satimis
How to remove the black border?
Thu Sep 07, 2017 4:23 pm
Hi all,
I tried to remove the border running;
$ sudo nano /boot/config.txt
uncomment disable_overscan=1
-> save and exit
$ systemctl reboot
to reboot Raspbian
After booting the black border is still there.
Please help. Thanks
Regards
satimis
gordon77
Re: How to remove the black border?
Thu Sep 07, 2017 4:37 pm
Try uncommenting and changing these values in config.txt
overscan_left=20
overscan_right=12
overscan_top=10
overscan_bottom=10
satimis
Fri Sep 08, 2017 3:31 am
overscan_left=20
overscan_right=12
overscan_top=10
overscan_bottom=10
Thanks for your advice.
Tried following configuration;
1)
disable_overscan=1
overscan_left=20
overscan_right=12
overscan_top=10
overscan_bottom=10
2)
#disable_overscan=1
overscan_left=20
overscan_right=12
overscan_top=10
overscan_bottom=10
3)
disable_overscan=1
overscan_left=-20
overscan_right=-12
overscan_top=-10
overscan_bottom=-10
4)
#disable_overscan=1
overscan_left=-20
overscan_right=-12
overscan_top=-10
overscan_bottom=-10
all without result. The black border is still there without any alternation.
I'm running 24" LCD display with 1920x1080 resolution.
Regards
satimis
ab1jx
Fri Sep 08, 2017 4:56 am
I don't know, the disable_overscan=1 should have done it as far as I know. Does the monitor work without a border on other things? I have a white border of about 1/2 inch but I've only used this monitor with the Pi. It's odd, it appears, then as soon as something covers it up it seems to go away.
tvservice -s probably won't show a lot other than the mode, but you could try tvservice -d > somefile.bin. That should dump the monitor's Extended Display Identification Data (EDID) to a binary file. Then try parse-edid on it. EDID has been through several revisions, so parse-edid doesn't always work. There are some online EDID parsers I think, or other programs to try no doubt. The EDID parsing built into the Pi only works with recent monitors, I have a couple it doesn't work with. My Dell S2409 from 2009 doesn't work with it.
There's also a "roll your own" video mode called CVT, there's a sticky for that at viewtopic.php?f=29&t=24679&hilit=cvt
R_a_s_s_b_e_r_y
Sun Aug 18, 2019 12:47 am
Try to use negative numbers not positive in /boot/config.txt this helped me ;)
W. H. Heydt
Sun Aug 18, 2019 5:16 am
I would suggest checking the *entire* contents of config.txt. If a command appears in it more than once, the final effect will be that of the last occurrence. It's pretty easy, when adding things at the end to override a previous version of the same directive and then if you change the earlier copy, wonder why it didn't work.
Yodhan
Sat Jun 06, 2020 3:05 pm
I was also having the same problem at the beginning. I tried various method , after I made a change in display settings. it worked for me.
check this article. https://www.hackerstec.com/raspberry-pi ... eshooting/
It has a tutorial on how to change screen settings and remove black border
eddykacak
Mon Jun 15, 2020 7:15 am
Hi all, I registered just to post this.
Try disable this line = #hdmi_safe=1
Worked for me.
trezhunter
Fri Jul 10, 2020 3:20 am
You have conflicting parameters in your config.txt.
You can't disable overscan, AND try to use overscan settings.
Comment disable_overscan=1 back out again.. Just use the overscan settings.
As another user mentioned, black borders mean you need to use negative numbers.
Try something like:
overscan_left=-50
overscan_right=-50
overscan_top=-50
overscan_bottom=-50
then reboot..
