NewPi
How to configure Rpi on two wireless networks ?
Mon Oct 01, 2012 4:39 am
I have two wireless networks - one at Home and one at office, I used wpa_gui to configure my Home WiFi with RPi and connected successfully. My current "interfaces" config is :
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
Now, I want to connect to my office wifi network and configure both wlan connections to have static IP's. Pls. guide how to achieve this ?
Raspberry Pi Howto, Tips, Tricks and Tools -> http://bit.ly/RPiTricks
RussoNC
Re: How to configure Rpi on two wireless networks ?
Tue Oct 02, 2012 7:13 am
Mmhh... seems like you want to do an VPN? If is that, you can use this tutorial that another user post:
http://www.raspberrypi.org/phpBB3/viewt ... 36&t=14535
Hope this is usefull, if not, tell me and I'll try to help you.
Whant to see MySQL, nginx in action on the Raspberry pi ? Check my site: www.pirepository.com
NewPi
Wed Oct 03, 2012 3:02 pm
RussoNC wrote:Mmhh... seems like you want to do an VPN? If is that, you can use this tutorial that another user post:
No I did not wanted an VPN, I wanted my Pi to have the same static IP address in wlan when connected to any one of the two wifi's.
Lob0426
Wed Oct 03, 2012 8:15 pm
Your best bet might be to use one of the network managers. They allow settings for multiple networks. The new Raspbian has one installed. I use network-manager-gnome. There are others out there also.
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
NewPi
Thu Oct 11, 2012 4:03 am
Some Google searching and WICD Network Manager did the trick :)
thogue
Thu Oct 11, 2012 4:31 pm
I'd be interested in what the interfaces file looks like for this config. Or maybe wicd holds all that info.
NewPi
Sat Oct 13, 2012 4:43 pm
thogue wrote:I'd be interested in what the interfaces file looks like for this config. Or maybe wicd holds all that info.
Here's the /etc/network/interfaces file :
auto lo
allow-hotplug wlan0
The /etc/wpa_supplicant/wpa_supplicant.conf file :
update_config=1
network={
	ssid="MyOfficeWifi"
	psk="areyoukiddingme"
	proto=RSN
	key_mgmt=WPA-PSK
	pairwise=CCMP
	auth_alg=OPEN
network={
	ssid="Home_Network"
	psk="reallyiwillpostithere"
	proto=RSN
	key_mgmt=WPA-PSK
	pairwise=CCMP
	auth_alg=OPEN
Dweeber
Sat Oct 13, 2012 4:56 pm
You can also add priorities when you have say a temporary hotspot that you use for testing at a location where you have a normal access point.
By adding priority...
network={
        ssid="HouseDefault"
        psk="password"
        proto=RSN
        key_mgmt=WPA-PSK
        pairwise=CCMP
        auth_alg=OPEN
        priority=5
network={
        ssid="Rezound4G"
        psk="password"
        proto=RSN
        key_mgmt=WPA-PSK
        pairwise=CCMP
        auth_alg=OPEN
        priority=9
If both HouseDefault an Rezound4G are active at the location the Rezound SSID will be used because it has a higher default value. There are some great portable reasons to do this in a headless environment.
Dweeber A.K.A. Kevin...
My RPI Info Pages including Current Setup - http://rpi.tnet.com
thogue
Sat Oct 13, 2012 6:19 pm
Config is showing dhcp config a, did you setup reservations or am I missing something ? My configs look just like this.
NewPi
Sun Oct 14, 2012 2:18 am
thogue wrote:Config is showing dhcp config a, did you setup reservations or am I missing something ? My configs look just like this.
No, I did no manual config. First set-upped using wpa_config and then used WICD to allot an static ip.
I guess WICD takes over to load the static IP while booting.
