daveraver
usbmount doesnt work
Fri Sep 01, 2017 9:03 pm
after upgrading to strech, usbmount doesnt work, and usb hdd device can only be mounted manually on console. has anybody experimented the same issue?
thanks
daveraver
Re: usbmount doesnt work
Sat Sep 02, 2017 1:17 pm
I little deceptioned with raspbian lite 9, some of the configurations for jessie doesnt work with stretch. Where to learn about new stretch setup ?
DirkS
Sat Sep 02, 2017 1:24 pm
Probably in various places...
Which setups / configurations do you have problems with?
(Of course there's always Google. Adding Raspbian Stretch or Debian Stretch to any search may find some good sources)
klricks
Sat Sep 02, 2017 1:29 pm
Auto mounting of a USB 'stick'' worked fine for me in Stretch same as Jessie.
mina
Sun Sep 03, 2017 11:51 am
thanks
Yes, see https://github.com/rbrito/usbmount/issues/2
Maintainer of MoodleBox, a Moodle server on Raspberry Pi
Swampy42
Fri Sep 08, 2017 5:47 pm
For me usbmount doesn't work in Raspbian Stretch too.
Because I must use usb automount for my webradio I saw this solution:
https://raspberrypi.stackexchange.com/q ... thout-uuid
(last entry for now)
It's not as easy as usbmount, but it works for me.
I only had to change the rights:
sudo chmod 0777 /usr/local/bin/cpmount
Linux is like wigwam: no Gates, no Windows and Apache inside.
yy502
Thu Sep 14, 2017 10:31 pm
Here's my solution based on the one mentioned in previous post.
sudo apt-get install pmount
Add the following to /etc/udev/rules.d/usbstick.rules
ACTION=="add", KERNEL=="sd[a-z][0-9]", TAG+="systemd", ENV{SYSTEMD_WANTS}="usbstick-handler@%k"
Add the following to /lib/systemd/system/usbstick-handler@.service
[Unit]
Description=Mount USB sticks
BindsTo=dev-%i.device
After=dev-%i.device
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStart=/usr/local/bin/automount %I
ExecStop=/usr/bin/pumount /dev/%I
Add the following to /usr/local/bin/automount
#!/bin/bash
PART=$1
FS_LABEL=`lsblk -o name,label | grep ${PART} | awk '{print $2}'`
if [ -z ${FS_LABEL} ]
then
    /usr/bin/pmount --umask 000 --noatime -w --sync /dev/${PART} /media/${PART}
else
    /usr/bin/pmount --umask 000 --noatime -w --sync /dev/${PART} /media/${FS_LABEL}_${PART}
fi
sudo chmod +x /usr/local/bin/automount
Reboot.
The mount points/folders names will be in the format of /media/<PartitionLabel>_<sdxy>. In case a partition has no label, it will just be /media/<sdxy>.
I normally label my USB drives with their capacity. e.g. 8G, 16G. When I plug in multiple USB disks with the same label, I can still distinguish them as, for example:
/media/500G_sdb1
/media/500G_sdc1
I will update the automount script to ignore root partition on USB drive, if not using SD card for root, so the USB root partition is not mounted twice, i.e. at / and /media/xxx
micksulley
Tue Oct 03, 2017 3:03 pm
This link https://github.com/rbrito/usbmount/issues/2 has the solution.
Edit /lib/systemd/system/systemd-udevd.service and change the line
MountFlags=slave
to
MountFlags=shared
then reboot
blackhawk60
Tue Jan 30, 2018 6:34 pm
Thanks! Your response helped me a lot.
(I even registered for posting this)
AlbertB
Fri Mar 02, 2018 2:46 pm
I am on Stretch as well and had the same issue. usbmount won't work out of the box. To fix this issue I cloned the newest version (0.0.24) from github and built a new Debian package myself.
Try this:
• As we are going to create a Debian package on our own we have to install debhelper package
sudo apt-get install debhelper
• Clone usbmount from github
git clone https://github.com/rbrito/usbmount.git
• Creata Debian package
cd usbmount
sudo dpkg-buildpackage -us -uc -b
• Install newly created package
cd ..
sudo apt install  ./usbmount_0.0.24_all.deb
• Reboot
sudo shutdown -r now
eschik123
Mon Aug 26, 2019 5:15 pm
I know this is an old post.. but I figured I would update the answer that worked for me in Buster:
https://raspberrypi.stackexchange.com/q ... ot-working
Return to “Raspberry Pi OS”
