I'm actually trying to install owncloud now and maybe try to change its design later, but i have a problem, i have raspbian and raspberry pi 1 b and a 16 gb sd card. i have installed almost everything including phpmyadmin, mysql etc. but i cannot install php7.0-fpm, it says that there were errors while installing php7.0-fpm but it looked like it installed it, so i didnt worry about it too much. after that i installed nginx and apache2. After that I tried to write a simple index.php program, but it said error 403 forbidden and i could get to fix it yet. I'm trying to, but my raspberry pi crashed(idk what happened) and if i try to run a command like ls or a sudo command it says: Illegal instruction and it has happened twice, i had to reinstall raspbian and now it happened again. if i reboot it, it never comes back on and i have to reinstall raspbian again. i have it connected with ethernet, but i dont think i should do anything bad. and i was following this tutorial to install it:
https://www.stewright.me/2017/08/create ... -owncloud/ would love to get some help, because i had to reinstall raspbian 3 times now and same errors keep coming. I also tried to use a diffrent sd card, but that did not help.
