- DSCN0001edited.JPG (192.79 KiB) Viewed 3757 times
Hikomarowski wrote: ↑Fri Jul 19, 2019 9:09 amHello everyone,![]()
To begin a big thank you to Mike for your great work! I have a little problem all is well parametrer but when I add mp3 files in the directory folder that I targeted in my chosen skin the file is not added to the launch of fruitbox an idea of the problem? or there is a manupulation to make fruitbox take into account the new mp3![]()
Thank you in advance for the answers !
Hi
sudo chmod -R +rw skins
HiDA313 wrote: ↑Wed Jul 24, 2019 11:02 pmTargetIndy,
You might want to try using Picard (a great meta tag editor). Not sure how well it will recognize non commercial MP3s but it's worth a shot. Use Picard on a regular Linux machine though; RPi isn't powerful enough IMHO.
sudo apt-get install picard
By the way, love your project.
HiTargetIndy wrote: ↑Wed Jul 24, 2019 8:41 pm
But now I've hit a snag. I've begun creating MP3 files from my vinyl collection (I'm using Audacity to do it). For some reason Fruitbox doesn't see the files I've created. I've filled out the Metadata information (Artist Name, Track Title, Album Title, Track Number, and Genre) through Audacity's Metadata tool.
Hopefully you guys can help. Is there something in the metadata or file creation that I'm missing? Is there something I need to do in Fruitbox? Fruitbox doesn't have a problem seeing my commercially made MP3's, so I suspect it's something with the file setup.
fruitbox wrote: ↑Thu Jul 25, 2019 7:56 amThanks, Mike. That was indeed my problem.TargetIndy wrote: ↑Wed Jul 24, 2019 8:41 pmIf fruitbox isn't seeing your files, then perhaps it's a music path problem rather than an mp3 tag issue. Also don't forget to delete the fruitbox.db file when you change your mp3 files otherwise fruitbox won't pick up the changes (fixed in next release)
Cheers
Mike
Hi
Thanks Mike.fruitbox wrote: ↑Tue Aug 13, 2019 7:26 amHi
MikeTV is currently the only skin which displays video. Have you considered creating your own skin or modifying an existing one? The video is easily displayed using the $VIDEO related status variables. If you look at the fruitbox.cfg file (and associated status box text files) for the MikeTV skin, and also check out the user guide it may start to make more sense
Cheers
Mike
Aaaaaaannnnnnnddddddd . . . done!fruitbox wrote: ↑Tue Aug 13, 2019 7:26 amHi
Cheers
Mike
Does it also play the disc changing mechanism for ordinary tunes?
Yes it does. If you don't want it to then comment out those lines of code.
Hi karrika
Hi Mike,fruitbox wrote: ↑Fri Aug 16, 2019 10:56 amHi karrika
If you let me know exactly how you want the skin to behave I can create it for you
Cheers
Mike
Hi MichaelTuco wrote: ↑Fri Aug 16, 2019 11:02 am
Hi Mike,
Happy with my mods to play video but as mentioned above when the video finishes it 'appears to freeze' for about 45 seconds before the removal of the record happens.
Other question is how is the album art displayed. So far one of my songs displayed album art (only tried a few songs)
Is that to do with the ID tag?
Michael. (Tuco)
