niels
RPi shuts down by it self
Fri Oct 05, 2012 3:43 pm
My RPi shuts down by it self after a few minutes of running. All lights exept PMR turnes of and the signal (HDMI, SSH, etc.) is lost.
I have tried different SD cards and different OS's. I have also tried the same SD and OS combinations with another RPi, where it runs perfectly.
I think it's a hardware error, but what do you think and how do I fix it?
Best from Niels
mahjongg
Re: RPi shuts down by it self
Fri Oct 05, 2012 4:17 pm
Does your fuse (F3, on the back of the board, near the power input) gets hot?
If it does, give it a few days to recover from being blown, and then try again.
joan
Fri Oct 05, 2012 4:18 pm
Can you isolate the fault? Try without screen attached etc. The fault could be with the Pi, power supply, or other connected device.
thogue
Fri Oct 05, 2012 4:50 pm
Have a decent mutlimeter? you could check the polyfuse with a ohm meter.
Also monitoring your pis voltage could be a good started (via TP1 / TP2 )
Check out PSU output while your at it :)
