I just want to enter a 5 digit code. If it is correct it should change a global variable (alarm) and when it is wrong it should restart. I have written two different codes maybe someone can help me with finding a solution. The code is attached.
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
MATRIX = [ [1, 2 ,3 , 'A'],
[4, 5, 6, 'B'],
[7, 8, 9, 'C'],
['*',0,'#','D'] ]
ROW = [21,4,27,6]
COL = [5,13,19,26]
code = [1,2,3,4,"#"]
digits= []
global alarm
for j in range(4):
GPIO.setup(COL[j], GPIO.OUT)
GPIO.output(COL[j], 1)
for i in range(4):
GPIO.setup(ROW[i], GPIO.IN, pull_up_down = GPIO.PUD_UP)
try:
while(True):
for j in range(4):
GPIO.output(COL[j],0)
for i in range(4):
if GPIO.input(ROW[i]) == 0:
print MATRIX[i][j]
key = MATRIX[i][j]
while(GPIO.input(ROW[i]) == 0):
pass
GPIO.output(COL[j],1)
if key == "*" && if len(digits) > 0:
del digits[-1]
length=len(digits)
lcd.clear()
for i in length:
lcd.message("*")
else:
digits.append(key)
lcd.message("*")
if len(digits)==4:
if digits == code:
if alarm=0:
lcd.message("CODE CORRECT")
time.sleep(1)
alarm = 1
lcd.clear()
lcd.message("SYSTEM ARMED")
elif alarm >0
time.sleep(1)
alarm = 0
lcd.clear()
lcd.message("SYSTEM UNARMED")
else:
lcd.clear()
lcd.message("Wrong Code")
time.sleep(0.5)
lcd.clear()
digits=[]
except KeyboardInterrupt:
GPIO.cleanup()Code: Select all
from pad4pi import rpi_gpio
import time
import Adafruit_CharLCD as LCD
# Raspberry Pi pin setup
lcd_rs = 25
lcd_en = 24
lcd_d4 = 23
lcd_d5 = 17
lcd_d6 = 18
lcd_d7 = 22
lcd_backlight = 2
# Define LCD column and row size for 16x2 LCD.
lcd_columns = 16
lcd_rows = 2
lcd = LCD.Adafruit_CharLCD(lcd_rs, lcd_en, lcd_d4, lcd_d5, lcd_d6, lcd_d7, lcd_$
KEYPAD = [
[1,2,3,"A"],
[4,5,6,"B"],
[7,8,9,"C"],
["*",0,"#","D"]
COL_PINS = [5,13,19,26] # BCM numbering
ROW_PINS = [21,4,27,6] # BCM numbering
factory = rpi_gpio.KeypadFactory()
# Try factory.create_4_by_3_keypad
# and factory.create_4_by_4_keypad for reasonable defaults
keypad = factory.create_keypad(keypad=KEYPAD, row_pins=ROW_PINS, col_pins=COL_PINS)
def printKey(key):
while 1:
if len(code)==0:
lcd.clear()
code=[]
lcd.message("ENTER CODE:")
print("Enter your code: ")
print(key)
if key == "*" && len(code)>0:
del code[-1]
length=len(code)
lcd.clear()
for i in length:
lcd.message("*")
else:
lcd.message("*")
time.sleep(0.4)
code.append(key)
if len(code) == 5:
print(code)
print("\n")
if code == [1,2,3,4,'#']:
print("Very good")
lcd.clear()
lcd.message("Code accepted")
if alarm == 0:
alarm=1
time.sleep(1)
lcd.clear()
elif alarm > 0:
alarm = 0
time.sleep(1)
lcd.clear()
else:
print("Wrong Code")
time.sleep(1)
code=[]
lcd.clear()
# printKey will be called each time a keypad button is pressed
keypad.registerKeyPressHandler(printKey)
Thank you so much already
