I have been messing with OpenVG for about a year now on and off. The learning curve is very steep and there are a lot of different concepts to learn.
just getting a working context and surface can be a pain sometimes and i created a handy template that is simple for the basic programmer (like myself) that gets you up and running quickly. I thought I would share the code which is all in one file for ease and I have also shared my makefile below.
#include <iostream>
#include "bcm_host.h"
#include "EGL/egl.h"
#include "VG/openvg.h"
using namespace std;
BCM STUFF
EGL_DISPMANX_WINDOW_T nativewindow;
uint32_t display_width;
uint32_t display_height;
int startBCM() {
//get the bcm setup
bcm_host_init();
//the variables
DISPMANX_ELEMENT_HANDLE_T dispman_element;
DISPMANX_DISPLAY_HANDLE_T dispman_display;
DISPMANX_UPDATE_HANDLE_T dispman_update;
DISPMANX_TRANSFORM_T dispman_trans;
VC_RECT_T dst_rect;
VC_RECT_T src_rect;
// create an EGL window surface, passing context width/height
int success = graphics_get_display_size(0 /* LCD */,
&display_width, &display_height);
if ( success < 0 )
return 1;
// You can hardcode the resolution here:
//display_width = 640;
//display_height = 480;
dst_rect.x = 0;
dst_rect.y = 0;
dst_rect.width = display_width;
dst_rect.height = display_height;
src_rect.x = 0;
src_rect.y = 0;
src_rect.width = display_width << 16;
src_rect.height = display_height << 16;
dispman_display = vc_dispmanx_display_open( 0 /* LCD */);
dispman_update = vc_dispmanx_update_start( 0 );
dispman_element = vc_dispmanx_element_add ( dispman_update,
dispman_display, 0/*layer*/, &dst_rect, 0/*src*/,
&src_rect, DISPMANX_PROTECTION_NONE, 0 /*alpha*/,
0/*clamp*/, dispman_trans/*transform*/);
nativewindow.element = dispman_element;
nativewindow.width = display_width;
nativewindow.height = display_height;
vc_dispmanx_update_submit_sync( dispman_update );
//DEBUG PRINT SCREEN DIMENSIONS
cout << "Width : " << display_width << endl;
cout << "Height : " << display_height << endl;
return 0;
EGL stuff
EGLDisplay eglDisplay;
EGLSurface eglSurface;
EGLContext eglContext;
int startEGL() {
//lets get EGL up and running using the native window
//we use egl to create a context for OpenVG to use
eglDisplay = eglGetDisplay(EGL_DEFAULT_DISPLAY);
if(eglDisplay == EGL_NO_DISPLAY) {
cout << "Error Creating EGL display!" << endl;
return 1;
//initialise EGL
if(eglInitialize(eglDisplay, NULL, NULL) != EGL_TRUE) {
cout << "Error Initialising EGL display!" << endl;
return 2;
//Create an EGL config for what we want
EGLConfig config;
EGLint numConfigs;
EGLint configs[] = {
EGL_RED_SIZE, 8,
EGL_GREEN_SIZE, 8,
EGL_BLUE_SIZE, 8,
EGL_ALPHA_SIZE, 8,
EGL_RENDERABLE_TYPE, EGL_OPENVG_BIT,
EGL_SURFACE_TYPE, EGL_WINDOW_BIT,
EGL_NONE
//Choose the config to use
if(eglChooseConfig(eglDisplay, configs, &config, 1, &numConfigs) == EGL_FALSE) {
cout << "Error With EGL config!" << endl;
return 3;
//tell EGL we are using OpenVG
//IMPORTANT THIS MUST BE DONE BEFORE CREATING THE CONTEXT!
if(eglBindAPI(EGL_OPENVG_API) != EGL_TRUE) {
cout << "Error setting api to openvg!" << endl;
return 7;
//Now lets create the rendering context
eglContext = eglCreateContext(eglDisplay, config, EGL_NO_CONTEXT, NULL);
if(eglContext == EGL_NO_CONTEXT) {
cout << "Error creating context!" << endl;
return 4;
//Create the window surface
eglSurface = eglCreateWindowSurface(eglDisplay, config, &nativewindow, NULL);
if(eglSurface == EGL_NO_CONTEXT) {
cout << "Error creating surface!" << endl;
return 5;
//make context current
if(eglMakeCurrent(eglDisplay, eglSurface, eglSurface, eglContext) != EGL_TRUE) {
cout << "Error making context current!" << endl;
return 6;
return 0;
Open VG Setup
int startVG() {
//set the screen clear colour
VGfloat color[4] = {0.2f,0.2f,0.2f,1.0f};
vgSetfv(VG_CLEAR_COLOR, 4, color);
return 0;
Open VG Drawing
int drawVG() {
//clear the screen
vgClear(0, 0, (VGint)display_width, (VGint)display_height);
DO ALL THE DRAWING FROM HERE
return 0;
Main Program Start
int main(int argc, char *argv[]) {
//start up bcm and check for error
if(startBCM() != 0) {
cout << "Error starting BCM!" << endl;
return 1;
//setup EGL for our context
if(startEGL() != 0) {
cout << "Error starting EGL!" << endl;
return 2;
//Start OpenVG
startVG();
//Program loop
int count = 0;
while(count < 600) {
//Drawing
drawVG();
//swap the buffers
eglSwapBuffers(eglDisplay, eglSurface);
//Increment timer thinking 60hz refresh here
count++;
//cleanup
eglDestroySurface(eglDisplay, eglSurface);
eglDestroyContext(eglDisplay, eglContext);
eglTerminate(eglDisplay);
return 0;
}The Make File
all:
g++ -Wall clock.cpp -o clock -I/opt/vc/include -I/opt/vc/include/interface/vmcs_host -L/opt/vc/lib -lbcm_host -lEGL -lGLESv2 -lOpenVG
Hope someone finds it useful !!
