mitchnufc
PRI Sensors
Mon Oct 01, 2012 1:46 pm
I need to purchase some cheap and reliable PRI motion sensors for use on a Raspberry PI, I'm not to good with components and wonder if someone would be kind enough to recommend some suitable ones from Farnell and also some simple connectors so I can connect these to the GPIO pins.
joan
Re: PRI Sensors
Mon Oct 01, 2012 1:55 pm
Can't speak for Farnell but this does what it says on the tin (at least for me).
http://www.ebay.co.uk/itm/Automatical-A ... 0947825391
mitchnufc
Re: PRI Sensors
Mon Oct 01, 2012 2:32 pm
Yeah needs to be ordered through RS or Farrell as its through University. Thanks though
hayesey
Re: PRI Sensors
Mon Oct 01, 2012 3:13 pm
They're called PIR sensors, not PRI sensors. Searching on farnell's website for "PIR sensor" brings plenty of results.
gordon@drogon.net
Re: PRI Sensors
Tue Oct 02, 2012 6:49 am
PIR sensors?
I'm using the ones from Tandy:
http://www.tandyonline.co.uk/pir-motion ... odule.html
They run at 5v, but produce a 3.3v output. I'm using it in the Halloween Pi project. (See this moths MagPi magazine!)
-Gordon
techpaul
Re: PRI Sensors
Tue Oct 02, 2012 9:29 am
Try this and others in the range from Farnell
http://uk.farnell.com/panasonic-ew/amn3 ... tt=1373712
work from 3V to 6V, digital output, lower current than older types, better detection zones, less prone to sun traversal problems. I have found them to operate in no output on at 1/5 current of standard devices people use.
They are only three pins power, gnd and output. in a metal can transistor style base (TO5)
You can use the 3V from Pi to power it direct, I first used them from self contained security cameras that had to run off batteries for 1 year.
You can find plenty of connection schemes for mounting them, I also would say one of my boards (see signature below)
Just another techie on the net - For GPIO boards see http:///www.facebook.com/pcservicesreading
or http://www.pcserviceselectronics.co.uk/pi/
ant_thomas
Re: PRI Sensors
Wed Jan 09, 2013 10:36 am
joan wrote:Can't speak for Farnell but this does what it says on the tin (at least for me).
Can you tell me how you've wired this up? Did you connect it direct to the GPIO?
I've got a very similar looking PIR sensor and wired it up directly.
VCC ---- 5V
GND ---- GND
Out ---- GPIO18
When I enable the GPIO pin, create it as an input and cat the value it is constantly "1". Even without the VCC or GND (so Out + one other) connected it is still "1".
I've tried changing the jumper and tried adjusting the dials but never seem to get it to change to "0".
gordon@drogon.net
Re: PRI Sensors
Wed Jan 09, 2013 10:55 am
ant_thomas wrote: When I enable the GPIO pin, create it as an input and cat the value it is constantly "1". Even without the VCC or GND (so Out + one other) connected it is still "1".
If you have wiringPi installed, then test the GPIO as follows:
Remove all hardware from the Pi:
Type:
gpio mode 1 in
gpio mode 1 high
gpio read 1
gpio mode 1 low
gpio read 1
gpio mode 1 high
gpio read 1
You should get 1, then 0, then 1 from the gpio read commands.
And if that's OK, then start looking at the sensor.
One thing to know - the sensors need 5-10 seconds of no movement to stabilise. Then, when triggered, the'll hold the output for a set time. So you need to be still when you first power it up.
-Gordon
MattHawkinsUK
Re: PRI Sensors
Wed Jan 09, 2013 11:02 am
I use the modules that Gordon mentioned. I ordered mine on eBay. If you can wait a few weeks you can get them for £2 from China (I've got 2 more on the way!). I've currently got one running 24/7 in my garage. The performance is great for something so small and cheap. If I remember correctly I wired mine up directly.
ant_thomas, are you sure you connected to Pin 12, GPIO18 and not Pin 18, GPIO24?
My Raspberry Pi blog and home of the BerryClip Add-on board : http://www.raspberrypi-spy.co.uk/
Follow me on Google+, Facebook, Pinterest and Twitter (@RPiSpy)
ant_thomas
Re: PRI Sensors
Wed Jan 09, 2013 11:18 am
Thanks Gordon, I'll give that a go.
Matt: Definitely referencing the correct GPIO pin (12/18). Once I unplug the "out" cable it goes to "0".
I'll give wiringPi a go tonight. Maybe it is constantly detecting movement. I'll stick the sensor in a box or something to avoid light/movement. I got mine off eBay, cost a grand total of £1.38!
ant_thomas
Re: PRI Sensors
Tue Jan 15, 2013 7:36 pm
gordon@drogon.net wrote: If you have wiringPi installed, then test the GPIO as follows:
Only just had chance to give wiringPi a go but it doesn't seem to want to compile using "./build" even as root.
Here's the output
http://pastebin.com/TB9XNWkQ
(probably not the best thread for this!)
gordon@drogon.net
Re: PRI Sensors
Tue Jan 15, 2013 7:44 pm
Here's the output
Ah. you managed to grab a snapshot of wiringPi when I noticed that issue for myself and fixed it (ish) and pushed another version!
What you need to to is:
sudo apt-get install libi2c-dev
then run the ./build again. (no need to be root as long as sudo works for you)
The latest version (ie. 5 minutes after you pulled that one!) checks for it and advises on what you do.
-Gordon
ant_thomas
Re: PRI Sensors
Tue Jan 15, 2013 7:57 pm
gordon@drogon.net wrote:Ah. you managed to grab a snapshot of wiringPi when I noticed that issue for myself and fixed it (ish) and pushed another version!
-Gordon
Bingo! Pulled it again and it compiled first time, thanks!
ant_thomas
Re: PRI Sensors
Tue Jan 15, 2013 8:15 pm
Type:
gpio mode 1 in
gpio mode 1 high
gpio read 1
gpio mode 1 low
gpio read 1
gpio mode 1 high
gpio read 1
-Gordon
Doing - gpio mode 1 high
gives - mode: Invalid mode: high. Should be in/out/pwm/up/down/tri
So no chance to read it as high or low because it won't let me set as high or low.
gordon@drogon.net
Re: PRI Sensors
Tue Jan 15, 2013 8:46 pm
Type:
gpio mode 1 in
gpio mode 1 high
gpio read 1
gpio mode 1 low
gpio read 1
gpio mode 1 high
gpio read 1
-Gordon
Sorry - I confuse myself sometimes.
gpio mode 1 up ; gpio read 1
gpio mode 1 down ; gpio read 1
etc.
I recently added the ability to write a gpio pin using high/low as well as 1/0 ...
-Gordon
ant_thomas
Re: PRI Sensors
Tue Jan 15, 2013 8:53 pm
They both output 0
I can use "gpio write 1 0" and "gpio write 1 1" to write 1 and 0 to the pin but mode 1 up or down doesn't seem to do anything.
pi@raspberrypi ~ $ gpio mode 1 up
pi@raspberrypi ~ $ gpio read 1
0
pi@raspberrypi ~ $ gpio mode 1 down
0
pi@raspberrypi ~ $ gpio write 1 1
1
pi@raspberrypi ~ $ gpio write 1 0
0
pi@raspberrypi ~ $
ant_thomas
Re: PRI Sensors
Tue Jan 15, 2013 8:59 pm
Whereas pin 3/22 works fine (this is the one I was trying to plug the PIR sensor in to)
pi@raspberrypi ~ $ gpio mode 3 down
pi@raspberrypi ~ $ gpio read 3
0
pi@raspberrypi ~ $ gpio mode 3 up
1
0
gordon@drogon.net
Re: PRI Sensors
ant_thomas wrote:They both output 0
0
0
1
0
pi@raspberrypi ~ $
I'm not sure what you're doing, or intending to do.
I'm suggesting a way to test the inputs of your GPIO pins, so:
Set them to input mode with nothing connected:
gpio mode 1 in
set the intenal pull-up to high:
gpio mode 1 up
read the pin - and expect 1:
gpio read 1
change the internal pull up to a pull-down and read the pin again:
gpio mode 1 down
gpio read 1
expect 0.
If you set the mode to output, or start writing when it's an input then it's not going to change anything...
-Gordon
ant_thomas
Re: PRI Sensors
Tue Jan 15, 2013 9:16 pm
I think my issue might be power.
The PIR sensor should be getting 5V but I've measured it at only 1.25V. I'll try and figure out that issue first!
ant_thomas
Re: PRI Sensors
Tue Jan 15, 2013 10:29 pm
Power was the issue.
I've now got that sorted and it works great.
Thanks for the help. Even pointing me to wiringPi has made my scripting easier!
ant_thomas
Re: PRI Sensors
Wed Jan 16, 2013 9:09 pm
I made a simple script to detect motion and report it. Nothing fancy.....
#!/bin/bash
gpio mode 3 in
while true
do
if [ `gpio read 3` -eq 1 ];
then
echo 'Motion Detected: '`date +"%Y-%m-%d_%H-%M-%S"` >> /var/log/webcam/motion.log
echo 'Motion Detected'
else
echo 'No Motion'
fi
sleep 1
done
This works great when I run it manually.
I've created an init.d script to start it on boot and be able to stop/start/restart it. The script does start and can been seen as a running process but it doesn't detect any motion. If I manually restart the script motion is able to be detected.
Is there any issues with accessing GPIO pins using wiringPi via init scripts?
I've also tried adding /usr/bin/motion-log to rc.local which has the same result.
gordon@drogon.net
Re: PRI Sensors
Wed Jan 16, 2013 9:43 pm
ant_thomas wrote:I made a simple script to detect motion and report it. Nothing fancy.....
#!/bin/bash
gpio mode 3 in
while true
do
then
else
echo 'No Motion'
fi
sleep 1
done
init scripts are run with no environment - in particular no PATH set.
So at the start of the script do something like:
#!/bin/bash
PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin
or change gpio into $gpio and gpio=/usr/local/bin/gpio
-Gordon
ant_thomas
Re: PRI Sensors
Wed Jan 16, 2013 9:58 pm
Perfect!
Thanks again for your help.
