countxerox
daemonizing node js
Tue Sep 12, 2017 8:14 pm
Hi, so far I've been running the node app like ...
node app.js
and that works but the command is blocked and if I log off the pi the app dies. So I'm looking for ways to run it in the background?
I found this post and tried to set up a service...
sudo nano /etc/systemd/system/myapp.service
[Unit]
Description=My app
[Service]
ExecStart=/home/pi/proj/app.js
Restart=always
User=nobody
Group=nobody
Environment=PATH=/usr/bin:/usr/local/bin
Environment=NODE_ENV=production
WorkingDirectory=/home/pi/proj
[Install]
WantedBy=multi-user.target
but the service won't start.
sudo systemctl daemon-reload
sudo systemctl start myapp
journalctl -u myapp
Sep 12 19:45:46 raspberrypi systemd[14880]: myapp.service: Failed at step GROUP spawning /home/pi/proj/app.js:
Sep 12 19:45:47 raspberrypi systemd[1]: myapp.service: Main process exited, code=exited, status=216/GROUP
Sep 12 19:45:47 raspberrypi systemd[1]: myapp.service: Unit entered failed state.
Sep 12 19:45:47 raspberrypi systemd[1]: myapp.service: Failed with result 'exit-code'.
Sep 12 19:45:47 raspberrypi systemd[1]: myapp.service: Service hold-off time over, scheduling restart.
Sep 12 19:45:47 raspberrypi systemd[1]: Stopped My app.
Is this the right way to run a node js server?
I can see there's a problem with the group, I don't know what this means?
countxerox
Re: daemonizing node js
Tue Sep 12, 2017 10:16 pm
OK it works now, I made some changes to myapp.service...
[Unit]
Description=My app
[Service]
ExecStart=/usr/local/bin/node /home/pi/proj/app.js
Restart=always
RestartSec=10
#User=nobody
#Group=nobody
#Environment=PATH=/usr/bin:/usr/local/bin
Environment=NODE_ENV=production PORT=5000
[Install]
it seems like /usr/local/bin/node should be defined with Environment= somehow?
Tue Sep 12, 2017 11:58 pm
I think it's fine to use the full path to your node executable like that.
I have many versions of node on my machines installed with nvm. I have the full path to the node version I want to use in my service files.
