Amrutha Saseendran
error loading a shared library in raspberry pi
Thu Aug 10, 2017 1:55 pm
i have cross compiled qt in raspberry pi and now i am trying to implement a shared library in it. i have created a shared library in qt in my laptop and deployed it to raspberry pi. then i created a widget application to call this library and see if it is working. when i tried to run this widget application in raspberry pi it is getting builded sucessfully. but when i tried to run it is showing error as "cannot load shared library"
these are my .pro files of my library and application
.pro of my library
QT       += widgets
QT       -= gui
TARGET = libforpishared
TEMPLATE = lib
DEFINES += LIBFORPISHARED_LIBRARY
SOURCES += libforpishared.cpp
HEADERS += libforpishared.h\
        libforpishared_global.h
INSTALLS        = target
target.files    = libforpishared
target.path     = /home/pi
.pro of my application
QT       += core gui widgets
greaterThan(QT_MAJOR_VERSION, 4): QT += widgets
TARGET = libtryforraspberrypi
TEMPLATE = app
SOURCES += main.cpp\
HEADERS  +=
DEPENDPATH += /home/amruz/libforpishared
INCLUDEPATH += /home/amruz/libforpishared
LIBS += -L/home/amruz/build-libforpishared-Raspberry_Pi-Debug -llibforpishared
INSTALLS        = target
target.files    = libtryforraspberrypi
I have deployed the library in raspberry pi. But only .so file is in /home/pi.
How to add the header files of my library to raspberry pi?
I am not sure of that
can anyone guide me in this
thanks in advance
topguy
Re: error loading a shared library in raspberry pi
Sun Aug 13, 2017 1:20 pm
The error "can not load shared library" is not caused by missing header files.
You have to tell the dynamic linker where to look for .so files, normally it only looks in "/usr/lib" and "/usr/local/lib".
If you have a library in the same directory as your binary the easiest way is to use the environment variable LD_LIBRARYPATH to tell the linker to look in more places.
# add "current directory" to list of places to look for .so files.
export LD_LIBRARYPATH=.
./my_binary
Amrutha Saseendran
Fri Aug 18, 2017 8:16 am
i tried
export LD_LIBRARYPATH = /home/pi
in raspberry pi
then i ran ./myappplication
still it shows as error while loading sharedlibraries.so.1 :cannot open shared object file: No such file or directory
sorry if i am doing it wrong..
can you please help me out
topguy
Sat Aug 19, 2017 1:54 pm
Exactly where is .so the file located ?
Martin Frezman
Sat Aug 19, 2017 2:19 pm
Here's the right answer. Follow these steps exactly.
$ mkdir ~/lib
$ export LD_LIBRARY_PATH=~/lib
$ mv -v /path/to/wherever/the/so/file/is_now/whatever.so ~/lib
$ cd /path/to/whever/the/executable/file_is
$ ./program_that_requires_whatever_shared_lib
Note: No spaces are allowed in the "export" command.
If this post appears in the wrong forums category, my apologies.
PeterO
Fri Aug 25, 2017 10:02 am
Fixed it for you .....
Here's just another answer. Follow these steps exactly.
$ mkdir ~/lib
