jeclark2006
PI Zero W, has it both AP and Client connections?
Mon Aug 21, 2017 6:19 am
The Zero W supports WIFI and I thought briefly I had both AP and Client connections. But for some reason, I only see the interface in managed mode even though an invocation of 'hostapd' is running, and looks to have setup with 'wlan0' as its interface.
Is it possible to use both modes on the Zero W WIFI interface?
And if so, what are the config steps.
Thanks,
John Clark.
Re: PI Zero W, has it both AP and Client connections?
Mon Aug 21, 2017 2:16 pm
This is a doctor free zone.
B.Goode
Mon Aug 21, 2017 2:21 pm
It is certainly possible to use either.
But do you mean you want client and AP modes active concurrently?
jeclark2006
Tue Aug 22, 2017 7:48 pm
This describes how to setup the AP mode.
What I'm asking about is if anyone has setup for dual Client and AP mode. How this is done is using a second 'virtual' interface. One associated with client connectivity and one for the AP functionality.
I'm familiar with Atheros 802.11 devices, but that's not what is on the Zero W.
I do have things such that there is a wlan0 and a uap0 device. But from the log file there's a series of error messages, shown below.
Aug 20 19:17:16 das-boot dhcpcd[376]: uap0: IAID eb:4f:6c:be
Aug 20 19:17:16 das-boot dhcpcd[376]: uap0: IAID conflicts with one assigned to wlan0
Aug 20 19:17:16 das-boot dhcpcd[376]: uap0: carrier lost
I've tried manually setting the hw ethernet addresses of the two interfaces to be different, but that seems to be ignored.
Thanks,
John Clark.
vivianliu
Wed Aug 30, 2017 3:22 am
:mrgreen:
I can definitely help you on this by amending a few of files.
Create or edit your wpa_supplicant configuration:
sudo vi /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
country=GB
network={
        ssid="YOUR_WIFI"
        psk="wifi_password"
        key_mgmt=WPA-PSK
Edit the interfaces configuration:
sudo vi /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
auto wlan0
auto wlan1
iface lo inet loopback
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
iface wlan1 inet static
        address 192.168.10.1
        netmask 255.255.255.0
        network 192.168.10.0
        broadcast 192.168.10.255
        gateway 192.168.10.1
Install hostapd and dnsmasq:
sudo apt-get install hostapd dnsmasq
Create a new hostapd configuration:
sudo vi /etc/hostapd/hostapd.conf
The new configuration should look like this, change your wifi ssid and password as your wish:
interface=wlan1
ssid=Pi0W
hw_mode=g
channel=11
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=new_password
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
Modify the hostapd default configuration to use your new configuration file:
sudo vi /etc/default/hostapd
Add the following line:
DAEMON_CONF="/etc/hostapd/hostapd.conf"
Modify the dnsmasq configuration:
sudo vi /etc/dnsmasq.conf
interface=lo,wlan1
no-dhcp-interface=lo,wlan0
bind-interfaces
server=8.8.8.8
domain-needed
bogus-priv
dhcp-range=192.168.10.100,192.168.10.150,12h
Modify sysctl.conf:
sudo vi /etc/sysctl.conf
Uncomment the next line to enable packet forwarding for IPv4:
net.ipv4.ip_forward=1
Modify the rc.local script to run some commands on boot up.
sudo vi /etc/rc.local
Add the following line before "exit 0".
service dnsmasq start
iptables -t nat -A POSTROUTING -s 192.168.10.0/24 ! -d 192.168.10.0/24 -j MASQUERADE
ifdown wlan0
ifup wlan0
Last step, reboot your Pi Zero W:
sudo reboot
Enjoy your new AP designed by Rasyberry Pi :D
shanem2
Wed Jul 04, 2018 3:52 am
@vivianliu,
I'm going through your config and comparing against one that I've been trying to get to work; viewtopic.php?f=36&t=138730&start=150 (post by @SurferTim on Fri Jun 22, 2018 3:56 am.
Your config references a wlan1 and wlan0. Where does wlan1 come from or get defined?
The only difference is you define wlan1 in the "/etc/network/interfaces" file, where the other configuration applies it in the "/etc/rc.local" file using the command 'iw dev wlan0 interface add uap0 type __ap'.
Any assistance on getting both AP and Client working on a RPi 3B+ would be appreciated.
