Donni H
Adding A DVD Player to my raspberry Pi
Wed Aug 02, 2017 7:35 pm
Hello RP Community,
I'm looking into adding a dvd player/drive to my raspberry pi,
The problem is I don't have any experience in this area of DvDs with Pi,
If anyone has done this before, I'd really appreciate any recommendation on certain devices, and the process how you did it.
Thank you so much,
Donni
Re: Adding A DVD Player to my raspberry Pi
Wed Aug 02, 2017 8:58 pm
Hello RP Community,
Thank you so much,
Donni
USB Optical Drive works if it has external power supply.....
RPi 4B 4GB (SSD Boot)..
Donni H
Wed Aug 02, 2017 9:01 pm
One of these?
You just plug it in?
Is there some type of app?
Wed Aug 02, 2017 11:55 pm
One of these?
APP ? that is for Android OS ?
Linux will just recognise as a Drive, whether or not it can play content depends on the file format !
The drive you listed is not externally powered...
Donni H
Thu Aug 03, 2017 12:47 am
app as in application, is there one for raspberry pi that supports video files?
Thu Aug 03, 2017 2:31 am
The Raspberry Pi is Hardware.
Raspbian Jessie with Desktop Operating System includes the cli omxplayer, if need a GUI then see kweb:
viewtopic.php?t=40860
omx can play most formats...though if the content is DRM it may not play.
Imperf3kt
Thu Aug 03, 2017 3:23 am
For a DVD you will need an MPEG2 license
http://www.raspberrypi.com/mpeg-2-license-key/
55:55:44:44:4C
52:4C:52:42:41
Donni H
Thu Aug 03, 2017 3:41 pm
What does the MPEG2 license do?
RaTTuS
Contact: Twitter YouTube
Thu Aug 03, 2017 3:47 pm
if you wish to play movies that are on a DVD then omxplayer will need a mpeg2 codec to play them in hardware,
if you just want a dvd to read data then no problem plug in and go ...
Covfefe
Donni H
Thu Aug 03, 2017 4:25 pm
Ah I understand,
Also, why does it need external power supply?
Can't the raspberry pi power it?
gkaiseril
Thu Aug 03, 2017 4:30 pm
The power supply might not be able to provide and amperage needed and if it can the Pi's USB port cannot handle that amperage. Get a powered hub and connect the DVD drive through the hub. Make sure you provide a power supply for the hub.
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
Thu Aug 03, 2017 5:02 pm
Ah I understand,
The RPi 3B can supply a maximum of 1.2mA in total (the USB Ports are not individually limited) from all 4 USB Ports, though it should be "theoretically" sufficient, but when an Optical Drive spins-up it can draw more power than the USB can supply:
https://www.raspberrypi.org/help/faqs/#topPower
rpiMike
Thu Aug 03, 2017 5:05 pm
That should be 1.2A !
Thu Aug 03, 2017 6:57 pm
Yes slip of the keyboard should be 1200mA.....
daveduggan
Mon Jun 29, 2020 2:17 pm
I am using my RPI 4 (4 g ram) as a desktop.
I would like to be able to use a dvd / cd player so I can listen to music and watch videos.
I am looking at CD/ DVD units but they all get their power from USB (USB 3).
My RPI 4 will do USB 3 but my concern is that I don't think the PI can power the CD/DVD player.
I do have an older hub that is powered but it is USB 2 at best not 3.
Any thoughts - any solutions?
Thank you
Imperf3kt
Mon Jun 29, 2020 11:00 pm
A DVD player or even a bluray player does not require the bandwidth of usb3 and will work just fine with usb2
55:55:44:44:4C
52:4C:52:42:41
