dwhite0
Ubuntu cross-compile copy to SD doesn't seem to work
Thu Aug 31, 2017 5:18 am
I am trying to cross compile a new driver into the kernel, and I am running into a problem following the instructions according to:
https://www.raspberrypi.org/documentati ... uilding.md
First, if I do:
sudo make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- INSTALL_MOD_PATH=mnt/ext4 modules_install
I get
make: arm-linux-gnueabihf-gcc: Command not found
So putting the whole path for my compiler in the command line it passes that error. (wasn't a problem for my build- the tools are in my path.
So after that I get:
sudo make ARCH=arm CROSS_COMPILE=/home/dwhite/rpi/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin/arm-linux-gnueabihf- INSTALL_MOD_PATH=mnt/ext4 modules_install
ln: failed to create symbolic link 'mnt/ext4/lib/modules/4.9.46-v7+/source': Operation not permitted
Makefile:1221: recipe for target '_modinst_' failed
make: *** [_modinst_] Error 1
Any ideas of why the symbolic link can't be created? It creates directories first, then fails.
Thanks in advance.
Darin
Return to “Other”
