pi@raspberrypi:~ $ sudo apt-get install evtest
Reading package lists... Done
Building dependency tree
E: Unable to locate package evtest
pi@raspberrypi:~ $
fruitbox v1.11 (Mar 16 2018, 11:05:38) by Mike Kingsley
A customisable MP3 Retro Jukebox for the Raspberry Pi
Detecting display...800 x 600 (60Hz)
Reading configuration 'skins/TouchOne/fruitbox.cfg'...
[general]
SkinName = TouchSong
SkinDescription = Touch skin for Official Raspberry Pi 7" Touch Screen
SkinSize = 800 480
Database = ../fruitbox.db
MusicPath = ../Music/
SortSongsBy = Title
SortSongsBy = Artist
SelectKeys = 0909
AutoSelect = true
SelectTimeout = 150
SelectHoldTimeout = 150
AutoPageTurnTime = 3000
MaxPlaylistLength = 20
LoopPlaylist = false
PlaysPerCoin1 = 0
SongsPerPage = 6
PageSize = 360 308
PairSongs = Dual
ArtistDescription = Artist
ArtistDescription = " / "
ArtistDescription = PairedArtist
PageMoveStyle = 20 0 false
SongLoadTime = 0
SongUnloadTime = 0
ArtistText = 1 255 32 32 255 centre true true false 0 7 294
SongText = 0 0 0 0 255 centre true true true 0 7 360
[sounds]
[font]
File = skins/TouchOne/bluecond.ttf
Height = 24
[font]
Height = 22
[font]
File = skins/TouchOne/dotmatrx.ttf
Height = 16
[font]
Height = 18
[bitmap]
File = skins/TouchOne/background.jpg
Position = 0 0
Size = 800 480
[page]
Position = 30 100
Background = skins/TouchOne/strip3.jpg
[page]
Position = 410 100
[status]
Position = 30 12
Size = 352 84
Text = 2 255 255 255 255 right false true false 0 0 350
Contents = skins/TouchOne/now_playing.txt
LineSpacing = 4
TimerTickPeriod = 60
[status]
Position = 414 12
Size = 352 84
Text = 2 255 255 255 255 left false true false 0 0 350
Contents = skins/TouchOne/coming_up.txt
LineSpacing = 4
[status]
Position = 160 432
Size = 234 53
Text = 2 255 255 255 255 centre false false false 0 0 350
Contents = skins/TouchOne/help.txt
LineSpacing = 4
TimerTickPeriod = 200
[touch song]
Bitmap = skins/TouchOne/touch_red.png
[bitmap]
File = skins/TouchOne/foreground.png
Position = 0 0
Size = 800 480
[bitmap]
File = skins/TouchOne/volume.png
Position = 8 422
Size = 12 51
VertScale = Volume
VertScaleMode = Clipped
[status]
Position = 423 421
Size = 93 53
Bitmap = skins/TouchOne/random_button.png
Contents = skins/TouchOne/random_pressed.txt
[status]
Position = 546 421
Size = 94 53
Bitmap = skins/TouchOne/skip_button.png
Contents = skins/TouchOne/skip_pressed.txt
[status]
Position = 663 421
Size = 54 53
Bitmap = skins/TouchOne/left_button.png
Contents = skins/TouchOne/left_pressed.txt
[status]
Position = 37 421
Size = 93 53
Bitmap = skins/TouchOne/volume_button.png
Contents = skins/TouchOne/volume_pressed.txt
[status]
Position = 717 421
Size = 53 53
Bitmap = skins/TouchOne/right_button.png
Contents = skins/TouchOne/right_pressed.txt
[touch areas]
ButtonRandom = 423 421 94 53
ButtonSkip = 546 421 94 53
ButtonLeft = 663 421 48 53
ButtonRight = 724 421 45 53
ButtonVol- = 38 421 32 53
ButtonVol+ = 98 421 32 53
Initialising audio ...
Loading database '../fruitbox.db'...6 songs found
Sorting songs by Title...
Sorting songs by Artist...
Building song pages...
Let's Rock!
Hello Mike, Hello GeoffB,
Hi Mike,fruitbox wrote: ↑Thu Apr 05, 2018 9:26 amThanks Jurgen ...that's reminded me...
GeoffB - I am currently debugging non official touchscreens with Jurgen, and have ironed out a few issues already - maybe it's worth you grabbing the fruitbox-1.11-jurgen4 experimental executable from GitHub and trying that? It's still got a few issues, but is the latest as far as touchscreen support for non official displays is concerned, so it would be interesting to see if that works any better for you...
Cheers,
Mike
Input driver version is 1.0.1
Input device ID: bus 0x3 vendor 0x4e7 product 0x20 version 0x100
Input device name: "Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 272 (BTN_LEFT)
Event type 3 (EV_ABS)
Event code 0 (ABS_X)
Value 3992
Min 0
Max 4095
Event code 1 (ABS_Y)
Value 712
Min 0
Max 4095
Event code 40 (ABS_MISC)
Value 0
Min 0
Max 256
Event type 4 (EV_MSC)
Event code 4 (MSC_SCAN)
Properties:
Testing ... (interrupt to exit)
Event: time 1523035900.345911, type 3 (EV_ABS), code 0 (ABS_X), value 3889
Event: time 1523035900.345911, type 3 (EV_ABS), code 1 (ABS_Y), value 487
Event: time 1523035900.345911, type 3 (EV_ABS), code 40 (ABS_MISC), value 17
Event: time 1523035900.345911, -------------- SYN_REPORT ------------
Event: time 1523035900.353917, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001
Event: time 1523035900.353917, type 1 (EV_KEY), code 272 (BTN_LEFT), value 1
Event: time 1523035900.353917, type 3 (EV_ABS), code 0 (ABS_X), value 3890
Event: time 1523035900.353917, type 3 (EV_ABS), code 40 (ABS_MISC), value 21
Event: time 1523035900.353917, -------------- SYN_REPORT ------------
Event: time 1523035900.365926, type 3 (EV_ABS), code 0 (ABS_X), value 3891
Event: time 1523035900.365926, type 3 (EV_ABS), code 40 (ABS_MISC), value 26
Event: time 1523035900.365926, -------------- SYN_REPORT ------------
Event: time 1523035900.373920, type 3 (EV_ABS), code 40 (ABS_MISC), value 34
Event: time 1523035900.373920, -------------- SYN_REPORT ------------
Event: time 1523035900.385918, type 3 (EV_ABS), code 1 (ABS_Y), value 486
Event: time 1523035900.385918, type 3 (EV_ABS), code 40 (ABS_MISC), value 43
Event: time 1523035900.385918, -------------- SYN_REPORT ------------
Event: time 1523035900.393910, type 3 (EV_ABS), code 40 (ABS_MISC), value 51
Event: time 1523035900.393910, -------------- SYN_REPORT ------------
Event: time 1523035900.405890, type 3 (EV_ABS), code 1 (ABS_Y), value 485
Event: time 1523035900.405890, type 3 (EV_ABS), code 40 (ABS_MISC), value 59
Event: time 1523035900.405890, -------------- SYN_REPORT ------------
Event: time 1523035900.413927, type 3 (EV_ABS), code 0 (ABS_X), value 3892
Event: time 1523035900.413927, type 3 (EV_ABS), code 40 (ABS_MISC), value 66
Event: time 1523035900.413927, -------------- SYN_REPORT ------------
Event: time 1523035900.425931, type 3 (EV_ABS), code 1 (ABS_Y), value 483
Event: time 1523035900.425931, type 3 (EV_ABS), code 40 (ABS_MISC), value 72
Event: time 1523035900.425931, -------------- SYN_REPORT ------------
Event: time 1523035900.433911, type 3 (EV_ABS), code 1 (ABS_Y), value 482
Event: time 1523035900.433911, type 3 (EV_ABS), code 40 (ABS_MISC), value 77
Event: time 1523035900.433911, -------------- SYN_REPORT ------------
Event: time 1523035900.445948, type 3 (EV_ABS), code 40 (ABS_MISC), value 82
Event: time 1523035900.445948, -------------- SYN_REPORT ------------
Event: time 1523035900.453920, type 3 (EV_ABS), code 40 (ABS_MISC), value 86
Event: time 1523035900.453920, -------------- SYN_REPORT ------------
Event: time 1523035900.465914, type 3 (EV_ABS), code 1 (ABS_Y), value 481
Event: time 1523035900.465914, type 3 (EV_ABS), code 40 (ABS_MISC), value 88
Event: time 1523035900.465914, -------------- SYN_REPORT ------------
Event: time 1523035900.473915, type 3 (EV_ABS), code 1 (ABS_Y), value 480
Event: time 1523035900.473915, type 3 (EV_ABS), code 40 (ABS_MISC), value 89
Event: time 1523035900.473915, -------------- SYN_REPORT ------------
Event: time 1523035900.493920, type 3 (EV_ABS), code 1 (ABS_Y), value 479
Event: time 1523035900.493920, type 3 (EV_ABS), code 40 (ABS_MISC), value 91
Event: time 1523035900.493920, -------------- SYN_REPORT ------------
Event: time 1523035900.505925, type 3 (EV_ABS), code 0 (ABS_X), value 3891
Event: time 1523035900.505925, type 3 (EV_ABS), code 1 (ABS_Y), value 478
Event: time 1523035900.505925, -------------- SYN_REPORT ------------
Event: time 1523035900.513929, type 3 (EV_ABS), code 0 (ABS_X), value 3890
Event: time 1523035900.513929, type 3 (EV_ABS), code 1 (ABS_Y), value 477
Event: time 1523035900.513929, type 3 (EV_ABS), code 40 (ABS_MISC), value 88
Event: time 1523035900.513929, -------------- SYN_REPORT ------------
Event: time 1523035900.525914, type 3 (EV_ABS), code 0 (ABS_X), value 3889
Event: time 1523035900.525914, type 3 (EV_ABS), code 40 (ABS_MISC), value 79
Event: time 1523035900.525914, -------------- SYN_REPORT ------------
Event: time 1523035900.533920, type 3 (EV_ABS), code 0 (ABS_X), value 3890
Event: time 1523035900.533920, type 3 (EV_ABS), code 40 (ABS_MISC), value 61
Event: time 1523035900.533920, -------------- SYN_REPORT ------------
Event: time 1523035900.545926, type 3 (EV_ABS), code 0 (ABS_X), value 3889
Event: time 1523035900.545926, type 3 (EV_ABS), code 40 (ABS_MISC), value 42
Event: time 1523035900.545926, -------------- SYN_REPORT ------------
Event: time 1523035900.581887, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001
Event: time 1523035900.581887, type 1 (EV_KEY), code 272 (BTN_LEFT), value 0
Event: time 1523035900.581887, type 3 (EV_ABS), code 40 (ABS_MISC), value 0
Event: time 1523035900.581887, -------------- SYN_REPORT ------------
Hello GeoffB,GeoffB wrote: ↑Fri Apr 06, 2018 5:42 pmMike/Jurgen
Since my last post I managed to install evtest. I ran it and captured the output to a log file, the contents of which are below
The log is only short because I just touched the screen near the top right corner then interrupted evtest to get the log.Code: Select all
Input driver version is 1.0.1 Input device ID: bus 0x3 vendor 0x4e7 product 0x20 version 0x100 Input device name: "Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface" Supported events: Event type 0 (EV_SYN) Event type 1 (EV_KEY) Event code 272 (BTN_LEFT) Event type 3 (EV_ABS) Event code 0 (ABS_X) Value 3992 Min 0 Max 4095 Event code 1 (ABS_Y) Value 712 Min 0 Max 4095 Event code 40 (ABS_MISC) Value 0 Min 0 Max 256 Event type 4 (EV_MSC) Event code 4 (MSC_SCAN) Properties: Testing ... (interrupt to exit) Event: time 1523035900.345911, type 3 (EV_ABS), code 0 (ABS_X), value 3889 Event: time 1523035900.345911, type 3 (EV_ABS), code 1 (ABS_Y), value 487 Event: time 1523035900.345911, type 3 (EV_ABS), code 40 (ABS_MISC), value 17 Event: time 1523035900.345911, -------------- SYN_REPORT ------------ Event: time 1523035900.353917, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001 Event: time 1523035900.353917, type 1 (EV_KEY), code 272 (BTN_LEFT), value 1 Event: time 1523035900.353917, type 3 (EV_ABS), code 0 (ABS_X), value 3890 Event: time 1523035900.353917, type 3 (EV_ABS), code 40 (ABS_MISC), value 21 Event: time 1523035900.353917, -------------- SYN_REPORT ------------ Event: time 1523035900.365926, type 3 (EV_ABS), code 0 (ABS_X), value 3891 Event: time 1523035900.365926, type 3 (EV_ABS), code 40 (ABS_MISC), value 26 Event: time 1523035900.365926, -------------- SYN_REPORT ------------ Event: time 1523035900.373920, type 3 (EV_ABS), code 40 (ABS_MISC), value 34 Event: time 1523035900.373920, -------------- SYN_REPORT ------------ Event: time 1523035900.385918, type 3 (EV_ABS), code 1 (ABS_Y), value 486 Event: time 1523035900.385918, type 3 (EV_ABS), code 40 (ABS_MISC), value 43 Event: time 1523035900.385918, -------------- SYN_REPORT ------------ Event: time 1523035900.393910, type 3 (EV_ABS), code 40 (ABS_MISC), value 51 Event: time 1523035900.393910, -------------- SYN_REPORT ------------ Event: time 1523035900.405890, type 3 (EV_ABS), code 1 (ABS_Y), value 485 Event: time 1523035900.405890, type 3 (EV_ABS), code 40 (ABS_MISC), value 59 Event: time 1523035900.405890, -------------- SYN_REPORT ------------ Event: time 1523035900.413927, type 3 (EV_ABS), code 0 (ABS_X), value 3892 Event: time 1523035900.413927, type 3 (EV_ABS), code 40 (ABS_MISC), value 66 Event: time 1523035900.413927, -------------- SYN_REPORT ------------ Event: time 1523035900.425931, type 3 (EV_ABS), code 1 (ABS_Y), value 483 Event: time 1523035900.425931, type 3 (EV_ABS), code 40 (ABS_MISC), value 72 Event: time 1523035900.425931, -------------- SYN_REPORT ------------ Event: time 1523035900.433911, type 3 (EV_ABS), code 1 (ABS_Y), value 482 Event: time 1523035900.433911, type 3 (EV_ABS), code 40 (ABS_MISC), value 77 Event: time 1523035900.433911, -------------- SYN_REPORT ------------ Event: time 1523035900.445948, type 3 (EV_ABS), code 40 (ABS_MISC), value 82 Event: time 1523035900.445948, -------------- SYN_REPORT ------------ Event: time 1523035900.453920, type 3 (EV_ABS), code 40 (ABS_MISC), value 86 Event: time 1523035900.453920, -------------- SYN_REPORT ------------ Event: time 1523035900.465914, type 3 (EV_ABS), code 1 (ABS_Y), value 481 Event: time 1523035900.465914, type 3 (EV_ABS), code 40 (ABS_MISC), value 88 Event: time 1523035900.465914, -------------- SYN_REPORT ------------ Event: time 1523035900.473915, type 3 (EV_ABS), code 1 (ABS_Y), value 480 Event: time 1523035900.473915, type 3 (EV_ABS), code 40 (ABS_MISC), value 89 Event: time 1523035900.473915, -------------- SYN_REPORT ------------ Event: time 1523035900.493920, type 3 (EV_ABS), code 1 (ABS_Y), value 479 Event: time 1523035900.493920, type 3 (EV_ABS), code 40 (ABS_MISC), value 91 Event: time 1523035900.493920, -------------- SYN_REPORT ------------ Event: time 1523035900.505925, type 3 (EV_ABS), code 0 (ABS_X), value 3891 Event: time 1523035900.505925, type 3 (EV_ABS), code 1 (ABS_Y), value 478 Event: time 1523035900.505925, -------------- SYN_REPORT ------------ Event: time 1523035900.513929, type 3 (EV_ABS), code 0 (ABS_X), value 3890 Event: time 1523035900.513929, type 3 (EV_ABS), code 1 (ABS_Y), value 477 Event: time 1523035900.513929, type 3 (EV_ABS), code 40 (ABS_MISC), value 88 Event: time 1523035900.513929, -------------- SYN_REPORT ------------ Event: time 1523035900.525914, type 3 (EV_ABS), code 0 (ABS_X), value 3889 Event: time 1523035900.525914, type 3 (EV_ABS), code 40 (ABS_MISC), value 79 Event: time 1523035900.525914, -------------- SYN_REPORT ------------ Event: time 1523035900.533920, type 3 (EV_ABS), code 0 (ABS_X), value 3890 Event: time 1523035900.533920, type 3 (EV_ABS), code 40 (ABS_MISC), value 61 Event: time 1523035900.533920, -------------- SYN_REPORT ------------ Event: time 1523035900.545926, type 3 (EV_ABS), code 0 (ABS_X), value 3889 Event: time 1523035900.545926, type 3 (EV_ABS), code 40 (ABS_MISC), value 42 Event: time 1523035900.545926, -------------- SYN_REPORT ------------ Event: time 1523035900.581887, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001 Event: time 1523035900.581887, type 1 (EV_KEY), code 272 (BTN_LEFT), value 0 Event: time 1523035900.581887, type 3 (EV_ABS), code 40 (ABS_MISC), value 0 Event: time 1523035900.581887, -------------- SYN_REPORT ------------
I'm not sure if this helps you Mike but it's all smoke and mirrors to me,
Regards
GeoffB
Supported events:
Value 1998
Min 0
Max 4095
Value 1809
Min 0
Max 4095
Value 0
Min 0
Max 256
Properties:
Event: time 1523042547.661481, type 3 (EV_ABS), code 0 (ABS_X), value 53
Event: time 1523042547.661481, type 3 (EV_ABS), code 1 (ABS_Y), value 18
Event: time 1523042547.661481, type 3 (EV_ABS), code 40 (ABS_MISC), value 27
Event: time 1523042547.661481, -------------- SYN_REPORT ------------
Event: time 1523042547.669470, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001
Event: time 1523042547.669470, type 1 (EV_KEY), code 272 (BTN_LEFT), value 1
Event: time 1523042547.669470, type 3 (EV_ABS), code 1 (ABS_Y), value 19
Event: time 1523042547.669470, type 3 (EV_ABS), code 40 (ABS_MISC), value 31
Event: time 1523042547.669470, -------------- SYN_REPORT ------------
Event: time 1523042547.681475, type 3 (EV_ABS), code 1 (ABS_Y), value 20
Event: time 1523042547.681475, type 3 (EV_ABS), code 40 (ABS_MISC), value 37
Event: time 1523042547.681475, -------------- SYN_REPORT ------------
Event: time 1523042547.689470, type 3 (EV_ABS), code 40 (ABS_MISC), value 45
Event: time 1523042547.689470, -------------- SYN_REPORT ------------
Event: time 1523042547.701466, type 3 (EV_ABS), code 1 (ABS_Y), value 21
Event: time 1523042547.701466, type 3 (EV_ABS), code 40 (ABS_MISC), value 55
Event: time 1523042547.701466, -------------- SYN_REPORT ------------
Event: time 1523042547.709464, type 3 (EV_ABS), code 40 (ABS_MISC), value 66
Event: time 1523042547.709464, -------------- SYN_REPORT ------------
Event: time 1523042547.721469, type 3 (EV_ABS), code 0 (ABS_X), value 54
Event: time 1523042547.721469, type 3 (EV_ABS), code 40 (ABS_MISC), value 76
Event: time 1523042547.721469, -------------- SYN_REPORT ------------
Event: time 1523042547.729469, type 3 (EV_ABS), code 0 (ABS_X), value 53
Event: time 1523042547.729469, type 3 (EV_ABS), code 1 (ABS_Y), value 22
Event: time 1523042547.729469, type 3 (EV_ABS), code 40 (ABS_MISC), value 83
Event: time 1523042547.729469, -------------- SYN_REPORT ------------
Event: time 1523042547.741469, type 3 (EV_ABS), code 40 (ABS_MISC), value 92
Event: time 1523042547.741469, -------------- SYN_REPORT ------------
Event: time 1523042547.749465, type 3 (EV_ABS), code 1 (ABS_Y), value 23
Event: time 1523042547.749465, type 3 (EV_ABS), code 40 (ABS_MISC), value 100
Event: time 1523042547.749465, -------------- SYN_REPORT ------------
Event: time 1523042547.761467, type 3 (EV_ABS), code 40 (ABS_MISC), value 108
Event: time 1523042547.761467, -------------- SYN_REPORT ------------
Event: time 1523042547.769450, type 3 (EV_ABS), code 1 (ABS_Y), value 24
Event: time 1523042547.769450, type 3 (EV_ABS), code 40 (ABS_MISC), value 114
Event: time 1523042547.769450, -------------- SYN_REPORT ------------
Event: time 1523042547.781446, type 3 (EV_ABS), code 40 (ABS_MISC), value 119
Event: time 1523042547.781446, -------------- SYN_REPORT ------------
Event: time 1523042547.793448, type 3 (EV_ABS), code 1 (ABS_Y), value 25
Event: time 1523042547.793448, type 3 (EV_ABS), code 40 (ABS_MISC), value 123
Event: time 1523042547.793448, -------------- SYN_REPORT ------------
Event: time 1523042547.801448, type 3 (EV_ABS), code 1 (ABS_Y), value 26
Event: time 1523042547.801448, type 3 (EV_ABS), code 40 (ABS_MISC), value 130
Event: time 1523042547.801448, -------------- SYN_REPORT ------------
Event: time 1523042547.813447, type 3 (EV_ABS), code 1 (ABS_Y), value 27
Event: time 1523042547.813447, type 3 (EV_ABS), code 40 (ABS_MISC), value 135
Event: time 1523042547.813447, -------------- SYN_REPORT ------------
Event: time 1523042547.849448, type 3 (EV_ABS), code 40 (ABS_MISC), value 132
Event: time 1523042547.849448, -------------- SYN_REPORT ------------
Event: time 1523042547.857447, type 3 (EV_ABS), code 40 (ABS_MISC), value 135
Event: time 1523042547.857447, -------------- SYN_REPORT ------------
Event: time 1523042547.877447, type 3 (EV_ABS), code 1 (ABS_Y), value 28
Event: time 1523042547.877447, type 3 (EV_ABS), code 40 (ABS_MISC), value 139
Event: time 1523042547.877447, -------------- SYN_REPORT ------------
Event: time 1523042547.885445, type 3 (EV_ABS), code 40 (ABS_MISC), value 142
Event: time 1523042547.885445, -------------- SYN_REPORT ------------
Event: time 1523042547.897449, type 3 (EV_ABS), code 1 (ABS_Y), value 29
Event: time 1523042547.897449, type 3 (EV_ABS), code 40 (ABS_MISC), value 143
Event: time 1523042547.897449, -------------- SYN_REPORT ------------
Event: time 1523042547.905448, type 3 (EV_ABS), code 0 (ABS_X), value 54
Event: time 1523042547.905448, type 3 (EV_ABS), code 40 (ABS_MISC), value 144
Event: time 1523042547.905448, -------------- SYN_REPORT ------------
Event: time 1523042547.925446, type 3 (EV_ABS), code 1 (ABS_Y), value 30
Event: time 1523042547.925446, -------------- SYN_REPORT ------------
Event: time 1523042547.961447, type 3 (EV_ABS), code 0 (ABS_X), value 55
Event: time 1523042547.961447, type 3 (EV_ABS), code 40 (ABS_MISC), value 141
Event: time 1523042547.961447, -------------- SYN_REPORT ------------
Event: time 1523042547.973445, type 3 (EV_ABS), code 40 (ABS_MISC), value 137
Event: time 1523042547.973445, -------------- SYN_REPORT ------------
Event: time 1523042547.981446, type 3 (EV_ABS), code 1 (ABS_Y), value 31
Event: time 1523042547.981446, type 3 (EV_ABS), code 40 (ABS_MISC), value 128
Event: time 1523042547.981446, -------------- SYN_REPORT ------------
Event: time 1523042547.993448, type 3 (EV_ABS), code 1 (ABS_Y), value 30
Event: time 1523042547.993448, type 3 (EV_ABS), code 40 (ABS_MISC), value 112
Event: time 1523042547.993448, -------------- SYN_REPORT ------------
Event: time 1523042548.001447, type 3 (EV_ABS), code 40 (ABS_MISC), value 86
Event: time 1523042548.001447, -------------- SYN_REPORT ------------
Event: time 1523042548.009447, type 3 (EV_ABS), code 1 (ABS_Y), value 29
Event: time 1523042548.009447, type 3 (EV_ABS), code 40 (ABS_MISC), value 56
Event: time 1523042548.009447, -------------- SYN_REPORT ------------
Event: time 1523042548.049451, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001
Event: time 1523042548.049451, type 1 (EV_KEY), code 272 (BTN_LEFT), value 0
Event: time 1523042548.049451, type 3 (EV_ABS), code 0 (ABS_X), value 56
Event: time 1523042548.049451, type 3 (EV_ABS), code 1 (ABS_Y), value 24
Event: time 1523042548.049451, type 3 (EV_ABS), code 40 (ABS_MISC), value 0
Event: time 1523042548.049451, -------------- SYN_REPORT ------------
Event: time 1523042549.837471, type 3 (EV_ABS), code 0 (ABS_X), value 4089
Event: time 1523042549.837471, type 3 (EV_ABS), code 1 (ABS_Y), value 28
Event: time 1523042549.837471, type 3 (EV_ABS), code 40 (ABS_MISC), value 23
Event: time 1523042549.837471, -------------- SYN_REPORT ------------
Event: time 1523042549.849462, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001
Event: time 1523042549.849462, type 1 (EV_KEY), code 272 (BTN_LEFT), value 1
Event: time 1523042549.849462, type 3 (EV_ABS), code 0 (ABS_X), value 4088
Event: time 1523042549.849462, type 3 (EV_ABS), code 40 (ABS_MISC), value 26
Event: time 1523042549.849462, -------------- SYN_REPORT ------------
Event: time 1523042549.857460, type 3 (EV_ABS), code 0 (ABS_X), value 4087
Event: time 1523042549.857460, type 3 (EV_ABS), code 1 (ABS_Y), value 29
Event: time 1523042549.857460, type 3 (EV_ABS), code 40 (ABS_MISC), value 30
Event: time 1523042549.857460, -------------- SYN_REPORT ------------
Event: time 1523042549.869453, type 3 (EV_ABS), code 40 (ABS_MISC), value 34
Event: time 1523042549.869453, -------------- SYN_REPORT ------------
Event: time 1523042549.877457, type 3 (EV_ABS), code 0 (ABS_X), value 4086
Event: time 1523042549.877457, type 3 (EV_ABS), code 40 (ABS_MISC), value 40
Event: time 1523042549.877457, -------------- SYN_REPORT ------------
Event: time 1523042549.889460, type 3 (EV_ABS), code 0 (ABS_X), value 4085
Event: time 1523042549.889460, type 3 (EV_ABS), code 40 (ABS_MISC), value 45
Event: time 1523042549.889460, -------------- SYN_REPORT ------------
Event: time 1523042549.897458, type 3 (EV_ABS), code 0 (ABS_X), value 4084
Event: time 1523042549.897458, type 3 (EV_ABS), code 40 (ABS_MISC), value 51
Event: time 1523042549.897458, -------------- SYN_REPORT ------------
Event: time 1523042549.909453, type 3 (EV_ABS), code 40 (ABS_MISC), value 57
Event: time 1523042549.909453, -------------- SYN_REPORT ------------
Event: time 1523042549.917455, type 3 (EV_ABS), code 0 (ABS_X), value 4083
Event: time 1523042549.917455, type 3 (EV_ABS), code 40 (ABS_MISC), value 64
Event: time 1523042549.917455, -------------- SYN_REPORT ------------
Event: time 1523042549.929457, type 3 (EV_ABS), code 0 (ABS_X), value 4082
Event: time 1523042549.929457, type 3 (EV_ABS), code 40 (ABS_MISC), value 73
Event: time 1523042549.929457, -------------- SYN_REPORT ------------
Event: time 1523042549.937443, type 3 (EV_ABS), code 0 (ABS_X), value 4081
Event: time 1523042549.937443, type 3 (EV_ABS), code 1 (ABS_Y), value 28
Event: time 1523042549.937443, type 3 (EV_ABS), code 40 (ABS_MISC), value 82
Event: time 1523042549.937443, -------------- SYN_REPORT ------------
Event: time 1523042549.949437, type 3 (EV_ABS), code 0 (ABS_X), value 4080
Event: time 1523042549.949437, type 3 (EV_ABS), code 40 (ABS_MISC), value 90
Event: time 1523042549.949437, -------------- SYN_REPORT ------------
Event: time 1523042549.961439, type 3 (EV_ABS), code 0 (ABS_X), value 4079
Event: time 1523042549.961439, type 3 (EV_ABS), code 1 (ABS_Y), value 29
Event: time 1523042549.961439, type 3 (EV_ABS), code 40 (ABS_MISC), value 99
Event: time 1523042549.961439, -------------- SYN_REPORT ------------
Event: time 1523042549.969437, type 3 (EV_ABS), code 40 (ABS_MISC), value 107
Event: time 1523042549.969437, -------------- SYN_REPORT ------------
Event: time 1523042549.981438, type 3 (EV_ABS), code 0 (ABS_X), value 4077
Event: time 1523042549.981438, type 3 (EV_ABS), code 40 (ABS_MISC), value 114
Event: time 1523042549.981438, -------------- SYN_REPORT ------------
Event: time 1523042549.989436, type 3 (EV_ABS), code 0 (ABS_X), value 4076
Event: time 1523042549.989436, type 3 (EV_ABS), code 40 (ABS_MISC), value 121
Event: time 1523042549.989436, -------------- SYN_REPORT ------------
Event: time 1523042550.001438, type 3 (EV_ABS), code 1 (ABS_Y), value 30
Event: time 1523042550.001438, type 3 (EV_ABS), code 40 (ABS_MISC), value 126
Event: time 1523042550.001438, -------------- SYN_REPORT ------------
Event: time 1523042550.009437, type 3 (EV_ABS), code 0 (ABS_X), value 4075
Event: time 1523042550.009437, type 3 (EV_ABS), code 40 (ABS_MISC), value 130
Event: time 1523042550.009437, -------------- SYN_REPORT ------------
Event: time 1523042550.021436, type 3 (EV_ABS), code 0 (ABS_X), value 4076
Event: time 1523042550.021436, type 3 (EV_ABS), code 40 (ABS_MISC), value 132
Event: time 1523042550.021436, -------------- SYN_REPORT ------------
Event: time 1523042550.029437, type 3 (EV_ABS), code 0 (ABS_X), value 4075
Event: time 1523042550.029437, type 3 (EV_ABS), code 1 (ABS_Y), value 29
Event: time 1523042550.029437, type 3 (EV_ABS), code 40 (ABS_MISC), value 133
Event: time 1523042550.029437, -------------- SYN_REPORT ------------
Event: time 1523042550.041438, type 3 (EV_ABS), code 1 (ABS_Y), value 30
Event: time 1523042550.041438, type 3 (EV_ABS), code 40 (ABS_MISC), value 130
Event: time 1523042550.041438, -------------- SYN_REPORT ------------
Event: time 1523042550.049438, type 3 (EV_ABS), code 1 (ABS_Y), value 29
Event: time 1523042550.049438, type 3 (EV_ABS), code 40 (ABS_MISC), value 128
Event: time 1523042550.049438, -------------- SYN_REPORT ------------
Event: time 1523042550.061436, type 3 (EV_ABS), code 1 (ABS_Y), value 30
Event: time 1523042550.061436, type 3 (EV_ABS), code 40 (ABS_MISC), value 127
Event: time 1523042550.061436, -------------- SYN_REPORT ------------
Event: time 1523042550.069435, type 3 (EV_ABS), code 40 (ABS_MISC), value 130
Event: time 1523042550.069435, -------------- SYN_REPORT ------------
Event: time 1523042550.089438, type 3 (EV_ABS), code 1 (ABS_Y), value 31
Event: time 1523042550.089438, type 3 (EV_ABS), code 40 (ABS_MISC), value 125
Event: time 1523042550.089438, -------------- SYN_REPORT ------------
Event: time 1523042550.101435, type 3 (EV_ABS), code 40 (ABS_MISC), value 122
Event: time 1523042550.101435, -------------- SYN_REPORT ------------
Event: time 1523042550.109435, type 3 (EV_ABS), code 40 (ABS_MISC), value 116
Event: time 1523042550.109435, -------------- SYN_REPORT ------------
Event: time 1523042550.121437, type 3 (EV_ABS), code 1 (ABS_Y), value 30
Event: time 1523042550.121437, type 3 (EV_ABS), code 40 (ABS_MISC), value 107
Event: time 1523042550.121437, -------------- SYN_REPORT ------------
Event: time 1523042550.129436, type 3 (EV_ABS), code 40 (ABS_MISC), value 88
Event: time 1523042550.129436, -------------- SYN_REPORT ------------
Event: time 1523042550.141436, type 3 (EV_ABS), code 0 (ABS_X), value 4076
Event: time 1523042550.141436, type 3 (EV_ABS), code 1 (ABS_Y), value 29
Event: time 1523042550.141436, type 3 (EV_ABS), code 40 (ABS_MISC), value 64
Event: time 1523042550.141436, -------------- SYN_REPORT ------------
Event: time 1523042550.149436, type 3 (EV_ABS), code 0 (ABS_X), value 4077
Event: time 1523042550.149436, type 3 (EV_ABS), code 40 (ABS_MISC), value 42
Event: time 1523042550.149436, -------------- SYN_REPORT ------------
Event: time 1523042550.193441, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001
Event: time 1523042550.193441, type 1 (EV_KEY), code 272 (BTN_LEFT), value 0
Event: time 1523042550.193441, type 3 (EV_ABS), code 0 (ABS_X), value 4083
Event: time 1523042550.193441, type 3 (EV_ABS), code 1 (ABS_Y), value 21
Event: time 1523042550.193441, type 3 (EV_ABS), code 40 (ABS_MISC), value 0
Event: time 1523042550.193441, -------------- SYN_REPORT ------------
Event: time 1523042552.153458, type 3 (EV_ABS), code 0 (ABS_X), value 45
Event: time 1523042552.153458, type 3 (EV_ABS), code 1 (ABS_Y), value 3965
Event: time 1523042552.153458, type 3 (EV_ABS), code 40 (ABS_MISC), value 23
Event: time 1523042552.153458, -------------- SYN_REPORT ------------
Event: time 1523042552.161453, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001
Event: time 1523042552.161453, type 1 (EV_KEY), code 272 (BTN_LEFT), value 1
Event: time 1523042552.161453, type 3 (EV_ABS), code 1 (ABS_Y), value 3966
Event: time 1523042552.161453, type 3 (EV_ABS), code 40 (ABS_MISC), value 29
Event: time 1523042552.161453, -------------- SYN_REPORT ------------
Event: time 1523042552.173445, type 3 (EV_ABS), code 40 (ABS_MISC), value 37
Event: time 1523042552.173445, -------------- SYN_REPORT ------------
Event: time 1523042552.181446, type 3 (EV_ABS), code 1 (ABS_Y), value 3968
Event: time 1523042552.181446, type 3 (EV_ABS), code 40 (ABS_MISC), value 44
Event: time 1523042552.181446, -------------- SYN_REPORT ------------
Event: time 1523042552.193446, type 3 (EV_ABS), code 1 (ABS_Y), value 3969
Event: time 1523042552.193446, type 3 (EV_ABS), code 40 (ABS_MISC), value 51
Event: time 1523042552.193446, -------------- SYN_REPORT ------------
Event: time 1523042552.201449, type 3 (EV_ABS), code 1 (ABS_Y), value 3970
Event: time 1523042552.201449, type 3 (EV_ABS), code 40 (ABS_MISC), value 59
Event: time 1523042552.201449, -------------- SYN_REPORT ------------
Event: time 1523042552.213445, type 3 (EV_ABS), code 0 (ABS_X), value 44
Event: time 1523042552.213445, type 3 (EV_ABS), code 1 (ABS_Y), value 3971
Event: time 1523042552.213445, type 3 (EV_ABS), code 40 (ABS_MISC), value 66
Event: time 1523042552.213445, -------------- SYN_REPORT ------------
Event: time 1523042552.221443, type 3 (EV_ABS), code 40 (ABS_MISC), value 72
Event: time 1523042552.221443, -------------- SYN_REPORT ------------
Event: time 1523042552.233446, type 3 (EV_ABS), code 1 (ABS_Y), value 3972
Event: time 1523042552.233446, type 3 (EV_ABS), code 40 (ABS_MISC), value 80
Event: time 1523042552.233446, -------------- SYN_REPORT ------------
Event: time 1523042552.241449, type 3 (EV_ABS), code 0 (ABS_X), value 43
Event: time 1523042552.241449, type 3 (EV_ABS), code 1 (ABS_Y), value 3973
Event: time 1523042552.241449, type 3 (EV_ABS), code 40 (ABS_MISC), value 87
Event: time 1523042552.241449, -------------- SYN_REPORT ------------
Event: time 1523042552.253444, type 3 (EV_ABS), code 1 (ABS_Y), value 3974
Event: time 1523042552.253444, type 3 (EV_ABS), code 40 (ABS_MISC), value 94
Event: time 1523042552.253444, -------------- SYN_REPORT ------------
Event: time 1523042552.261427, type 3 (EV_ABS), code 1 (ABS_Y), value 3975
Event: time 1523042552.261427, type 3 (EV_ABS), code 40 (ABS_MISC), value 96
Event: time 1523042552.261427, -------------- SYN_REPORT ------------
Event: time 1523042552.273427, type 3 (EV_ABS), code 1 (ABS_Y), value 3976
Event: time 1523042552.273427, type 3 (EV_ABS), code 40 (ABS_MISC), value 99
Event: time 1523042552.273427, -------------- SYN_REPORT ------------
Event: time 1523042552.281427, type 3 (EV_ABS), code 1 (ABS_Y), value 3977
Event: time 1523042552.281427, type 3 (EV_ABS), code 40 (ABS_MISC), value 108
Event: time 1523042552.281427, -------------- SYN_REPORT ------------
Event: time 1523042552.293427, type 3 (EV_ABS), code 0 (ABS_X), value 42
Event: time 1523042552.293427, type 3 (EV_ABS), code 1 (ABS_Y), value 3978
Event: time 1523042552.293427, type 3 (EV_ABS), code 40 (ABS_MISC), value 115
Event: time 1523042552.293427, -------------- SYN_REPORT ------------
Event: time 1523042552.301425, type 3 (EV_ABS), code 40 (ABS_MISC), value 118
Event: time 1523042552.301425, -------------- SYN_REPORT ------------
Event: time 1523042552.313427, type 3 (EV_ABS), code 1 (ABS_Y), value 3979
Event: time 1523042552.313427, type 3 (EV_ABS), code 40 (ABS_MISC), value 120
Event: time 1523042552.313427, -------------- SYN_REPORT ------------
Event: time 1523042552.333427, type 3 (EV_ABS), code 0 (ABS_X), value 41
Event: time 1523042552.333427, type 3 (EV_ABS), code 1 (ABS_Y), value 3980
Event: time 1523042552.333427, type 3 (EV_ABS), code 40 (ABS_MISC), value 119
Event: time 1523042552.333427, -------------- SYN_REPORT ------------
Event: time 1523042552.341427, type 3 (EV_ABS), code 1 (ABS_Y), value 3979
Event: time 1523042552.341427, type 3 (EV_ABS), code 40 (ABS_MISC), value 113
Event: time 1523042552.341427, -------------- SYN_REPORT ------------
Event: time 1523042552.353426, type 3 (EV_ABS), code 40 (ABS_MISC), value 108
Event: time 1523042552.353426, -------------- SYN_REPORT ------------
Event: time 1523042552.369428, type 3 (EV_ABS), code 0 (ABS_X), value 42
Event: time 1523042552.369428, type 3 (EV_ABS), code 1 (ABS_Y), value 3978
Event: time 1523042552.369428, type 3 (EV_ABS), code 40 (ABS_MISC), value 105
Event: time 1523042552.369428, -------------- SYN_REPORT ------------
Event: time 1523042552.425428, type 3 (EV_ABS), code 0 (ABS_X), value 41
Event: time 1523042552.425428, type 3 (EV_ABS), code 40 (ABS_MISC), value 107
Event: time 1523042552.425428, -------------- SYN_REPORT ------------
Event: time 1523042552.457426, type 3 (EV_ABS), code 40 (ABS_MISC), value 110
Event: time 1523042552.457426, -------------- SYN_REPORT ------------
Event: time 1523042552.477424, type 3 (EV_ABS), code 40 (ABS_MISC), value 107
Event: time 1523042552.477424, -------------- SYN_REPORT ------------
Event: time 1523042552.489425, type 3 (EV_ABS), code 40 (ABS_MISC), value 103
Event: time 1523042552.489425, -------------- SYN_REPORT ------------
Event: time 1523042552.497426, type 3 (EV_ABS), code 40 (ABS_MISC), value 98
Event: time 1523042552.497426, -------------- SYN_REPORT ------------
Event: time 1523042552.509425, type 3 (EV_ABS), code 1 (ABS_Y), value 3976
Event: time 1523042552.509425, type 3 (EV_ABS), code 40 (ABS_MISC), value 92
Event: time 1523042552.509425, -------------- SYN_REPORT ------------
Event: time 1523042552.517424, type 3 (EV_ABS), code 40 (ABS_MISC), value 82
Event: time 1523042552.517424, -------------- SYN_REPORT ------------
Event: time 1523042552.529426, type 3 (EV_ABS), code 1 (ABS_Y), value 3975
Event: time 1523042552.529426, type 3 (EV_ABS), code 40 (ABS_MISC), value 66
Event: time 1523042552.529426, -------------- SYN_REPORT ------------
Event: time 1523042552.537426, type 3 (EV_ABS), code 1 (ABS_Y), value 3974
Event: time 1523042552.537426, type 3 (EV_ABS), code 40 (ABS_MISC), value 44
Event: time 1523042552.537426, -------------- SYN_REPORT ------------
Event: time 1523042552.581428, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001
Event: time 1523042552.581428, type 1 (EV_KEY), code 272 (BTN_LEFT), value 0
Event: time 1523042552.581428, type 3 (EV_ABS), code 0 (ABS_X), value 39
Event: time 1523042552.581428, type 3 (EV_ABS), code 1 (ABS_Y), value 3965
Event: time 1523042552.581428, type 3 (EV_ABS), code 40 (ABS_MISC), value 0
Event: time 1523042552.581428, -------------- SYN_REPORT ------------
Event: time 1523042554.173441, type 3 (EV_ABS), code 0 (ABS_X), value 4075
Event: time 1523042554.173441, type 3 (EV_ABS), code 1 (ABS_Y), value 4003
Event: time 1523042554.173441, type 3 (EV_ABS), code 40 (ABS_MISC), value 16
Event: time 1523042554.173441, -------------- SYN_REPORT ------------
Event: time 1523042554.181437, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001
Event: time 1523042554.181437, type 1 (EV_KEY), code 272 (BTN_LEFT), value 1
Event: time 1523042554.181437, type 3 (EV_ABS), code 40 (ABS_MISC), value 20
Event: time 1523042554.181437, -------------- SYN_REPORT ------------
Event: time 1523042554.193435, type 3 (EV_ABS), code 1 (ABS_Y), value 4002
Event: time 1523042554.193435, type 3 (EV_ABS), code 40 (ABS_MISC), value 25
Event: time 1523042554.193435, -------------- SYN_REPORT ------------
Event: time 1523042554.201435, type 3 (EV_ABS), code 40 (ABS_MISC), value 30
Event: time 1523042554.201435, -------------- SYN_REPORT ------------
Event: time 1523042554.213436, type 3 (EV_ABS), code 1 (ABS_Y), value 4001
Event: time 1523042554.213436, type 3 (EV_ABS), code 40 (ABS_MISC), value 31
Event: time 1523042554.213436, -------------- SYN_REPORT ------------
Event: time 1523042554.221436, type 3 (EV_ABS), code 1 (ABS_Y), value 4000
Event: time 1523042554.221436, type 3 (EV_ABS), code 40 (ABS_MISC), value 32
Event: time 1523042554.221436, -------------- SYN_REPORT ------------
Event: time 1523042554.233438, type 3 (EV_ABS), code 0 (ABS_X), value 4074
Event: time 1523042554.233438, type 3 (EV_ABS), code 1 (ABS_Y), value 3999
Event: time 1523042554.233438, type 3 (EV_ABS), code 40 (ABS_MISC), value 33
Event: time 1523042554.233438, -------------- SYN_REPORT ------------
Event: time 1523042554.241439, type 3 (EV_ABS), code 1 (ABS_Y), value 3997
Event: time 1523042554.241439, type 3 (EV_ABS), code 40 (ABS_MISC), value 34
Event: time 1523042554.241439, -------------- SYN_REPORT ------------
Event: time 1523042554.261435, type 3 (EV_ABS), code 1 (ABS_Y), value 3996
Event: time 1523042554.261435, type 3 (EV_ABS), code 40 (ABS_MISC), value 38
Event: time 1523042554.261435, -------------- SYN_REPORT ------------
Event: time 1523042554.273438, type 3 (EV_ABS), code 0 (ABS_X), value 4073
Event: time 1523042554.273438, type 3 (EV_ABS), code 1 (ABS_Y), value 3995
Event: time 1523042554.273438, type 3 (EV_ABS), code 40 (ABS_MISC), value 39
Event: time 1523042554.273438, -------------- SYN_REPORT ------------
Event: time 1523042554.289435, type 3 (EV_ABS), code 40 (ABS_MISC), value 42
Event: time 1523042554.289435, -------------- SYN_REPORT ------------
Event: time 1523042554.309433, type 3 (EV_ABS), code 1 (ABS_Y), value 3997
Event: time 1523042554.309433, type 3 (EV_ABS), code 40 (ABS_MISC), value 49
Event: time 1523042554.309433, -------------- SYN_REPORT ------------
Event: time 1523042554.325433, type 3 (EV_ABS), code 1 (ABS_Y), value 3998
Event: time 1523042554.325433, type 3 (EV_ABS), code 40 (ABS_MISC), value 50
Event: time 1523042554.325433, -------------- SYN_REPORT ------------
Event: time 1523042554.337418, type 3 (EV_ABS), code 1 (ABS_Y), value 3999
Event: time 1523042554.337418, type 3 (EV_ABS), code 40 (ABS_MISC), value 54
Event: time 1523042554.337418, -------------- SYN_REPORT ------------
Event: time 1523042554.345417, type 3 (EV_ABS), code 1 (ABS_Y), value 4001
Event: time 1523042554.345417, type 3 (EV_ABS), code 40 (ABS_MISC), value 56
Event: time 1523042554.345417, -------------- SYN_REPORT ------------
Event: time 1523042554.357417, type 3 (EV_ABS), code 0 (ABS_X), value 4072
Event: time 1523042554.357417, type 3 (EV_ABS), code 40 (ABS_MISC), value 53
Event: time 1523042554.357417, -------------- SYN_REPORT ------------
Event: time 1523042554.369418, type 3 (EV_ABS), code 1 (ABS_Y), value 4003
Event: time 1523042554.369418, type 3 (EV_ABS), code 40 (ABS_MISC), value 52
Event: time 1523042554.369418, -------------- SYN_REPORT ------------
Event: time 1523042554.377416, type 3 (EV_ABS), code 1 (ABS_Y), value 4004
Event: time 1523042554.377416, -------------- SYN_REPORT ------------
Event: time 1523042554.385416, type 3 (EV_ABS), code 1 (ABS_Y), value 4005
Event: time 1523042554.385416, -------------- SYN_REPORT ------------
Event: time 1523042554.397416, type 3 (EV_ABS), code 1 (ABS_Y), value 4006
Event: time 1523042554.397416, -------------- SYN_REPORT ------------
Event: time 1523042554.405416, type 3 (EV_ABS), code 0 (ABS_X), value 4073
Event: time 1523042554.405416, type 3 (EV_ABS), code 1 (ABS_Y), value 4007
Event: time 1523042554.405416, -------------- SYN_REPORT ------------
Event: time 1523042554.417417, type 3 (EV_ABS), code 1 (ABS_Y), value 4009
Event: time 1523042554.417417, -------------- SYN_REPORT ------------
Event: time 1523042554.445415, type 3 (EV_ABS), code 40 (ABS_MISC), value 56
Event: time 1523042554.445415, -------------- SYN_REPORT ------------
Event: time 1523042554.453415, type 3 (EV_ABS), code 0 (ABS_X), value 4072
Event: time 1523042554.453415, type 3 (EV_ABS), code 40 (ABS_MISC), value 58
Event: time 1523042554.453415, -------------- SYN_REPORT ------------
Event: time 1523042554.465416, type 3 (EV_ABS), code 1 (ABS_Y), value 4007
Event: time 1523042554.465416, type 3 (EV_ABS), code 40 (ABS_MISC), value 59
Event: time 1523042554.465416, -------------- SYN_REPORT ------------
Event: time 1523042554.493416, type 3 (EV_ABS), code 1 (ABS_Y), value 4006
Event: time 1523042554.493416, type 3 (EV_ABS), code 40 (ABS_MISC), value 57
Event: time 1523042554.493416, -------------- SYN_REPORT ------------
Event: time 1523042554.501414, type 3 (EV_ABS), code 1 (ABS_Y), value 4004
Event: time 1523042554.501414, -------------- SYN_REPORT ------------
Event: time 1523042554.521416, type 3 (EV_ABS), code 40 (ABS_MISC), value 60
Event: time 1523042554.521416, -------------- SYN_REPORT ------------
Event: time 1523042554.529417, type 3 (EV_ABS), code 1 (ABS_Y), value 4005
Event: time 1523042554.529417, type 3 (EV_ABS), code 40 (ABS_MISC), value 62
Event: time 1523042554.529417, -------------- SYN_REPORT ------------
Event: time 1523042554.609417, type 3 (EV_ABS), code 1 (ABS_Y), value 4004
Event: time 1523042554.609417, type 3 (EV_ABS), code 40 (ABS_MISC), value 61
Event: time 1523042554.609417, -------------- SYN_REPORT ------------
Event: time 1523042554.617415, type 3 (EV_ABS), code 0 (ABS_X), value 4071
Event: time 1523042554.617415, -------------- SYN_REPORT ------------
Event: time 1523042554.669414, type 3 (EV_ABS), code 40 (ABS_MISC), value 56
Event: time 1523042554.669414, -------------- SYN_REPORT ------------
Event: time 1523042554.681415, type 3 (EV_ABS), code 40 (ABS_MISC), value 53
Event: time 1523042554.681415, -------------- SYN_REPORT ------------
Event: time 1523042554.689415, type 3 (EV_ABS), code 1 (ABS_Y), value 4003
Event: time 1523042554.689415, type 3 (EV_ABS), code 40 (ABS_MISC), value 46
Event: time 1523042554.689415, -------------- SYN_REPORT ------------
Event: time 1523042554.701415, type 3 (EV_ABS), code 0 (ABS_X), value 4072
Event: time 1523042554.701415, type 3 (EV_ABS), code 1 (ABS_Y), value 4002
Event: time 1523042554.701415, type 3 (EV_ABS), code 40 (ABS_MISC), value 34
Event: time 1523042554.701415, -------------- SYN_REPORT ------------
Event: time 1523042554.741417, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001
Event: time 1523042554.741417, type 1 (EV_KEY), code 272 (BTN_LEFT), value 0
Event: time 1523042554.741417, type 3 (EV_ABS), code 0 (ABS_X), value 4074
Event: time 1523042554.741417, type 3 (EV_ABS), code 1 (ABS_Y), value 3998
Event: time 1523042554.741417, type 3 (EV_ABS), code 40 (ABS_MISC), value 0
Event: time 1523042554.741417, -------------- SYN_REPORT ------------
Event: time 1523042556.385431, type 3 (EV_ABS), code 0 (ABS_X), value 1918
Event: time 1523042556.385431, type 3 (EV_ABS), code 1 (ABS_Y), value 2022
Event: time 1523042556.385431, type 3 (EV_ABS), code 40 (ABS_MISC), value 28
Event: time 1523042556.385431, -------------- SYN_REPORT ------------
Event: time 1523042556.397429, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001
Event: time 1523042556.397429, type 1 (EV_KEY), code 272 (BTN_LEFT), value 1
Event: time 1523042556.397429, type 3 (EV_ABS), code 40 (ABS_MISC), value 40
Event: time 1523042556.397429, -------------- SYN_REPORT ------------
Event: time 1523042556.405423, type 3 (EV_ABS), code 40 (ABS_MISC), value 55
Event: time 1523042556.405423, -------------- SYN_REPORT ------------
Event: time 1523042556.417426, type 3 (EV_ABS), code 40 (ABS_MISC), value 71
Event: time 1523042556.417426, -------------- SYN_REPORT ------------
Event: time 1523042556.425425, type 3 (EV_ABS), code 1 (ABS_Y), value 2024
Event: time 1523042556.425425, type 3 (EV_ABS), code 40 (ABS_MISC), value 86
Event: time 1523042556.425425, -------------- SYN_REPORT ------------
Event: time 1523042556.437424, type 3 (EV_ABS), code 0 (ABS_X), value 1919
Event: time 1523042556.437424, type 3 (EV_ABS), code 40 (ABS_MISC), value 100
Event: time 1523042556.437424, -------------- SYN_REPORT ------------
Event: time 1523042556.449423, type 3 (EV_ABS), code 40 (ABS_MISC), value 112
Event: time 1523042556.449423, -------------- SYN_REPORT ------------
Event: time 1523042556.457423, type 3 (EV_ABS), code 40 (ABS_MISC), value 122
Event: time 1523042556.457423, -------------- SYN_REPORT ------------
Event: time 1523042556.469421, type 3 (EV_ABS), code 40 (ABS_MISC), value 130
Event: time 1523042556.469421, -------------- SYN_REPORT ------------
Event: time 1523042556.477424, type 3 (EV_ABS), code 1 (ABS_Y), value 2025
Event: time 1523042556.477424, type 3 (EV_ABS), code 40 (ABS_MISC), value 136
Event: time 1523042556.477424, -------------- SYN_REPORT ------------
Event: time 1523042556.489425, type 3 (EV_ABS), code 0 (ABS_X), value 1920
Event: time 1523042556.489425, type 3 (EV_ABS), code 40 (ABS_MISC), value 139
Event: time 1523042556.489425, -------------- SYN_REPORT ------------
Event: time 1523042556.497427, type 3 (EV_ABS), code 1 (ABS_Y), value 2024
Event: time 1523042556.497427, type 3 (EV_ABS), code 40 (ABS_MISC), value 140
Event: time 1523042556.497427, -------------- SYN_REPORT ------------
Event: time 1523042556.509420, type 3 (EV_ABS), code 40 (ABS_MISC), value 137
Event: time 1523042556.509420, -------------- SYN_REPORT ------------
Event: time 1523042556.517422, type 3 (EV_ABS), code 0 (ABS_X), value 1919
Event: time 1523042556.517422, type 3 (EV_ABS), code 40 (ABS_MISC), value 135
Event: time 1523042556.517422, -------------- SYN_REPORT ------------
Event: time 1523042556.561425, type 3 (EV_ABS), code 0 (ABS_X), value 1918
Event: time 1523042556.561425, type 3 (EV_ABS), code 40 (ABS_MISC), value 139
Event: time 1523042556.561425, -------------- SYN_REPORT ------------
Event: time 1523042556.581421, type 3 (EV_ABS), code 40 (ABS_MISC), value 136
Event: time 1523042556.581421, -------------- SYN_REPORT ------------
Event: time 1523042556.593424, type 3 (EV_ABS), code 0 (ABS_X), value 1917
Event: time 1523042556.593424, type 3 (EV_ABS), code 40 (ABS_MISC), value 116
Event: time 1523042556.593424, -------------- SYN_REPORT ------------
Event: time 1523042556.601425, type 3 (EV_ABS), code 40 (ABS_MISC), value 85
Event: time 1523042556.601425, -------------- SYN_REPORT ------------
Event: time 1523042556.613424, type 3 (EV_ABS), code 0 (ABS_X), value 1916
Event: time 1523042556.613424, type 3 (EV_ABS), code 1 (ABS_Y), value 2022
Event: time 1523042556.613424, type 3 (EV_ABS), code 40 (ABS_MISC), value 55
Event: time 1523042556.613424, -------------- SYN_REPORT ------------
Event: time 1523042556.653424, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001
Event: time 1523042556.653424, type 1 (EV_KEY), code 272 (BTN_LEFT), value 0
Event: time 1523042556.653424, type 3 (EV_ABS), code 40 (ABS_MISC), value 0
Event: time 1523042556.653424, -------------- SYN_REPORT ------------
Hi GeoffB,GeoffB wrote: ↑Fri Apr 06, 2018 7:32 pmHi Jurgen
Thanks for the response here is the event.log from evtest
The touch.log from fruitbox-1-11-jurgen4 has nothing in it because fruitbox doesn't recognize the ELO Touchscreen. If I use the touchscreen in the Raspbian Desktop everything works fine.Code: Select all
Input driver version is 1.0.1 Input device ID: bus 0x3 vendor 0x4e7 product 0x20 version 0x100 Input device name: "Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface" Supported events: Event type 0 (EV_SYN) Event type 1 (EV_KEY) Event code 272 (BTN_LEFT) Event type 3 (EV_ABS) Event code 0 (ABS_X) Value 1998 Min 0 Max 4095 Event code 1 (ABS_Y) Value 1809 Min 0 Max 4095 Event code 40 (ABS_MISC) Value 0 Min 0 Max 256 Event type 4 (EV_MSC) Event code 4 (MSC_SCAN) Properties: Testing ... (interrupt to exit) Event: time 1523042547.661481, type 3 (EV_ABS), code 0 (ABS_X), value 53 Event: time 1523042547.661481, type 3 (EV_ABS), code 1 (ABS_Y), value 18 Event: time 1523042547.661481, type 3 (EV_ABS), code 40 (ABS_MISC), value 27 Event: time 1523042547.661481, -------------- SYN_REPORT ------------ Event: time 1523042547.669470, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001 Event: time 1523042547.669470, type 1 (EV_KEY), code 272 (BTN_LEFT), value 1 Event: time 1523042547.669470, type 3 (EV_ABS), code 1 (ABS_Y), value 19 Event: time 1523042547.669470, type 3 (EV_ABS), code 40 (ABS_MISC), value 31 Event: time 1523042547.669470, -------------- SYN_REPORT ------------ Event: time 1523042547.681475, type 3 (EV_ABS), code 1 (ABS_Y), value 20 Event: time 1523042547.681475, type 3 (EV_ABS), code 40 (ABS_MISC), value 37 Event: time 1523042547.681475, -------------- SYN_REPORT ------------ Event: time 1523042547.689470, type 3 (EV_ABS), code 40 (ABS_MISC), value 45 Event: time 1523042547.689470, -------------- SYN_REPORT ------------ Event: time 1523042547.701466, type 3 (EV_ABS), code 1 (ABS_Y), value 21 Event: time 1523042547.701466, type 3 (EV_ABS), code 40 (ABS_MISC), value 55 Event: time 1523042547.701466, -------------- SYN_REPORT ------------ Event: time 1523042547.709464, type 3 (EV_ABS), code 40 (ABS_MISC), value 66 Event: time 1523042547.709464, -------------- SYN_REPORT ------------ Event: time 1523042547.721469, type 3 (EV_ABS), code 0 (ABS_X), value 54 Event: time 1523042547.721469, type 3 (EV_ABS), code 40 (ABS_MISC), value 76 Event: time 1523042547.721469, -------------- SYN_REPORT ------------ Event: time 1523042547.729469, type 3 (EV_ABS), code 0 (ABS_X), value 53 Event: time 1523042547.729469, type 3 (EV_ABS), code 1 (ABS_Y), value 22 Event: time 1523042547.729469, type 3 (EV_ABS), code 40 (ABS_MISC), value 83 Event: time 1523042547.729469, -------------- SYN_REPORT ------------ Event: time 1523042547.741469, type 3 (EV_ABS), code 40 (ABS_MISC), value 92 Event: time 1523042547.741469, -------------- SYN_REPORT ------------ Event: time 1523042547.749465, type 3 (EV_ABS), code 1 (ABS_Y), value 23 Event: time 1523042547.749465, type 3 (EV_ABS), code 40 (ABS_MISC), value 100 Event: time 1523042547.749465, -------------- SYN_REPORT ------------ Event: time 1523042547.761467, type 3 (EV_ABS), code 40 (ABS_MISC), value 108 Event: time 1523042547.761467, -------------- SYN_REPORT ------------ Event: time 1523042547.769450, type 3 (EV_ABS), code 1 (ABS_Y), value 24 Event: time 1523042547.769450, type 3 (EV_ABS), code 40 (ABS_MISC), value 114 Event: time 1523042547.769450, -------------- SYN_REPORT ------------ Event: time 1523042547.781446, type 3 (EV_ABS), code 40 (ABS_MISC), value 119 Event: time 1523042547.781446, -------------- SYN_REPORT ------------ Event: time 1523042547.793448, type 3 (EV_ABS), code 1 (ABS_Y), value 25 Event: time 1523042547.793448, type 3 (EV_ABS), code 40 (ABS_MISC), value 123 Event: time 1523042547.793448, -------------- SYN_REPORT ------------ Event: time 1523042547.801448, type 3 (EV_ABS), code 1 (ABS_Y), value 26 Event: time 1523042547.801448, type 3 (EV_ABS), code 40 (ABS_MISC), value 130 Event: time 1523042547.801448, -------------- SYN_REPORT ------------ Event: time 1523042547.813447, type 3 (EV_ABS), code 1 (ABS_Y), value 27 Event: time 1523042547.813447, type 3 (EV_ABS), code 40 (ABS_MISC), value 135 Event: time 1523042547.813447, -------------- SYN_REPORT ------------ Event: time 1523042547.849448, type 3 (EV_ABS), code 40 (ABS_MISC), value 132 Event: time 1523042547.849448, -------------- SYN_REPORT ------------ Event: time 1523042547.857447, type 3 (EV_ABS), code 40 (ABS_MISC), value 135 Event: time 1523042547.857447, -------------- SYN_REPORT ------------ Event: time 1523042547.877447, type 3 (EV_ABS), code 1 (ABS_Y), value 28 Event: time 1523042547.877447, type 3 (EV_ABS), code 40 (ABS_MISC), value 139 Event: time 1523042547.877447, -------------- SYN_REPORT ------------ Event: time 1523042547.885445, type 3 (EV_ABS), code 40 (ABS_MISC), value 142 Event: time 1523042547.885445, -------------- SYN_REPORT ------------ Event: time 1523042547.897449, type 3 (EV_ABS), code 1 (ABS_Y), value 29 Event: time 1523042547.897449, type 3 (EV_ABS), code 40 (ABS_MISC), value 143 Event: time 1523042547.897449, -------------- SYN_REPORT ------------ Event: time 1523042547.905448, type 3 (EV_ABS), code 0 (ABS_X), value 54 Event: time 1523042547.905448, type 3 (EV_ABS), code 40 (ABS_MISC), value 144 Event: time 1523042547.905448, -------------- SYN_REPORT ------------ Event: time 1523042547.925446, type 3 (EV_ABS), code 1 (ABS_Y), value 30 Event: time 1523042547.925446, -------------- SYN_REPORT ------------ Event: time 1523042547.961447, type 3 (EV_ABS), code 0 (ABS_X), value 55 Event: time 1523042547.961447, type 3 (EV_ABS), code 40 (ABS_MISC), value 141 Event: time 1523042547.961447, -------------- SYN_REPORT ------------ Event: time 1523042547.973445, type 3 (EV_ABS), code 40 (ABS_MISC), value 137 Event: time 1523042547.973445, -------------- SYN_REPORT ------------ Event: time 1523042547.981446, type 3 (EV_ABS), code 1 (ABS_Y), value 31 Event: time 1523042547.981446, type 3 (EV_ABS), code 40 (ABS_MISC), value 128 Event: time 1523042547.981446, -------------- SYN_REPORT ------------ Event: time 1523042547.993448, type 3 (EV_ABS), code 1 (ABS_Y), value 30 Event: time 1523042547.993448, type 3 (EV_ABS), code 40 (ABS_MISC), value 112 Event: time 1523042547.993448, -------------- SYN_REPORT ------------ Event: time 1523042548.001447, type 3 (EV_ABS), code 40 (ABS_MISC), value 86 Event: time 1523042548.001447, -------------- SYN_REPORT ------------ Event: time 1523042548.009447, type 3 (EV_ABS), code 1 (ABS_Y), value 29 Event: time 1523042548.009447, type 3 (EV_ABS), code 40 (ABS_MISC), value 56 Event: time 1523042548.009447, -------------- SYN_REPORT ------------ Event: time 1523042548.049451, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001 Event: time 1523042548.049451, type 1 (EV_KEY), code 272 (BTN_LEFT), value 0 Event: time 1523042548.049451, type 3 (EV_ABS), code 0 (ABS_X), value 56 Event: time 1523042548.049451, type 3 (EV_ABS), code 1 (ABS_Y), value 24 Event: time 1523042548.049451, type 3 (EV_ABS), code 40 (ABS_MISC), value 0 Event: time 1523042548.049451, -------------- SYN_REPORT ------------ Event: time 1523042549.837471, type 3 (EV_ABS), code 0 (ABS_X), value 4089 Event: time 1523042549.837471, type 3 (EV_ABS), code 1 (ABS_Y), value 28 Event: time 1523042549.837471, type 3 (EV_ABS), code 40 (ABS_MISC), value 23 Event: time 1523042549.837471, -------------- SYN_REPORT ------------ Event: time 1523042549.849462, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001 Event: time 1523042549.849462, type 1 (EV_KEY), code 272 (BTN_LEFT), value 1 Event: time 1523042549.849462, type 3 (EV_ABS), code 0 (ABS_X), value 4088 Event: time 1523042549.849462, type 3 (EV_ABS), code 40 (ABS_MISC), value 26 Event: time 1523042549.849462, -------------- SYN_REPORT ------------ Event: time 1523042549.857460, type 3 (EV_ABS), code 0 (ABS_X), value 4087 Event: time 1523042549.857460, type 3 (EV_ABS), code 1 (ABS_Y), value 29 Event: time 1523042549.857460, type 3 (EV_ABS), code 40 (ABS_MISC), value 30 Event: time 1523042549.857460, -------------- SYN_REPORT ------------ Event: time 1523042549.869453, type 3 (EV_ABS), code 40 (ABS_MISC), value 34 Event: time 1523042549.869453, -------------- SYN_REPORT ------------ Event: time 1523042549.877457, type 3 (EV_ABS), code 0 (ABS_X), value 4086 Event: time 1523042549.877457, type 3 (EV_ABS), code 40 (ABS_MISC), value 40 Event: time 1523042549.877457, -------------- SYN_REPORT ------------ Event: time 1523042549.889460, type 3 (EV_ABS), code 0 (ABS_X), value 4085 Event: time 1523042549.889460, type 3 (EV_ABS), code 40 (ABS_MISC), value 45 Event: time 1523042549.889460, -------------- SYN_REPORT ------------ Event: time 1523042549.897458, type 3 (EV_ABS), code 0 (ABS_X), value 4084 Event: time 1523042549.897458, type 3 (EV_ABS), code 40 (ABS_MISC), value 51 Event: time 1523042549.897458, -------------- SYN_REPORT ------------ Event: time 1523042549.909453, type 3 (EV_ABS), code 40 (ABS_MISC), value 57 Event: time 1523042549.909453, -------------- SYN_REPORT ------------ Event: time 1523042549.917455, type 3 (EV_ABS), code 0 (ABS_X), value 4083 Event: time 1523042549.917455, type 3 (EV_ABS), code 40 (ABS_MISC), value 64 Event: time 1523042549.917455, -------------- SYN_REPORT ------------ Event: time 1523042549.929457, type 3 (EV_ABS), code 0 (ABS_X), value 4082 Event: time 1523042549.929457, type 3 (EV_ABS), code 40 (ABS_MISC), value 73 Event: time 1523042549.929457, -------------- SYN_REPORT ------------ Event: time 1523042549.937443, type 3 (EV_ABS), code 0 (ABS_X), value 4081 Event: time 1523042549.937443, type 3 (EV_ABS), code 1 (ABS_Y), value 28 Event: time 1523042549.937443, type 3 (EV_ABS), code 40 (ABS_MISC), value 82 Event: time 1523042549.937443, -------------- SYN_REPORT ------------ Event: time 1523042549.949437, type 3 (EV_ABS), code 0 (ABS_X), value 4080 Event: time 1523042549.949437, type 3 (EV_ABS), code 40 (ABS_MISC), value 90 Event: time 1523042549.949437, -------------- SYN_REPORT ------------ Event: time 1523042549.961439, type 3 (EV_ABS), code 0 (ABS_X), value 4079 Event: time 1523042549.961439, type 3 (EV_ABS), code 1 (ABS_Y), value 29 Event: time 1523042549.961439, type 3 (EV_ABS), code 40 (ABS_MISC), value 99 Event: time 1523042549.961439, -------------- SYN_REPORT ------------ Event: time 1523042549.969437, type 3 (EV_ABS), code 40 (ABS_MISC), value 107 Event: time 1523042549.969437, -------------- SYN_REPORT ------------ Event: time 1523042549.981438, type 3 (EV_ABS), code 0 (ABS_X), value 4077 Event: time 1523042549.981438, type 3 (EV_ABS), code 40 (ABS_MISC), value 114 Event: time 1523042549.981438, -------------- SYN_REPORT ------------ Event: time 1523042549.989436, type 3 (EV_ABS), code 0 (ABS_X), value 4076 Event: time 1523042549.989436, type 3 (EV_ABS), code 40 (ABS_MISC), value 121 Event: time 1523042549.989436, -------------- SYN_REPORT ------------ Event: time 1523042550.001438, type 3 (EV_ABS), code 1 (ABS_Y), value 30 Event: time 1523042550.001438, type 3 (EV_ABS), code 40 (ABS_MISC), value 126 Event: time 1523042550.001438, -------------- SYN_REPORT ------------ Event: time 1523042550.009437, type 3 (EV_ABS), code 0 (ABS_X), value 4075 Event: time 1523042550.009437, type 3 (EV_ABS), code 40 (ABS_MISC), value 130 Event: time 1523042550.009437, -------------- SYN_REPORT ------------ Event: time 1523042550.021436, type 3 (EV_ABS), code 0 (ABS_X), value 4076 Event: time 1523042550.021436, type 3 (EV_ABS), code 40 (ABS_MISC), value 132 Event: time 1523042550.021436, -------------- SYN_REPORT ------------ Event: time 1523042550.029437, type 3 (EV_ABS), code 0 (ABS_X), value 4075 Event: time 1523042550.029437, type 3 (EV_ABS), code 1 (ABS_Y), value 29 Event: time 1523042550.029437, type 3 (EV_ABS), code 40 (ABS_MISC), value 133 Event: time 1523042550.029437, -------------- SYN_REPORT ------------ Event: time 1523042550.041438, type 3 (EV_ABS), code 1 (ABS_Y), value 30 Event: time 1523042550.041438, type 3 (EV_ABS), code 40 (ABS_MISC), value 130 Event: time 1523042550.041438, -------------- SYN_REPORT ------------ Event: time 1523042550.049438, type 3 (EV_ABS), code 1 (ABS_Y), value 29 Event: time 1523042550.049438, type 3 (EV_ABS), code 40 (ABS_MISC), value 128 Event: time 1523042550.049438, -------------- SYN_REPORT ------------ Event: time 1523042550.061436, type 3 (EV_ABS), code 1 (ABS_Y), value 30 Event: time 1523042550.061436, type 3 (EV_ABS), code 40 (ABS_MISC), value 127 Event: time 1523042550.061436, -------------- SYN_REPORT ------------ Event: time 1523042550.069435, type 3 (EV_ABS), code 40 (ABS_MISC), value 130 Event: time 1523042550.069435, -------------- SYN_REPORT ------------ Event: time 1523042550.089438, type 3 (EV_ABS), code 1 (ABS_Y), value 31 Event: time 1523042550.089438, type 3 (EV_ABS), code 40 (ABS_MISC), value 125 Event: time 1523042550.089438, -------------- SYN_REPORT ------------ Event: time 1523042550.101435, type 3 (EV_ABS), code 40 (ABS_MISC), value 122 Event: time 1523042550.101435, -------------- SYN_REPORT ------------ Event: time 1523042550.109435, type 3 (EV_ABS), code 40 (ABS_MISC), value 116 Event: time 1523042550.109435, -------------- SYN_REPORT ------------ Event: time 1523042550.121437, type 3 (EV_ABS), code 1 (ABS_Y), value 30 Event: time 1523042550.121437, type 3 (EV_ABS), code 40 (ABS_MISC), value 107 Event: time 1523042550.121437, -------------- SYN_REPORT ------------ Event: time 1523042550.129436, type 3 (EV_ABS), code 40 (ABS_MISC), value 88 Event: time 1523042550.129436, -------------- SYN_REPORT ------------ Event: time 1523042550.141436, type 3 (EV_ABS), code 0 (ABS_X), value 4076 Event: time 1523042550.141436, type 3 (EV_ABS), code 1 (ABS_Y), value 29 Event: time 1523042550.141436, type 3 (EV_ABS), code 40 (ABS_MISC), value 64 Event: time 1523042550.141436, -------------- SYN_REPORT ------------ Event: time 1523042550.149436, type 3 (EV_ABS), code 0 (ABS_X), value 4077 Event: time 1523042550.149436, type 3 (EV_ABS), code 40 (ABS_MISC), value 42 Event: time 1523042550.149436, -------------- SYN_REPORT ------------ Event: time 1523042550.193441, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001 Event: time 1523042550.193441, type 1 (EV_KEY), code 272 (BTN_LEFT), value 0 Event: time 1523042550.193441, type 3 (EV_ABS), code 0 (ABS_X), value 4083 Event: time 1523042550.193441, type 3 (EV_ABS), code 1 (ABS_Y), value 21 Event: time 1523042550.193441, type 3 (EV_ABS), code 40 (ABS_MISC), value 0 Event: time 1523042550.193441, -------------- SYN_REPORT ------------ Event: time 1523042552.153458, type 3 (EV_ABS), code 0 (ABS_X), value 45 Event: time 1523042552.153458, type 3 (EV_ABS), code 1 (ABS_Y), value 3965 Event: time 1523042552.153458, type 3 (EV_ABS), code 40 (ABS_MISC), value 23 Event: time 1523042552.153458, -------------- SYN_REPORT ------------ Event: time 1523042552.161453, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001 Event: time 1523042552.161453, type 1 (EV_KEY), code 272 (BTN_LEFT), value 1 Event: time 1523042552.161453, type 3 (EV_ABS), code 1 (ABS_Y), value 3966 Event: time 1523042552.161453, type 3 (EV_ABS), code 40 (ABS_MISC), value 29 Event: time 1523042552.161453, -------------- SYN_REPORT ------------ Event: time 1523042552.173445, type 3 (EV_ABS), code 40 (ABS_MISC), value 37 Event: time 1523042552.173445, -------------- SYN_REPORT ------------ Event: time 1523042552.181446, type 3 (EV_ABS), code 1 (ABS_Y), value 3968 Event: time 1523042552.181446, type 3 (EV_ABS), code 40 (ABS_MISC), value 44 Event: time 1523042552.181446, -------------- SYN_REPORT ------------ Event: time 1523042552.193446, type 3 (EV_ABS), code 1 (ABS_Y), value 3969 Event: time 1523042552.193446, type 3 (EV_ABS), code 40 (ABS_MISC), value 51 Event: time 1523042552.193446, -------------- SYN_REPORT ------------ Event: time 1523042552.201449, type 3 (EV_ABS), code 1 (ABS_Y), value 3970 Event: time 1523042552.201449, type 3 (EV_ABS), code 40 (ABS_MISC), value 59 Event: time 1523042552.201449, -------------- SYN_REPORT ------------ Event: time 1523042552.213445, type 3 (EV_ABS), code 0 (ABS_X), value 44 Event: time 1523042552.213445, type 3 (EV_ABS), code 1 (ABS_Y), value 3971 Event: time 1523042552.213445, type 3 (EV_ABS), code 40 (ABS_MISC), value 66 Event: time 1523042552.213445, -------------- SYN_REPORT ------------ Event: time 1523042552.221443, type 3 (EV_ABS), code 40 (ABS_MISC), value 72 Event: time 1523042552.221443, -------------- SYN_REPORT ------------ Event: time 1523042552.233446, type 3 (EV_ABS), code 1 (ABS_Y), value 3972 Event: time 1523042552.233446, type 3 (EV_ABS), code 40 (ABS_MISC), value 80 Event: time 1523042552.233446, -------------- SYN_REPORT ------------ Event: time 1523042552.241449, type 3 (EV_ABS), code 0 (ABS_X), value 43 Event: time 1523042552.241449, type 3 (EV_ABS), code 1 (ABS_Y), value 3973 Event: time 1523042552.241449, type 3 (EV_ABS), code 40 (ABS_MISC), value 87 Event: time 1523042552.241449, -------------- SYN_REPORT ------------ Event: time 1523042552.253444, type 3 (EV_ABS), code 1 (ABS_Y), value 3974 Event: time 1523042552.253444, type 3 (EV_ABS), code 40 (ABS_MISC), value 94 Event: time 1523042552.253444, -------------- SYN_REPORT ------------ Event: time 1523042552.261427, type 3 (EV_ABS), code 1 (ABS_Y), value 3975 Event: time 1523042552.261427, type 3 (EV_ABS), code 40 (ABS_MISC), value 96 Event: time 1523042552.261427, -------------- SYN_REPORT ------------ Event: time 1523042552.273427, type 3 (EV_ABS), code 1 (ABS_Y), value 3976 Event: time 1523042552.273427, type 3 (EV_ABS), code 40 (ABS_MISC), value 99 Event: time 1523042552.273427, -------------- SYN_REPORT ------------ Event: time 1523042552.281427, type 3 (EV_ABS), code 1 (ABS_Y), value 3977 Event: time 1523042552.281427, type 3 (EV_ABS), code 40 (ABS_MISC), value 108 Event: time 1523042552.281427, -------------- SYN_REPORT ------------ Event: time 1523042552.293427, type 3 (EV_ABS), code 0 (ABS_X), value 42 Event: time 1523042552.293427, type 3 (EV_ABS), code 1 (ABS_Y), value 3978 Event: time 1523042552.293427, type 3 (EV_ABS), code 40 (ABS_MISC), value 115 Event: time 1523042552.293427, -------------- SYN_REPORT ------------ Event: time 1523042552.301425, type 3 (EV_ABS), code 40 (ABS_MISC), value 118 Event: time 1523042552.301425, -------------- SYN_REPORT ------------ Event: time 1523042552.313427, type 3 (EV_ABS), code 1 (ABS_Y), value 3979 Event: time 1523042552.313427, type 3 (EV_ABS), code 40 (ABS_MISC), value 120 Event: time 1523042552.313427, -------------- SYN_REPORT ------------ Event: time 1523042552.333427, type 3 (EV_ABS), code 0 (ABS_X), value 41 Event: time 1523042552.333427, type 3 (EV_ABS), code 1 (ABS_Y), value 3980 Event: time 1523042552.333427, type 3 (EV_ABS), code 40 (ABS_MISC), value 119 Event: time 1523042552.333427, -------------- SYN_REPORT ------------ Event: time 1523042552.341427, type 3 (EV_ABS), code 1 (ABS_Y), value 3979 Event: time 1523042552.341427, type 3 (EV_ABS), code 40 (ABS_MISC), value 113 Event: time 1523042552.341427, -------------- SYN_REPORT ------------ Event: time 1523042552.353426, type 3 (EV_ABS), code 40 (ABS_MISC), value 108 Event: time 1523042552.353426, -------------- SYN_REPORT ------------ Event: time 1523042552.369428, type 3 (EV_ABS), code 0 (ABS_X), value 42 Event: time 1523042552.369428, type 3 (EV_ABS), code 1 (ABS_Y), value 3978 Event: time 1523042552.369428, type 3 (EV_ABS), code 40 (ABS_MISC), value 105 Event: time 1523042552.369428, -------------- SYN_REPORT ------------ Event: time 1523042552.425428, type 3 (EV_ABS), code 0 (ABS_X), value 41 Event: time 1523042552.425428, type 3 (EV_ABS), code 40 (ABS_MISC), value 107 Event: time 1523042552.425428, -------------- SYN_REPORT ------------ Event: time 1523042552.457426, type 3 (EV_ABS), code 40 (ABS_MISC), value 110 Event: time 1523042552.457426, -------------- SYN_REPORT ------------ Event: time 1523042552.477424, type 3 (EV_ABS), code 40 (ABS_MISC), value 107 Event: time 1523042552.477424, -------------- SYN_REPORT ------------ Event: time 1523042552.489425, type 3 (EV_ABS), code 40 (ABS_MISC), value 103 Event: time 1523042552.489425, -------------- SYN_REPORT ------------ Event: time 1523042552.497426, type 3 (EV_ABS), code 40 (ABS_MISC), value 98 Event: time 1523042552.497426, -------------- SYN_REPORT ------------ Event: time 1523042552.509425, type 3 (EV_ABS), code 1 (ABS_Y), value 3976 Event: time 1523042552.509425, type 3 (EV_ABS), code 40 (ABS_MISC), value 92 Event: time 1523042552.509425, -------------- SYN_REPORT ------------ Event: time 1523042552.517424, type 3 (EV_ABS), code 40 (ABS_MISC), value 82 Event: time 1523042552.517424, -------------- SYN_REPORT ------------ Event: time 1523042552.529426, type 3 (EV_ABS), code 1 (ABS_Y), value 3975 Event: time 1523042552.529426, type 3 (EV_ABS), code 40 (ABS_MISC), value 66 Event: time 1523042552.529426, -------------- SYN_REPORT ------------ Event: time 1523042552.537426, type 3 (EV_ABS), code 1 (ABS_Y), value 3974 Event: time 1523042552.537426, type 3 (EV_ABS), code 40 (ABS_MISC), value 44 Event: time 1523042552.537426, -------------- SYN_REPORT ------------ Event: time 1523042552.581428, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001 Event: time 1523042552.581428, type 1 (EV_KEY), code 272 (BTN_LEFT), value 0 Event: time 1523042552.581428, type 3 (EV_ABS), code 0 (ABS_X), value 39 Event: time 1523042552.581428, type 3 (EV_ABS), code 1 (ABS_Y), value 3965 Event: time 1523042552.581428, type 3 (EV_ABS), code 40 (ABS_MISC), value 0 Event: time 1523042552.581428, -------------- SYN_REPORT ------------ Event: time 1523042554.173441, type 3 (EV_ABS), code 0 (ABS_X), value 4075 Event: time 1523042554.173441, type 3 (EV_ABS), code 1 (ABS_Y), value 4003 Event: time 1523042554.173441, type 3 (EV_ABS), code 40 (ABS_MISC), value 16 Event: time 1523042554.173441, -------------- SYN_REPORT ------------ Event: time 1523042554.181437, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001 Event: time 1523042554.181437, type 1 (EV_KEY), code 272 (BTN_LEFT), value 1 Event: time 1523042554.181437, type 3 (EV_ABS), code 40 (ABS_MISC), value 20 Event: time 1523042554.181437, -------------- SYN_REPORT ------------ Event: time 1523042554.193435, type 3 (EV_ABS), code 1 (ABS_Y), value 4002 Event: time 1523042554.193435, type 3 (EV_ABS), code 40 (ABS_MISC), value 25 Event: time 1523042554.193435, -------------- SYN_REPORT ------------ Event: time 1523042554.201435, type 3 (EV_ABS), code 40 (ABS_MISC), value 30 Event: time 1523042554.201435, -------------- SYN_REPORT ------------ Event: time 1523042554.213436, type 3 (EV_ABS), code 1 (ABS_Y), value 4001 Event: time 1523042554.213436, type 3 (EV_ABS), code 40 (ABS_MISC), value 31 Event: time 1523042554.213436, -------------- SYN_REPORT ------------ Event: time 1523042554.221436, type 3 (EV_ABS), code 1 (ABS_Y), value 4000 Event: time 1523042554.221436, type 3 (EV_ABS), code 40 (ABS_MISC), value 32 Event: time 1523042554.221436, -------------- SYN_REPORT ------------ Event: time 1523042554.233438, type 3 (EV_ABS), code 0 (ABS_X), value 4074 Event: time 1523042554.233438, type 3 (EV_ABS), code 1 (ABS_Y), value 3999 Event: time 1523042554.233438, type 3 (EV_ABS), code 40 (ABS_MISC), value 33 Event: time 1523042554.233438, -------------- SYN_REPORT ------------ Event: time 1523042554.241439, type 3 (EV_ABS), code 1 (ABS_Y), value 3997 Event: time 1523042554.241439, type 3 (EV_ABS), code 40 (ABS_MISC), value 34 Event: time 1523042554.241439, -------------- SYN_REPORT ------------ Event: time 1523042554.261435, type 3 (EV_ABS), code 1 (ABS_Y), value 3996 Event: time 1523042554.261435, type 3 (EV_ABS), code 40 (ABS_MISC), value 38 Event: time 1523042554.261435, -------------- SYN_REPORT ------------ Event: time 1523042554.273438, type 3 (EV_ABS), code 0 (ABS_X), value 4073 Event: time 1523042554.273438, type 3 (EV_ABS), code 1 (ABS_Y), value 3995 Event: time 1523042554.273438, type 3 (EV_ABS), code 40 (ABS_MISC), value 39 Event: time 1523042554.273438, -------------- SYN_REPORT ------------ Event: time 1523042554.289435, type 3 (EV_ABS), code 40 (ABS_MISC), value 42 Event: time 1523042554.289435, -------------- SYN_REPORT ------------ Event: time 1523042554.309433, type 3 (EV_ABS), code 1 (ABS_Y), value 3997 Event: time 1523042554.309433, type 3 (EV_ABS), code 40 (ABS_MISC), value 49 Event: time 1523042554.309433, -------------- SYN_REPORT ------------ Event: time 1523042554.325433, type 3 (EV_ABS), code 1 (ABS_Y), value 3998 Event: time 1523042554.325433, type 3 (EV_ABS), code 40 (ABS_MISC), value 50 Event: time 1523042554.325433, -------------- SYN_REPORT ------------ Event: time 1523042554.337418, type 3 (EV_ABS), code 1 (ABS_Y), value 3999 Event: time 1523042554.337418, type 3 (EV_ABS), code 40 (ABS_MISC), value 54 Event: time 1523042554.337418, -------------- SYN_REPORT ------------ Event: time 1523042554.345417, type 3 (EV_ABS), code 1 (ABS_Y), value 4001 Event: time 1523042554.345417, type 3 (EV_ABS), code 40 (ABS_MISC), value 56 Event: time 1523042554.345417, -------------- SYN_REPORT ------------ Event: time 1523042554.357417, type 3 (EV_ABS), code 0 (ABS_X), value 4072 Event: time 1523042554.357417, type 3 (EV_ABS), code 40 (ABS_MISC), value 53 Event: time 1523042554.357417, -------------- SYN_REPORT ------------ Event: time 1523042554.369418, type 3 (EV_ABS), code 1 (ABS_Y), value 4003 Event: time 1523042554.369418, type 3 (EV_ABS), code 40 (ABS_MISC), value 52 Event: time 1523042554.369418, -------------- SYN_REPORT ------------ Event: time 1523042554.377416, type 3 (EV_ABS), code 1 (ABS_Y), value 4004 Event: time 1523042554.377416, -------------- SYN_REPORT ------------ Event: time 1523042554.385416, type 3 (EV_ABS), code 1 (ABS_Y), value 4005 Event: time 1523042554.385416, -------------- SYN_REPORT ------------ Event: time 1523042554.397416, type 3 (EV_ABS), code 1 (ABS_Y), value 4006 Event: time 1523042554.397416, -------------- SYN_REPORT ------------ Event: time 1523042554.405416, type 3 (EV_ABS), code 0 (ABS_X), value 4073 Event: time 1523042554.405416, type 3 (EV_ABS), code 1 (ABS_Y), value 4007 Event: time 1523042554.405416, -------------- SYN_REPORT ------------ Event: time 1523042554.417417, type 3 (EV_ABS), code 1 (ABS_Y), value 4009 Event: time 1523042554.417417, -------------- SYN_REPORT ------------ Event: time 1523042554.445415, type 3 (EV_ABS), code 40 (ABS_MISC), value 56 Event: time 1523042554.445415, -------------- SYN_REPORT ------------ Event: time 1523042554.453415, type 3 (EV_ABS), code 0 (ABS_X), value 4072 Event: time 1523042554.453415, type 3 (EV_ABS), code 40 (ABS_MISC), value 58 Event: time 1523042554.453415, -------------- SYN_REPORT ------------ Event: time 1523042554.465416, type 3 (EV_ABS), code 1 (ABS_Y), value 4007 Event: time 1523042554.465416, type 3 (EV_ABS), code 40 (ABS_MISC), value 59 Event: time 1523042554.465416, -------------- SYN_REPORT ------------ Event: time 1523042554.493416, type 3 (EV_ABS), code 1 (ABS_Y), value 4006 Event: time 1523042554.493416, type 3 (EV_ABS), code 40 (ABS_MISC), value 57 Event: time 1523042554.493416, -------------- SYN_REPORT ------------ Event: time 1523042554.501414, type 3 (EV_ABS), code 1 (ABS_Y), value 4004 Event: time 1523042554.501414, -------------- SYN_REPORT ------------ Event: time 1523042554.521416, type 3 (EV_ABS), code 40 (ABS_MISC), value 60 Event: time 1523042554.521416, -------------- SYN_REPORT ------------ Event: time 1523042554.529417, type 3 (EV_ABS), code 1 (ABS_Y), value 4005 Event: time 1523042554.529417, type 3 (EV_ABS), code 40 (ABS_MISC), value 62 Event: time 1523042554.529417, -------------- SYN_REPORT ------------ Event: time 1523042554.609417, type 3 (EV_ABS), code 1 (ABS_Y), value 4004 Event: time 1523042554.609417, type 3 (EV_ABS), code 40 (ABS_MISC), value 61 Event: time 1523042554.609417, -------------- SYN_REPORT ------------ Event: time 1523042554.617415, type 3 (EV_ABS), code 0 (ABS_X), value 4071 Event: time 1523042554.617415, -------------- SYN_REPORT ------------ Event: time 1523042554.669414, type 3 (EV_ABS), code 40 (ABS_MISC), value 56 Event: time 1523042554.669414, -------------- SYN_REPORT ------------ Event: time 1523042554.681415, type 3 (EV_ABS), code 40 (ABS_MISC), value 53 Event: time 1523042554.681415, -------------- SYN_REPORT ------------ Event: time 1523042554.689415, type 3 (EV_ABS), code 1 (ABS_Y), value 4003 Event: time 1523042554.689415, type 3 (EV_ABS), code 40 (ABS_MISC), value 46 Event: time 1523042554.689415, -------------- SYN_REPORT ------------ Event: time 1523042554.701415, type 3 (EV_ABS), code 0 (ABS_X), value 4072 Event: time 1523042554.701415, type 3 (EV_ABS), code 1 (ABS_Y), value 4002 Event: time 1523042554.701415, type 3 (EV_ABS), code 40 (ABS_MISC), value 34 Event: time 1523042554.701415, -------------- SYN_REPORT ------------ Event: time 1523042554.741417, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001 Event: time 1523042554.741417, type 1 (EV_KEY), code 272 (BTN_LEFT), value 0 Event: time 1523042554.741417, type 3 (EV_ABS), code 0 (ABS_X), value 4074 Event: time 1523042554.741417, type 3 (EV_ABS), code 1 (ABS_Y), value 3998 Event: time 1523042554.741417, type 3 (EV_ABS), code 40 (ABS_MISC), value 0 Event: time 1523042554.741417, -------------- SYN_REPORT ------------ Event: time 1523042556.385431, type 3 (EV_ABS), code 0 (ABS_X), value 1918 Event: time 1523042556.385431, type 3 (EV_ABS), code 1 (ABS_Y), value 2022 Event: time 1523042556.385431, type 3 (EV_ABS), code 40 (ABS_MISC), value 28 Event: time 1523042556.385431, -------------- SYN_REPORT ------------ Event: time 1523042556.397429, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001 Event: time 1523042556.397429, type 1 (EV_KEY), code 272 (BTN_LEFT), value 1 Event: time 1523042556.397429, type 3 (EV_ABS), code 40 (ABS_MISC), value 40 Event: time 1523042556.397429, -------------- SYN_REPORT ------------ Event: time 1523042556.405423, type 3 (EV_ABS), code 40 (ABS_MISC), value 55 Event: time 1523042556.405423, -------------- SYN_REPORT ------------ Event: time 1523042556.417426, type 3 (EV_ABS), code 40 (ABS_MISC), value 71 Event: time 1523042556.417426, -------------- SYN_REPORT ------------ Event: time 1523042556.425425, type 3 (EV_ABS), code 1 (ABS_Y), value 2024 Event: time 1523042556.425425, type 3 (EV_ABS), code 40 (ABS_MISC), value 86 Event: time 1523042556.425425, -------------- SYN_REPORT ------------ Event: time 1523042556.437424, type 3 (EV_ABS), code 0 (ABS_X), value 1919 Event: time 1523042556.437424, type 3 (EV_ABS), code 40 (ABS_MISC), value 100 Event: time 1523042556.437424, -------------- SYN_REPORT ------------ Event: time 1523042556.449423, type 3 (EV_ABS), code 40 (ABS_MISC), value 112 Event: time 1523042556.449423, -------------- SYN_REPORT ------------ Event: time 1523042556.457423, type 3 (EV_ABS), code 40 (ABS_MISC), value 122 Event: time 1523042556.457423, -------------- SYN_REPORT ------------ Event: time 1523042556.469421, type 3 (EV_ABS), code 40 (ABS_MISC), value 130 Event: time 1523042556.469421, -------------- SYN_REPORT ------------ Event: time 1523042556.477424, type 3 (EV_ABS), code 1 (ABS_Y), value 2025 Event: time 1523042556.477424, type 3 (EV_ABS), code 40 (ABS_MISC), value 136 Event: time 1523042556.477424, -------------- SYN_REPORT ------------ Event: time 1523042556.489425, type 3 (EV_ABS), code 0 (ABS_X), value 1920 Event: time 1523042556.489425, type 3 (EV_ABS), code 40 (ABS_MISC), value 139 Event: time 1523042556.489425, -------------- SYN_REPORT ------------ Event: time 1523042556.497427, type 3 (EV_ABS), code 1 (ABS_Y), value 2024 Event: time 1523042556.497427, type 3 (EV_ABS), code 40 (ABS_MISC), value 140 Event: time 1523042556.497427, -------------- SYN_REPORT ------------ Event: time 1523042556.509420, type 3 (EV_ABS), code 40 (ABS_MISC), value 137 Event: time 1523042556.509420, -------------- SYN_REPORT ------------ Event: time 1523042556.517422, type 3 (EV_ABS), code 0 (ABS_X), value 1919 Event: time 1523042556.517422, type 3 (EV_ABS), code 40 (ABS_MISC), value 135 Event: time 1523042556.517422, -------------- SYN_REPORT ------------ Event: time 1523042556.561425, type 3 (EV_ABS), code 0 (ABS_X), value 1918 Event: time 1523042556.561425, type 3 (EV_ABS), code 40 (ABS_MISC), value 139 Event: time 1523042556.561425, -------------- SYN_REPORT ------------ Event: time 1523042556.581421, type 3 (EV_ABS), code 40 (ABS_MISC), value 136 Event: time 1523042556.581421, -------------- SYN_REPORT ------------ Event: time 1523042556.593424, type 3 (EV_ABS), code 0 (ABS_X), value 1917 Event: time 1523042556.593424, type 3 (EV_ABS), code 40 (ABS_MISC), value 116 Event: time 1523042556.593424, -------------- SYN_REPORT ------------ Event: time 1523042556.601425, type 3 (EV_ABS), code 40 (ABS_MISC), value 85 Event: time 1523042556.601425, -------------- SYN_REPORT ------------ Event: time 1523042556.613424, type 3 (EV_ABS), code 0 (ABS_X), value 1916 Event: time 1523042556.613424, type 3 (EV_ABS), code 1 (ABS_Y), value 2022 Event: time 1523042556.613424, type 3 (EV_ABS), code 40 (ABS_MISC), value 55 Event: time 1523042556.613424, -------------- SYN_REPORT ------------ Event: time 1523042556.653424, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90001 Event: time 1523042556.653424, type 1 (EV_KEY), code 272 (BTN_LEFT), value 0 Event: time 1523042556.653424, type 3 (EV_ABS), code 40 (ABS_MISC), value 0 Event: time 1523042556.653424, -------------- SYN_REPORT ------------
I ran evtest in cli mode not in a terminal on the desktop and so the log proves that the touchscreen is working in the cli so the problem is definitely that fruitbox doesn't see it or recognize it.
regards
GeoffB
Hi GeoggB,
Hi GeoffB,GeoffB wrote: ↑Fri Apr 06, 2018 8:20 pmJurgen
I created the fruitbox.btn exactly as you described in your post and still no joy. it's clear from the fruitbox.log that Mike asked me to create and was included in a previous post that fruitbox is not seeing the ELO Touchscreen at all.
I feel a bit guilty now as both you and Mike are trying to find a solution and it may be taking attention away from more important things.
I wanted to use the ELO because I have it here available and they are really well made and solid devices. It would be ideal to make a floor standing Touchscreen jukebox.
regards
GeoffB
fruitbox v1.11-jurgen4 (Mar 23 2018, 15:23:05) by Mike Kingsley
A customisable MP3 Retro Jukebox for the Raspberry Pi
Detecting display...800 x 600 (60Hz)
Loading button mapping file 'fruitbox.btn'...
TouchDevice = Elo
ButtonVol+ = Touch
ButtonVol- = Touch
ButtonRandom = Touch
ButtonSkip = Touch
ButtonLeft = Touch
ButtonRight = Touch
NOTE: Opened input device 'Elo' (/dev/input/event4)
Reading configuration 'skins/TouchOne/fruitbox.cfg'...
[general]
SkinName = TouchSong
SkinDescription = Touch skin for Official Raspberry Pi 7" Touch Screen
SkinSize = 800 480
Database = ../fruitbox.db
MusicPath = ../Music/
SortSongsBy = Title
SortSongsBy = Artist
SelectKeys = 0909
AutoSelect = true
SelectTimeout = 150
SelectHoldTimeout = 150
AutoPageTurnTime = 3000
MaxPlaylistLength = 20
LoopPlaylist = false
PlaysPerCoin1 = 0
SongsPerPage = 6
PageSize = 360 308
PairSongs = Dual
ArtistDescription = Artist
ArtistDescription = " / "
ArtistDescription = PairedArtist
PageMoveStyle = 20 0 false
SongLoadTime = 0
SongUnloadTime = 0
ArtistText = 1 255 32 32 255 centre true true false 0 7 294
SongText = 0 0 0 0 255 centre true true true 0 7 360
[sounds]
[font]
File = skins/TouchOne/bluecond.ttf
Height = 24
[font]
Height = 22
[font]
File = skins/TouchOne/dotmatrx.ttf
Height = 16
[font]
Height = 18
[bitmap]
File = skins/TouchOne/background.jpg
Position = 0 0
Size = 800 480
[page]
Position = 30 100
Background = skins/TouchOne/strip3.jpg
[page]
Position = 410 100
[status]
Position = 30 12
Size = 352 84
Text = 2 255 255 255 255 right false true false 0 0 350
Contents = skins/TouchOne/now_playing.txt
LineSpacing = 4
TimerTickPeriod = 60
[status]
Position = 414 12
Size = 352 84
Text = 2 255 255 255 255 left false true false 0 0 350
Contents = skins/TouchOne/coming_up.txt
LineSpacing = 4
[status]
Position = 160 432
Size = 234 53
Text = 2 255 255 255 255 centre false false false 0 0 350
Contents = skins/TouchOne/help.txt
LineSpacing = 4
TimerTickPeriod = 200
[touch song]
Bitmap = skins/TouchOne/touch_red.png
[bitmap]
File = skins/TouchOne/foreground.png
Position = 0 0
Size = 800 480
[bitmap]
File = skins/TouchOne/volume.png
Position = 8 422
Size = 12 51
VertScale = Volume
VertScaleMode = Clipped
[status]
Position = 423 421
Size = 93 53
Bitmap = skins/TouchOne/random_button.png
Contents = skins/TouchOne/random_pressed.txt
[status]
Position = 546 421
Size = 94 53
Bitmap = skins/TouchOne/skip_button.png
Contents = skins/TouchOne/skip_pressed.txt
[status]
Position = 663 421
Size = 54 53
Bitmap = skins/TouchOne/left_button.png
Contents = skins/TouchOne/left_pressed.txt
[status]
Position = 37 421
Size = 93 53
Bitmap = skins/TouchOne/volume_button.png
Contents = skins/TouchOne/volume_pressed.txt
[status]
Position = 717 421
Size = 53 53
Bitmap = skins/TouchOne/right_button.png
Contents = skins/TouchOne/right_pressed.txt
[touch areas]
ButtonRandom = 423 421 94 53
ButtonSkip = 546 421 94 53
ButtonLeft = 663 421 48 53
ButtonRight = 724 421 45 53
ButtonVol- = 38 421 32 53
ButtonVol+ = 98 421 32 53
Initialising audio ...
Loading database '../fruitbox.db'...6 songs found
Sorting songs by Title...
Sorting songs by Artist...
Building song pages...
Let's Rock!
Yes! That's it! fruitbox ist seeing your touchscreen! Look at the Line beginning with NOTE: Now it is mikes part to calculate the correct touch Points!GeoffB wrote: ↑Fri Apr 06, 2018 8:56 pmJugen
See below for fruitbox.log as requested
hope this is what you wanted to seeCode: Select all
fruitbox v1.11-jurgen4 (Mar 23 2018, 15:23:05) by Mike Kingsley A customisable MP3 Retro Jukebox for the Raspberry Pi Detecting display...800 x 600 (60Hz) Loading button mapping file 'fruitbox.btn'... TouchDevice = Elo ButtonVol+ = Touch ButtonVol- = Touch ButtonRandom = Touch ButtonSkip = Touch ButtonLeft = Touch ButtonRight = Touch NOTE: Opened input device 'Elo' (/dev/input/event4) Reading configuration 'skins/TouchOne/fruitbox.cfg'... [general] SkinName = TouchSong SkinDescription = Touch skin for Official Raspberry Pi 7" Touch Screen SkinSize = 800 480 Database = ../fruitbox.db MusicPath = ../Music/ SortSongsBy = Title SortSongsBy = Artist SelectKeys = 0909 AutoSelect = true SelectTimeout = 150 SelectHoldTimeout = 150 AutoPageTurnTime = 3000 MaxPlaylistLength = 20 LoopPlaylist = false PlaysPerCoin1 = 0 SongsPerPage = 6 PageSize = 360 308 PairSongs = Dual ArtistDescription = Artist ArtistDescription = " / " ArtistDescription = PairedArtist PageMoveStyle = 20 0 false SongLoadTime = 0 SongUnloadTime = 0 ArtistText = 1 255 32 32 255 centre true true false 0 7 294 SongText = 0 0 0 0 255 centre true true true 0 7 360 [sounds] [font] File = skins/TouchOne/bluecond.ttf Height = 24 [font] File = skins/TouchOne/bluecond.ttf Height = 22 [font] File = skins/TouchOne/dotmatrx.ttf Height = 16 [font] File = skins/TouchOne/bluecond.ttf Height = 18 [bitmap] File = skins/TouchOne/background.jpg Position = 0 0 Size = 800 480 [page] Position = 30 100 Background = skins/TouchOne/strip3.jpg [page] Position = 410 100 Background = skins/TouchOne/strip3.jpg [status] Position = 30 12 Size = 352 84 Text = 2 255 255 255 255 right false true false 0 0 350 Contents = skins/TouchOne/now_playing.txt LineSpacing = 4 TimerTickPeriod = 60 [status] Position = 414 12 Size = 352 84 Text = 2 255 255 255 255 left false true false 0 0 350 Contents = skins/TouchOne/coming_up.txt LineSpacing = 4 [status] Position = 160 432 Size = 234 53 Text = 2 255 255 255 255 centre false false false 0 0 350 Contents = skins/TouchOne/help.txt LineSpacing = 4 TimerTickPeriod = 200 [touch song] Bitmap = skins/TouchOne/touch_red.png [bitmap] File = skins/TouchOne/foreground.png Position = 0 0 Size = 800 480 [bitmap] File = skins/TouchOne/volume.png Position = 8 422 Size = 12 51 VertScale = Volume VertScaleMode = Clipped [status] Position = 423 421 Size = 93 53 Bitmap = skins/TouchOne/random_button.png Contents = skins/TouchOne/random_pressed.txt [status] Position = 546 421 Size = 94 53 Bitmap = skins/TouchOne/skip_button.png Contents = skins/TouchOne/skip_pressed.txt [status] Position = 663 421 Size = 54 53 Bitmap = skins/TouchOne/left_button.png Contents = skins/TouchOne/left_pressed.txt [status] Position = 37 421 Size = 93 53 Bitmap = skins/TouchOne/volume_button.png Contents = skins/TouchOne/volume_pressed.txt [status] Position = 717 421 Size = 53 53 Bitmap = skins/TouchOne/right_button.png Contents = skins/TouchOne/right_pressed.txt [touch areas] ButtonRandom = 423 421 94 53 ButtonSkip = 546 421 94 53 ButtonLeft = 663 421 48 53 ButtonRight = 724 421 45 53 ButtonVol- = 38 421 32 53 ButtonVol+ = 98 421 32 53 Initialising audio ... Loading database '../fruitbox.db'...6 songs found Sorting songs by Title... Sorting songs by Artist... Building song pages... Let's Rock!
Regards
GeoffB
Hi MarkalMarkal wrote: ↑Sat Apr 07, 2018 3:50 amHi Mike
I have been looking further into the options to extend the control buttons but using the usb port as a keyboard emulator as a solution as previous posts have mentioned.
I try playing with two old usb keyboards I had, but the tracks on the multiplexer boards are just too fine and break off immediately a wire is connected to it. The plastic foil keyboard membranes are obviously useless to try and solder to. i did try gluing the cable to the board first, but then the soldering melts the insulation enough for the wire to lift the tack again. Hey, I tried.
Next i followed the mention in a previous posting about Arduinos and I read a few articles that said an Arduino Uno could be converted. As I have 2 Arduinos, a Rev 2 and a rev 3 in the garage I thought I would give it a go, but was not able to get 'Flip' to work due to errors saying missing files etc so unable to get it to flash the correct firmware upgrade needed. I spent a few days trying to work out what I was doing wrong, but eventually decided I was flogging a dead horse and though I would look further afield.
I then read that a Raspberry Pi Zero could be used to emulate a usb keyboard, and seeing how I have a spare Pi Zero laying on my desk that I have not opened yet, thought I will play with this. A few articles seem confident that it can be made to work including adafruits site.
I am just waiting on a config cable to set it up and will let you know if I manage to get it to work.
If anyone else has gone this route, would be interested in their findings and how they got there.
Hi Markal,GeoffB wrote: ↑Sat Apr 07, 2018 7:29 amHi MarkalMarkal wrote: ↑Sat Apr 07, 2018 3:50 amHi Mike
I have in the past hacked usb keyboards tbo I found it quite easy to do. Back in the days when I was messing about with DW Jukebox I used hacked usb keyboards to interface switches for my jukebox.
A quick search in Google found this
http://www.instructables.com/id/Hacking-a-USB-Keyboard/
I hope that this may help you. I know that the tracks are delicate you may have to use a lower powered soldering iron with a fine pointed tip I have an Antex 17w iron that I use for fine work.
regards
GeoffB
Hi bernyone,
mamer999 wrote:
Hi bernyone,
how did you open the box? I have bought a new one here in Germany (40 €) and find no way to open the case without damaging anything.
Cheers
Jürgen
