my Wi-Fi. I have two routers with Wi-Fi in the same room as where I powered up the Raspberry Pi. I click on the icon at the top right, it soon discovers both routers, however, entering the WEP PSK doesn't cause the wlan0 to pick up an IP. I'll add that I have an iPad Pro and an iPhone that have no trouble connecting.
I connected the hard line ethernet and booted into the web browser just fine. I did the apt-get update, apt-get upgrade and rebooted, but no change
I saw where the system HAD created a proper /etc/wp_supplicant/wp_supplicant.conf file and this was just fine.
In all cases, doing an ipconfig shows wlan0 information but no ip address.
For the record I'm using an ActionTec modem and have rebooted it a couple of times.
Now I did hear there was a possible bad hardware in the RBP 3 Mod B, but it seems to manifest itself as not being able to even discover the Wi-Fi devices. Mine does that just fine, but won't connect.
Any helpful hints would be fine, please remember this is NOT the version with the wi-fi dongle. This is the Raspberry Pi3 Mod B loaded with Raspberry Jessie with updates/upgrades.
Thank you for your help in advance.
Korky
KG5NNA
drgeoff
Re: Raspberri Pi 3 Mod B Wi-Fi Won't Connect
Thu Sep 21, 2017 8:54 am
If you truly meant WEP rather than mistakenly typing it instead of WPA, read viewtopic.php?f=91&t=193685
Quis custodiet ipsos custodes?
kg5nna
Fri Sep 22, 2017 1:57 am
That link did not help.
However, I did switch to WPA2 and re-configured the wpa_supplicant.conf file, rebooted and it worked.
However, most sites now won't completely load and give an error in Chromium "AwSnap"... wont work with cnn.com for instance. However the RaspberryPi.org page works fine.
