dgordon42
Re: Booting Stretch to the CLI with NumLock on [Solved]
Sun Sep 03, 2017 12:10 pm
Has anyone found a way to boot a fresh copy of Raspbian Stretch to the CLI with NumLock on?
In Jessie, I could set (uncomment) "LEDS=+num" in '/etc/kbd/config' to do this, but the '/etc/kbd/' directory is not present in Stretch by default.
I have tried adding "LEDS=+num" to the '/etc/default/console-setup' and '/etc/default/keyboard' files, but no luck.
I have installed "numlockx", but that only works with the GUI.
Thanks,
Dave.
Martin Frezman
Sun Sep 03, 2017 12:20 pm
Have you tried creating that directory/file? I know it is basic, but sometimes this works.
Maybe it was just an oversight on the part of the Stretch-makers - not creating the directory.
If this post appears in the wrong forums category, my apologies.
dgordon42
Sun Sep 03, 2017 12:48 pm
Martin Frezman wrote:Have you tried creating that directory/file? ...
Thanks for the reply.
The 'kbd' package is installed in Stretch by default, but the '/etc/kbd/' directory is deliberately left out. There is some information in the file '/usr/share/doc/kbd/NEWS.Debian.gz'. This file suggests using the 'console-setup' package to set up the keyboard, but I cannot find a way using this package to set the NumLock to on.
The NEWS.Debian file also says that if you upgrade to Stretch, the '/etc/kbd/*' will exist, but suggests that you move your settings and delete it, but it dose not say to where.
I do intend to try creating '/etc/kbd/config' with just a "LEDS=+num" entry, but I thought I would ask here first to see if there is a more up to date method.
Thanks,
Dave.
Martin Frezman
Sun Sep 03, 2017 1:50 pm
So, that's a "no", right?
dgordon42
Sun Sep 03, 2017 2:03 pm
Martin Frezman wrote:So, that's a "no", right?
Correct.
The '/usr/share/doc/kbd/NEWS.Debian.gz' file in Stretch recommends not keeping the '/etc/kbd/' directory in Stretch, but does not ban it.
As having the machine boot up with NumLock off is not a major problem, I plan on waiting a day or so to see if there is a "Stretch" way of doing this. If I don't get any answers, I was planing on creating a '/etc/kbd/config' file anyway to see what happens.
Thanks,
Dave.
dgordon42
Sat Sep 09, 2017 6:25 pm
Tried creating the '/etc/kbd/config' file with the line "LEDS=+nums", but the Pi still boots with NumLock off.
Dave.
gkaiseril
Sat Sep 09, 2017 8:45 pm
You can add the appliction numlockx and then add "numlockx 0n" to your startup script.
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
dgordon42
Sun Sep 10, 2017 11:50 am
gkaiseril wrote:You can add the appliction numlockx and then add "numlockx 0n" to your startup script.
I have numlockx installed, but that only works in the X GUI
I am now using the script suggested in 'setleds' man page, and calling it with '@reboot' in crontab, and the Pi is booting to the CLI with NumLock on.
I am marking this Solved.
Thanks for the replies,
Dave.
MikeZWorx
Wed Jan 17, 2018 1:33 am
To turn Numlock on at startup (on Raspbian Stretch) :
sudo apt-get install numlockx
sudo nano /usr/share/lightdm/lightdm.conf.d/01_debian.conf
At the end, add
greeter-setup-script=/usr/bin/numlockx on
Save. Reboot. Yer Done.
Credit: unix.stackexchange.com/questions/375920/numlock-on-startup-on-linux-mint-18-2
chris87p
Fri Aug 03, 2018 9:24 am
I'm going to write out step by step instructions, because I had trouble figuring out what the actual solution was. One solution works only for the CLI and one works only for the GUI. It looks like they both set Num Lock independently when they boot. I just did both.
To Boot to CLI with Num Lock On
Use your rc.local file to set Num Lock to on during boot. Edit the rc.local! file using:
sudo  nano /etc/rc.local
Insert the following after the comments and before exit 0.
INITTY=/dev/tty[1-8]
for tty in $INITTY; do
     setleds -D +num < $tty
done
Now Num Lock will come on when you boot into the CLI. But it will turn off again when the Destkop/GUI boots.
To Boot to Desktop/GUI with Num Lock On
I didn't have to add anything to my default file to get numlockx to auto-start. But if you have trouble, you should check out MikeZWorx's post above.
Return to “Raspbian”
