cpcnw
Network Stats
Wed Sep 13, 2017 10:43 am
What is the most reliable way to get eth0 stats? I am a bit confused about the disparity between the following...
# cat /proc/net/dev
           bytes    packets
eth0:  699814    5578
# cat /sys/class/net/eth0/statistics/rx_packets
5598
# ifconfig
eth0: RX packets 5623  bytes 703775 (687.2 KiB)
If you don't know what you want, you end up with a lot you don't!
cpcnw
Re: Network Stats
Wed Sep 13, 2017 10:54 am
I was just thinking...
Each time I executed these commands I was doing so over SSH
Maybe that's my answer :)
Re: Network Stats
Wed Sep 13, 2017 10:58 am
Yes, the number of bytes and packets will increase between each command.
Return to “Arch”
