tonyrhill
5 volt relay with only 2 inputs
Tue Aug 29, 2017 3:22 pm
Hi, I have bought a relay board 5V DC One 1 Channel Relay Module for Arduino Raspberry Pi Pic AVR UK
However there are only 2 input terminals GND and UCC. All the articles I see require three wires.
How can I wire this up to operate please
pcmanbob
Re: 5 volt relay with only 2 inputs
Tue Aug 29, 2017 6:51 pm
Hi.
It sounds like you have purchased just a relay on a board with no driver circuitry, my be if you post a link to were you got it or a good quality picture we might be able to confirm what you have purchased.
OutoftheBOTS
Tue Aug 29, 2017 8:51 pm
post a link to the board that you brought
tonyrhill
Wed Aug 30, 2017 10:37 am
Hi thanks for response. Please see attched picture. I bought it off eBay and oddly enough the only one they have now have 3 inputs..
pcmanbob
Wed Aug 30, 2017 1:12 pm
So from what I can see from you picture it looks like this is some sort of timed relay, so powering it will result in it activating for the time set by the jumpers and the trim pot.
This is not a general purpose relay board that you might switch via the gpio on your pi, but rater a specialist relay board that does its own timing once powered. have you just tried apply 5v to the terminals and seeing what the relay does ?
if you wanted to activate this from your pi it would be possible but you would need to use a transistor to allow the gpio to switch the 5v to power the relay, the relay would then just do what ever it has been set up to do with no control over it by the pi.
klricks
Wed Aug 30, 2017 1:19 pm
That is a time delay relay. Probably not what you wanted. When power is applied to the input the relay will operate after a delay. Time delay is adjusted by a pot on the board.
This is a similar board. Watch the YT link to see how these operate. http://www.ebay.com/itm/New-Delay-Timer ... 2548.l4275
tonyrhill
Wed Aug 30, 2017 2:26 pm
Many thanks for that.
I will hang on to them. I have ordered some new ones. Fortunately they are fairly cheap and I bought them some time ago.
gordon77
Wed Aug 30, 2017 3:06 pm
This looks like the 12v version with some explanation...
https://www.tindie.com/products/mmm999/ ... -circuit-/
