denniswage
fstab fails
Mon Aug 21, 2017 10:52 pm
fstab worked before I did apt-get dist-upgrade
Pretty sure I did apt-get dist-upgrade
proc /proc proc defaults 0 0
/dev/mmcblk0p1 /boot vfat defaults 0 2
/dev/mmcblk0p2 / ext4 defaults,noatime 0 1
/dev/sdb1 /mnt/usb ntfs-3g defaults 0 0
/dev/sda1 /mnt/usb2 ext4 defaults 0 0
The content of fstab above
sdb1 fails. sda1 mounts just fine.
mount /dev/sdb1 /dev/usb works.
mount -a also works.
This has worked fine until we had a power failure today, and it never booted up.
The fstab fail also causes the dhcpd.conf file to not assign an ip to eth0
Thanks,
totaly noob here.
tpylkko
Re: fstab fails
Tue Aug 22, 2017 9:43 am
Since systemd can mount the disks without fstab, I wonder if it could just be removed from Raspbian. I know it can be done on Debian.
In your case the failing mount is ntfs
Is there anything in the logs?
Uses
journalctl
NotRequired
Re: fstab fails
Tue Aug 22, 2017 11:15 am
What errors do you get? First you should make sure that ntfs-3g is installed:
sudo apt-get install ntfs-3g
If already installed, try reinstall:
sudo apt-get install --reinstall ntfs-3g
Last but not least, change fstab to let mount auto detect the file system:
/dev/sdb1 /mnt/usb auto defaults 0 0
Good luck :)
Please do not ask questions in private messages, they will not help others.
jahboater
Re: fstab fails
Tue Aug 22, 2017 11:17 am
Have you got "ntfs-3g" installed?
topguy
Re: fstab fails
Tue Aug 22, 2017 11:53 am
The powerfailure might be the cause.
Run "dmesg" command in a terminal and look for signs that mounting fails because of "dirty" filesystem.
I guess this is removable disks so you can take it to a windows machine and run a filesystem check and then plug it back in the Pi.
