OutoftheBOTS
enabling SPI1
Fri Aug 11, 2017 10:31 pm
I am trying to enable SPI1. I have SPI0 working fine and running a SPI LCD screen on CS0 and Touch on CS1. I also want to run my APA102 RBG LEDs on SPI1 as it this chip has a data line and clock ;line but no CS line. I can run the APA102 on SPI0 when I don't have the LCD screen attached to it.
I have added this line to the config.txt file "dtoverlay=spi1-1cs" but once I do that the RPi fails to boot
here is a copy of my current config.txt file
# For more options and information see
# http://rpf.io/configtxtreadme
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
dtoverlay=spi1-1cs
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# NOOBS Auto-generated Settings:
start_x=1
gpu_mem=128
enable_uart=1
dtoverlay=w1-gpio
OutoftheBOTS
Re: enabling SPI1
Fri Aug 11, 2017 10:47 pm
Ok I have found the solution.
I removed the 'console=serial0,115200' parameter from /boot/cmdline.txt as it apparently conflicts with SPI1
So now the next question what does "console=serial0,115200" do ???
pradroprod
Re: enabling SPI1
Sat Sep 30, 2017 7:50 pm
I just followed recently this guide on how to enable spi1 on raspberry pi and I was succesfully to use three nrf24 modules!
HermannSW
Re: enabling SPI1
Sun Oct 01, 2017 12:46 am
You can get 2+3=5 SPI(0+1) chip select lines out of the box:
viewtopic.php?f=44&t=22608&p=1216154#p1216154
https://stamm-wilbrandt.de/github_repo_i420toh264
