raviphulsundar
UDEV: Could not find DRM device!
Fri Aug 11, 2017 7:35 am
I'm using Raspberry Pi3,
I'm trying to run Qt program with EGLFS platform, and getting following error.
$./Program -platform eglfs
qt.qpa.egldeviceintegration: EGL device integration plugin keys: ("eglfs_kms_egldevice","eglfs_kms","eglfs_X11")
qt.qpa.egldeviceintegration: EGL device integration plugin keys (sorted): ("eglfs_kms","eglfs_kms_egldevice","eglfs_X11")
qt.qpa.egldeviceintegration: Trying to load device EGL integration "eglfs_kms"
qt.qpa.egldeviceintegration: Using EGL device integrtion "eglfs_kms"
qt.qpa.input: udev device discovery for type QFlags(0x10)
qt.qpa.input: Found matching devices ()
qt.qpa.eglfs.kms: Found the following video devices ()
Aborted
There is no /dev/dri directory on traget neither /sys/class/drm
Is this pbm with udev or something else ?
PhilE
Re: UDEV: Could not find DRM device!
Fri Aug 11, 2017 1:18 pm
[ Moved to Graphics Programming, a more natural home ]
ShiftPlusOne
Fri Aug 11, 2017 1:44 pm
What operating system? Where did the Qt install come from? If you compiled it yourself, do you have the configure output?
If you're just using the version of Qt that's in Raspbian, I don't believe it has a pi-specific eglfs backend enabled.
Return to “Graphics programming”
