I would really appreciate your replies, thanks!
What wrong with that statement is that it is wrong. Tyre circumference changes with temperature. Not by much, but it definitely changes. Probably not enough to affect a speedo as long as the tyre is in its operating range.Heater wrote: ↑Tue Sep 19, 2017 9:03 amThere are times when the only way to go is to do the experiments. There are so many variables here that I very much doubt you will get a realistically accurate calculation.
Hmmm....wait a minute. No matter what the pressure in the tire, no matter what the load on the wheel, no matter how squished down it gets (distance from axle to road) the distance around the outside of the tire remains constant (Ignoring a bit of thermal expansion) Even if it's not very round anymore. In order for the wheel to go around once, the outside of the tire has to get back to it starting point. If that were not the case the tire would get badly ripped up.
Ergo, the distance traveled by the car, per wheel revolution, is the same at all pressures and loads.
What is wrong with that argument?
See, unresolved, debate here: https://physics.stackexchange.com/quest ... -of-my-car
Like I said. Time to do some experiments and take measurements.
And what is wrong with that statement is that it totally ignores the part where I said "Ignoring a bit of thermal expansion".What wrong with that statement is that it is wrong. Tyre circumference changes with temperature. Not by much, but it definitely changes.
That is to say, ignore the small effect of temperature, and basically agree with me. That is to say I am wrong and right at the same time!Probably not enough to affect a speedo as long as the tyre is in its operating range.
The R19 is the diameter of the metal rim NOT the diameter of the rubber...https://www.tirerack.com/tires/tiretech ... p?techid=7
Please read what I wrote again.You cannot ignore thermal expansion. P1V1/T1 = P2V2/T2 - Boyles law. And tyres get hot in use.
Nope. I'm just doing what physicists do all the time. Try to identify the major contributors to some effect and ignore details that don't have much effect. Thus making it easier to reason about and the maths much simpler.So basically, you statement was wrong because it ignores the laws of physics.
All speedometers l have used measure faster than actual speed, or maybe manufacturers are compensating to avoid too many speeding finesbensimmo wrote: ↑Tue Sep 19, 2017 12:18 pmTyre are a complex system, every part does a different thing.
Let alone the weight of the car will effect the tyres rotational circumference as would a bumpy surface compared to a flat one and of course wear and tear.
There is a good reason road cars speedometers measure slower than actual speed.
I've seen this too. I've also seen speed read from the ODBII port to be lower than that shown on the speedo.
I don't get it.
Sorry, I meant faster. :Oops: As in you're going 28mph but it says 30mph.gordon77 wrote: ↑Tue Sep 19, 2017 2:25 pmAll speedometers l have used measure faster than actual speed, or maybe manufacturers are compensating to avoid too many speeding finesbensimmo wrote: ↑Tue Sep 19, 2017 12:18 pmTyre are a complex system, every part does a different thing.
There is a good reason road cars speedometers measure slower than actual speed.![]()
I did say "To a first approximation" of course there would be a contact patch.One is that the area of contact would be zero, and there'd be no grip.
Not so. If I squish a tyres sidewalls together at some point around the wheel the tread will move further away from the rim at that point.The other is that (because the tyre has a steel carcass) the side-walls can flex so that the wheel-rim to tyre tread distance can shrink, but can't grow.
I'm assuming our tyre bead is firmly in contact with the rim at all times.If what you've drawn happened, there'd be an air-gap between side-wall and rim.
Now we are talking about something else.The tread flexes so that there's a large area in contact with the road (helps with braking as well as accelerating), and the tread grips the road as it flexes.
pootle wrote: ↑Tue Sep 19, 2017 12:14 pmThe distance covered per rev varies with many things, and particularly with tyre wear as well as the type off tyre fitted, and the load on the wheel. Also the driven wheels will turn very slightly faster than the non-driven wheels at constant speed (and more so as the speed rises).
Some cars have the capability to recalibrate the speedo / odo based on data from the satnav to allow for these variations.
I would expect variation in the range of 1% - 5% at least. (diameter of the tyre varies by at least 2% from new to worn).
How precise do you need to be?
Thanks all for replying to this post. What I concluded is:DougieLawson wrote: That's Montgomery Scott's "Law" from Star Trek: The Naked Time.
http://www.imdb.com/title/tt0708473/quotes
Albeit that Albert Einstein changed some of Newton's "Laws" of physics with his general theory of relativity.
Someone needs to ask Pirelli, McLaren, Mercedes or Red-Bull Racing (other F1 teams are eligible). They'll know the rules of how tyre pressures affect the size of their wheels.
BTW, you're also old enough to be Ms Rachel Riley's dad.
The tread is not a solid thing though. There are gaps in it (unless running slicks). The tread has the ability to flex in and out, so the effective circumference of the tyre can change.
