squalldna
Stuck in Started Hostname Service on CLI mode
Sat Aug 19, 2017 11:16 pm
Good day sir. I'm a noob. Using a raspian thru noob.
Today i've been experimenting with RPi and Google Assistant.
I tried to run it Headless, however, upon checking the CLI is stuck in Started Hostname Service. Now i tried to Ssh to re enabled desktop mode, however, i forgot that i did not enable ssh. I tried to enable ssh using an ssh file on the root of the micro sd. However for some unknown reason I'm unable to make it work. Please note that i tries ssh and ssh.txt, but still both didn't work.
Also note that, i have an fm transmitter running consecutively thru the rc.local.
Is there a way to fix this without doing a fresh install?
Thank you an have a wonderful day.
