That indicates the file has been saved with DOS line-endings, rather than UNIX line-endings.pygmy_giant wrote:sleep: invalid time interval `1\r'
Try using something like Notepad++ and check the script is saved in the correct format
It's much easier when you can just connect your Rpi to the internet via ethernet, and then install packages using apt-get (which I realise you've already said you can't do).pygmy_giant wrote:life shouldn't be this complicated should it?
Did you remember to turn off the PIN on the SIM card?pygmy_giant wrote:/usr/sbin/pppd: The remote system is required to authenticate itself
/usr/sbin/pppd: but I couldn't find any suitable secret (password) for it to use to do so.
This is not something I ever had to do, but it does not belong in this bash script.pygmy_giant wrote:do I insert
Username = three
Password = three
it in the bash script?
