DareDrop
Datetime issue
Thu Aug 31, 2017 5:05 pm
I am using a DHT22 sensor to log temp and humidity and save it to a csv file.
What I need is a date for each read in this format MM/DD/YYYY
And the time as HH:MM:SS
Been try to work this out, have looked and at ref and still can not get it.
Pls help
Re: Datetime issue
Thu Aug 31, 2017 5:17 pm
What software are you using to read the sensor? What language is it written in? Where did you download it from?
DareDrop
Re: Datetime issue
Thu Aug 31, 2017 5:23 pm
Sorry should have put that in, my bad.
Raspi 3
Raspbain Stetch updated Upgraded
Python
Re: Datetime issue
Thu Aug 31, 2017 5:52 pm
Post your python code in [code]... your stuff goes here ...[/code] tags. As that makes the difference between
from datetime import datetime
very_True=True
iso_format=True
silly_american_fmt=very_True
date_str = datetime.now()
yyyy_mm_dd = datetime.strftime(date_str, "%Y-%m-%d %H:%M:%S")
american_fmt = datetime.strftime(date_str, "%m/%d/%Y %H:%M:%S")
if silly_american_fmt == True:
print (american_fmt)
else:
print (yyyy_mm_dd)
And
very_True=True
iso_format=True
else:
  print (yyyy_mm_dd)
DareDrop
Re: Datetime issue
Thu Aug 31, 2017 6:32 pm
very_True=True
iso_format=True
Not sure what this is, would you explain pls
This is the format get set up Date in 2 forms, OK
else:
print (yyyy_mm_dd)
This is the print statement OK
bensimmo
Re: Datetime issue
Thu Aug 31, 2017 6:53 pm
He is showing you and example between using 'code tags' and not using them, it's one of the format option when posting on here.
He wants you to post your code.
DareDrop
Re: Datetime issue
Thu Aug 31, 2017 9:14 pm
import time
import datetime
import csv
import sys
import Adafruit_DHT
sensor = Adafruit_DHT.DHT22
pin = 4
with open('dht.csv', 'w') as csv_file:
    dhtwriter=csv.writer(csv_file)
    dhtwriter.writerow(['Time', 'Tempemperature (F)', 'Humidity (%)'])
    while True:
        reading_time = datetime.datetime.now()
        humidity, temperature = Adafruit_DHT.read_retry(sensor, pin)
        if humidity is not None and temperature is not None:
            time_now = datetime.datetime.now()
            Tempemperature = ('Temp={0:0.1f}*C')
            print('Time: {0} Tempemperature: {1} Humidity: {2}'.format(time_now, temperature, humidity))
            dhtwriter.writerow([time_now, temperature, humidity])
            time.sleep(600)
Here is the code.
pcmanbob
Re: Datetime issue
Thu Aug 31, 2017 9:48 pm
This shows you how to get the date and time or just the time.
import time
datetime = time.strftime("%d-%m-%Y %H:%M:%S")
print datetime
time = time.strftime("%H:%M:%S")
print time
results look like this
31-08-2017 22:47:36
22:47:36
Re: Datetime issue
Fri Sep 01, 2017 12:52 am
Change these lines
to
            time_now = time_now.strftime("%m/%d/%Y %H:%M:%S")
NOTE that ISO dates (2017-09-01) naturally sort in date order. American dates (09/01/2017) need special handing to sort correctly (Excel can do that, because it converts your format to a day number internally).
BTW, if you want temps in °F rather than °C change
to
        temperature = (temperature*1.8)+32
DareDrop
Re: Datetime issue
Fri Sep 01, 2017 12:54 am
>>> import time
>>> print datetime
SyntaxError: Missing parentheses in call to 'print'
>>> print (datetime)
31-08-2017 20:47:23
>>> print time
>>> print(time)
20:49:44
This works with the change to the print statement.
Re: Datetime issue
Fri Sep 01, 2017 12:58 am
That's a feechur of python2 code being run with python3.
DareDrop
Re: Datetime issue
Fri Sep 01, 2017 1:52 am
import time
import datetime
import csv
import sys
import Adafruit_DHT
pin = 4
dhtwriter.writerow(['Date', 'Time', 'Tempemperature (F)', 'Humidity (%)'])
while True:
sensor_date = time.strftime("%m-%d-%Y")
sensor_time = time.strftime("%H:%M:%S")
Humidity = ('Humidity={1:0.1f}%')
print('Date: {0} Time: {1} Tempemperature: {2} Humidity: {3}'.format(sensor_date,
sensor_time, temperature, humidity))
dhtwriter.writerow([sensor_date, sensor_time, temperature, humidity])
time.sleep(4)
New code
pi@raspisensor:~/Adafruit_Python_DHT/examples $ sudo python simpletest_h.py
Date: 08-31-2017 Time: 21:44:19 Tempemperature: 23.7000007629 Humidity: 44.5
Date: 08-31-2017 Time: 21:44:24 Tempemperature: 23.6000003815 Humidity: 44.9000015259
Date: 08-31-2017 Time: 21:44:28 Tempemperature: 23.6000003815 Humidity: 44.9000015259
Date: 08-31-2017 Time: 21:44:33 Tempemperature: 23.6000003815 Humidity: 44.9000015259
Date: 08-31-2017 Time: 21:44:38 Tempemperature: 23.6000003815 Humidity: 44.9000015259
Date: 08-31-2017 Time: 21:44:45 Tempemperature: 23.6000003815 Humidity: 44.9000015259
output
now i just need to format the numbers.
