louellgat
Installing mysql-server problem - Raspbian Stretch
Sun Sep 17, 2017 2:04 pm
I'm trying to install mysql-server on my raspberry. I followed every tutorial in the internet and I always see a prompt that ask for root password. But when i try to install it, the installation doesn't ask for any password.
I also tried many ways to reset mysql password but it leads me to MariaDB > instead of mysql >
I hope someone can help me how to install this properly or reset the password of mysql. Thanks
fbe
Re: Installing mysql-server problem - Raspbian Stretch
Sun Sep 17, 2017 5:11 pm
[email protected] is authenticated via the "unix_socket" authentication plugin. You can login with
sudo mysql -u root
without a password.
bobcox4usa
Sun Sep 17, 2017 6:25 pm
I have same issue. And.. "mysql -u root" doesn't work for me. I also tried the mysql_secure_installation script. Anybody got more ideas?
Sun Sep 17, 2017 6:41 pm
That's not true unless you enable the unix_socket authorisation plugin with some special grants.
https://mariadb.com/kb/en/library/authe ... ix-socket/
which with my security hat on looks like a massive exposure.
fbe
Sun Sep 17, 2017 8:02 pm
It's true for new installations on stretch. Therefore the installation doesn't ask for a root password.
Sun Sep 17, 2017 10:01 pm
What an amazingly bad configuration decision by the Debian folks or the RPF folks. It was bad enough in the past where dpkg requested a root password and then generated a file with a "maintenance" password.
bobcox4usa
Mon Sep 18, 2017 2:18 am
I don't really care if the installation asks for a root password or not, as long as mysql -u root (-r) works and the mysql_secure_installation script works such that I can add a password after installation. Right now it's a brick.
heeed
Mon Oct 02, 2017 1:25 pm
Had this issue pop up when helping a friend out.
As dougie pointed out, mariadb by default authenticates against the current user. This can be seen by only being able to log in the database console from the root user account. This is regardless of what password you may set via mysql_secure_install.
This behaviour can be reverted to how it was before by:
sudo mysql -u root
MariaDB [none] use mysql;
MariaDB [mysql] update user set plugin='' where User='root';
MariaDB [mysql] flush privileges;
MariaDB [mysql]\q
This was adapted from: https://stackoverflow.com/questions/308 ... ord-prompt
cheddy
Thu Nov 22, 2018 7:08 pm
The previous post omitted the most important bit. After doing as suggested then enter:
# mysql_secure_installation
That installation script will allow you to change the root password, among other things.
fbe
Thu Nov 22, 2018 9:04 pm
Use the SET PASSWORD statement in mysql (https://mariadb.com/kb/en/library/set-password/) to change the root password instead.
Reading mysql_secure_installation is more useful than executing it. You get some exercises in SQL and you might figure out, that all other things are not needed after MariaDB installation from Raspbian packages.
