I wanted to ask, if it is possible to get the full 8 channel output over HDMI with the alsa driver? It should be possible because the openmaxil hallo_audio sample does with with 8 channels. But the alsa driver does not work with more then 2 channel (max_channel is set to 2 in source code).
I currently have no possibility to compile the raspberry kernel myself to check, if it is possible with simply changing the max_channel definition.
Thanks,
Alex
