PocketHarambe101
stock Debian(not raspbian) on the rpi?
Sat Aug 12, 2017 2:52 pm
I found the Raspbian image(both GUI and lite) to be loaded with stuff I won't use. Maybe it's because I'm a noob at linux and I'm not using everything in the distro, but for now I want a small sized image that is still debian. I heard that stock Debian can be installed under 300 megabytes. Am I correct? I just want to install the exact minimum required for me to use the text console, no GUI needed. Is there a raspberry pi port of pure stock Debian? Thanks!
--BACON IS ALWAYS THE ANSWER--
0={::::::::::> (((((TNT((((((~~~*
Martin Frezman
Re: stock Debian(not raspbian) on the rpi?
Sat Aug 12, 2017 2:56 pm
Why?
PocketHarambe101
Sat Aug 12, 2017 3:00 pm
it's explained in my post.
allfox
Sat Aug 12, 2017 3:07 pm
According to https://wiki.debian.org/RaspberryPi
Can I put Debian on my Raspberry Pi?
[*]Yes.
PocketHarambe101
Sat Aug 12, 2017 3:21 pm
yeah, I read that, but it says I need a custom kernel. If that means I need to build my own kernel, that's bad news, because I'm not in the level for kernel hacking - I don't even know how to add a user to a unix system!
allfox
Sat Aug 12, 2017 3:27 pm
Well, by coincidence, I am reading the manpage of adduser(8) now either, trying to make serial port available to a normal user.
I don't know how to build a Debian kernel either.
I built Raspbian kernel by following https://www.raspberrypi.org/documentati ... uilding.md
But keep digging, we'll be fine.
So download and install Raspbian Lite:
Which is pretty much a minimal Debian install but tweaked to support the Pi nicely.
It's a 297MB download which results in using a Gig or so in the installed SD card. Given that you are going to be using a 4 gig , 8 gig or bigger SD card why worry about that?
I see no reason to want a stock Debian over Raspbian. It's pretty much the same stuff but you will be far better supported with Raspbian.
DirkS
Sat Aug 12, 2017 3:28 pm
Maybe you could use something like DietPi (http://dietpi.com/)
Sat Aug 12, 2017 3:34 pm
PocketHarambe101,
Ah, sorry, you mentioned Lite in your opening post.
Sure it may have a few things in it you won't need. So what? It's only going to occupy a small patch on your SD card and has no overheads at run time.
Going for the smallest system required to get to the command line is going to be a lot of inconvenience. It's not something I'd want to waste time on unless I really had to. Been there, done that.
