I've got the following pins, and no idea how to connect them:
LED+
LED-
CS
WR
DATA
GRND
VDD
I managed to make the backlight light up by wiring the LED+ to a 5v battery through a resistor and then to ground - about as much electrical skills as I have
I understand that GRND connects to ground and VDD to the power. I'm confused with the CS (Chip Select) pin, WR (Write) pin, and especially the 1 DATA pin, and how to send data to it.
I'm not sure if I need to further desolder something to access each data pin, or if there is even more than 1 data pin.
Please see the pictures attached of the LCD!
